 Old 11-25-2013, 12:09 AM   #1
Status Update's Avatar
Posts: 461   (View Stats)
Status Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the world
Default Downpipe to Turbo Stud Broke
This past weekend a friend and I were working on my downpipe and one of the studs was being a bitch and would not budge. Long story short the stud at the bottom left that connects the downpipe to turbo snapped... Right now there are 4 studs/nuts that are holding the dp and the turbo together with a new replacement gasket in-between it. I understand that there are 5 studs for a reason but my friend says that as long as the other 4 studs are in securely and with a new gasket in place there shouldn't be an exhaust leak there. How can I test for an exhaust leak in that spot since its the bottom stud I cant really do the soap/water trick since it would drip right down. If I need to fix this what would I need to do to go about this? This install has been such a pain in the ass!
BMW 335xi 6MT
AR Catless Downpipes///HPF Fmic///BMS DCI///CP-e Chargepipe///Cobb AP V2///Volk TE37sl 18x9.5+22F 18x10.5+20R
2007 BM Mazdaspeed 6 GT #10477
SOLD 8/29/14
Status Update is offline   Reply With Quote
 Old 11-25-2013, 12:32 AM   #2
speed3sailor's Avatar
Posts: 835   (View Stats)
speed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the worldspeed3sailor is the leader of the world
you might be able to look at your fuel trims. I believe they will go negative if you have an exhaust leak. could be wrong on that one. you could also just get under the car while it is running and see if its leaking. possibly have somone give a little rev. I personally think it will start leaking. Best thing to do is order a new stud or two and change it out when you get it in. to remove the broken one, youll have to remove the DP again and then back two of the nuts up against each other with the flat parts of the nuts touching. tighten them against each other really tight then turn the bottom nut left and with a little luck the stud will turn with the nuts. good luck.
07 SILVER Speed3 , BNR S3- Tial 38mm EWG w/ stock mani- COBB AP- Ebay catless Downpipe- HTP 3in intake- Devils Own WMI (D10)- CX Racing FMIC- Autotech internals- Grimmspeed 3P EBCS- Denso ITV22- HKS super SQV- Bosch 3 bar - Damon PMM- JBR RMM- shift weight- EGR delete- TIGs- JBR RSB- Eibach springs- TR Motorsports 17x9- Hankook RS-3 255/40/17
speed3sailor is offline   Reply With Quote
The Following User Says Thank You to speed3sailor For This Useful Post:
Status Update (11-25-2013)
 Old 11-25-2013, 12:57 AM   #3
Originally Posted by calizoomzoom View Post
fawwkk..i hope it works out for you but i really think it will leak.. and drilling out broken studs aint no walk in the park.. goodluck sir
Thanks and if it comes to drilling oh boy I have nooooo idea how this is going to work out lol I found a thread on IWSTI and I'll probably have to pull the turbo and drill it out and then screw extractor it but the bit that snapped off is only about 1/4th of the original stud. Id take off the downpipe and try and vise grip the stud but it snapped off good and there is nothing to grab.
I'll take a look at my STFT's and LTFT's but on top of that I have a pretty bad dp to cbe exhaust leak too so its going to be hard to find out whether its the stud that would cause the exhaust leak or the actual dp-cbe.
BMW 335xi 6MT
SOLD 8/29/14
 Old 11-25-2013, 12:38 AM   #4
calizoomzoom's Avatar
Posts: 684   (View Stats)
calizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the worldcalizoomzoom is the leader of the world
calizoomzoom is offline   Reply With Quote
The Following User Says Thank You to calizoomzoom For This Useful Post:
 Old 11-25-2013, 01:05 AM   #5
sounds like your exhaust is F'd in the B.
 Old 11-25-2013, 01:13 AM   #6
Oh yeah definitely lol... I have a magnaflow cbe on the way so once thats in hopefully i'll be able to figure out if its leaking at the turbo-dp. Shits been fucked up since I got the dp installed lol. Threw a p0137 and p2096 simultaneously when i went 3/4 throttle and overboosted so hopefully I can clear those codes and they wont come back.
BMW 335xi 6MT
SOLD 8/29/14
 Old 12-28-2013, 06:30 PM   #7
Jkspeed's Avatar
Posts: 293   (View Stats)
Jkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond reputeJkspeed has a reputation beyond repute
Groaned at 6 Times in 4 Posts
Any luck?
2008.5 Metro Grey MS3
Performance:
HTP 3.5" Intake | Autotech HPFP Internals | SU TMIC | EBay Catless DP | Stratified Tuned | JBR 88a Dogbone - Short shift plate | Eibach Pro-Kit | 18x8 MB Interline wheels | Conti DW's 235/40R18 | JBR Rear Sway Bar
Other fun:
Dashhawk | Single res delete | Corksport Interior LED light kit - Bypass valve hose | Vent pod boost gage | Custom Heated driver and passenger seats | Leather shift boot
Jkspeed is offline   Reply With Quote
 Old 12-28-2013, 06:57 PM   #8
I've been running 4/5 studs and so far no exhaust leaks from the turbo/dp so its pretty good I'm still waiting to install my magnaflow cbe since the dp to cb is where I'm leaking at. Running a lot better now that I'm on my first revision of my stratified tune.
Sent from my DROID RAZR using Tapatalk 2
BMW 335xi 6MT
SOLD 8/29/14
 Old 12-28-2013, 07:00 PM   #9
Jkspeed's Avatar
Good to hear. I know @plak424; broke some studs doing his dp so he may have some input if you want to replace it down the road.
Performance:
Other fun:
The Following User Says Thank You to Jkspeed For This Useful Post:
Status Update (12-28-2013)
 Old 12-28-2013, 08:18 PM   #10
LatinKraze's Avatar
Posts: 804   (View Stats)
Start the car and shove a multi-purpose lighter next to the broken stud. If the flame goes out, there's a leak
2016 CX-5 GT AWD
The Following 2 Users Say Thank You to LatinKraze For This Useful Post:
ItsNox (12-28-2013), Status Update (12-28-2013)
 Old 12-28-2013, 08:42 PM   #11
Johnasaurus's Avatar
Posts: 359   (View Stats)
Johnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the worldJohnasaurus is the leader of the world
You might not need to remove the downpipe to get the stud out. If there's toom for an easy out I would do that instead.
Johnasaurus is offline   Reply With Quote
The Following User Says Thank You to Johnasaurus For This Useful Post:
 Old 12-28-2013, 09:33 PM   #12
mike w's Avatar
Posts: 138   (View Stats)
mike w has a reputation beyond reputemike w has a reputation beyond reputemike w has a reputation beyond reputemike w has a reputation beyond reputemike w has a reputation beyond reputemike w has a reputation beyond reputemike w has a reputation beyond reputemike w has a reputation beyond reputemike w has a reputation beyond reputemike w has a reputation beyond reputemike w has a reputation beyond repute
I broke one of the studs when I installed new dp this summer. I had to take the turbo out, drill the bolt and I was able to use an easy out to get the broken stud out. You must take your time drilling. You do not want to break the drill bit in the stud. And get a good drill bit/easy out set. There are a lot of how to's, also. Good luck. You can definitely do it.
mike w is offline   Reply With Quote
The Following 2 Users Say Thank You to mike w For This Useful Post:
 Old 12-28-2013, 09:45 PM   #13
I would attempt to get the stud out but when it snapped 95% of the stud came out idk. Seems to be a big headache so as long as its not giving me any problems ill just leave it but I do appreciate the help guys. I guess ill be saving up for a bnr s3
BMW 335xi 6MT
SOLD 8/29/14
 Old 02-28-2014, 07:35 PM   #14
ForAiur's Avatar
Posts: 53   (View Stats)
ForAiur has much to be proud ofForAiur has much to be proud ofForAiur has much to be proud ofForAiur has much to be proud ofForAiur has much to be proud ofForAiur has much to be proud ofForAiur has much to be proud ofForAiur has much to be proud ofForAiur has much to be proud ofForAiur has much to be proud of
Sorry to revive this but any change on your broken stud situation? Are you still running with 4 without issue? This just happened to me too, seems to be running leak free for now...
ForAiur is offline   Reply With Quote
 Old 02-28-2014, 09:14 PM   #15
Its actually leaking now -.- the primary o2 sensor wire and part of the firewall is covered in black soot so blah
BMW 335xi 6MT
SOLD 8/29/14
The Following User Says Thank You to Status Update For This Useful Post:
ForAiur (03-01-2014)
 Old 03-01-2014, 04:01 PM   #16
ForAiur's Avatar
Shit thats no good, sorry to hear that. Guess I should just bite the bullet and get it sorted sooner than later. Hopefully it can be done without pulling the turbo.
 Old 03-01-2014, 09:29 PM   #17
Invisible_2.3's Avatar
Posts: 68   (View Stats)
Invisible_2.3 has a spectacular aura aboutInvisible_2.3 has a spectacular aura about
Groaned at 23 Times in 9 Posts
You will have to pull the turbo
Invisible_2.3 is offline   Reply With Quote
 Old 03-19-2014, 12:47 PM   #18
bean59's Avatar
Posts: 62   (View Stats)
bean59 is a jewel in the roughbean59 is a jewel in the roughbean59 is a jewel in the rough
I stripped one of the stud holes when removing my dp flange and yea you can't get anything in there. I'm afraid you will have to remove the turbo which is what I did. There is just no room to move around. Once you get the turbo out it is a breeze. Kinda of a pita ass for one bolt I know. I also used some of that red rtv gasket where the flange mates to the turbo just to be sure of no leaks. Good luck
2006 Mazdaspeed 6 - H&R springs - CPE TMIC - MS CAI - Autotech HPFP-Cobb STG 2 93 - Custom 3in straight pipe exhaust - N2MB Wotbox -SURE RMM- SURE Juggernaught + Turbine Tech Diff Bushings- CPE STG2 Clutch- Corksport TIP- CPE Inj Seals- JBR IM Gasket- ITV 22-Carputer -12in Kicker @ 500w-EGR delete + OCC- Forge BPV
bean59 is offline   Reply With Quote
The Following 2 Users Say Thank You to bean59 For This Useful Post:
ForAiur (03-26-2014), Status Update (03-20-2014)
 Old 03-20-2014, 12:34 PM   #19
Gives me an excuse to go bnr LOL
Sent from my Nexus 5 using Tapatalk 2
BMW 335xi 6MT
SOLD 8/29/14
 Old 03-26-2014, 10:30 PM   #20
ForAiur's Avatar
Thanks for the info, curious when you reinstalled your turbo did you need to replace the gaskets/washers or did you reuse everything? I think there are some crush washers involved no? Just want to have everything before I start hah..
 Old 03-27-2014, 12:55 PM   #21
bean59's Avatar
Yea buy some new crush washers. I tried to reuse them but it gave me an oil leak. I reused the stock dp flange gasket mine was pretty new don't know how yours is. Theres another gasket underneath the turbo for the oil drain line too and one on the other end that goes into the block.
Sent from my LG-E971 using Tapatalk
 Old 03-27-2014, 01:31 PM   #22
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
a word of advice to any of you using factory style turbo flange REPLACE THE NUTS EACH TIME, if you try to re use the nuts they get very distorted and the threads fuck up which is why so many people have issues removing the nuts, they strip and bind to the stud so badly allowing the studs to snap.
make sure you replace all 5 nuts each time or your guaranteed fail. and re install new nuts with anti seize. i swear they are designed to disintegrate on removal .... im soo soooo asoooooooo glad i dont use those nuts anymore they fucking SUCK, they are the difference between a 1 hour downpipe install and a 4-5(or 2 day for that matter) hour install.
the studs that come off with the Nut do not need replacing, just the ones that come off without the stud alone, REPLACE those
the nuts get so bad i had one fall apart and peel apart like an orange before it came off.
The Following 4 Users Say Thank You to Nitr0EngiE For This Useful Post:
Anaphra (02-02-2020), Cevaes_64 (06-11-2014), siegsuwa (06-02-2015), Status Update (03-27-2014)
Broke ass turbo forced my hand mzr0818 MazdaSpeed 3/6 - Big Turbo Builds 115 04-02-2013 07:26 AM
Over torqued the lug nut and one of the stud broke offf TheMarKing 2010 MS3 - Wheels & Tires 10 06-06-2010 10:46 PM
extra stud from turbo to downpipe bova MazdaSpeed 3/6 - Turbo Induction 2 05-16-2008 03:42 PM
Page generated in 0.40737 seconds with 30 queries
