 Old 12-24-2009, 09:42 AM   #1
frontrightpocket's Avatar
Posts: 125   (View Stats)
frontrightpocket has a reputation beyond reputefrontrightpocket has a reputation beyond reputefrontrightpocket has a reputation beyond reputefrontrightpocket has a reputation beyond reputefrontrightpocket has a reputation beyond reputefrontrightpocket has a reputation beyond reputefrontrightpocket has a reputation beyond reputefrontrightpocket has a reputation beyond reputefrontrightpocket has a reputation beyond reputefrontrightpocket has a reputation beyond reputefrontrightpocket has a reputation beyond repute
Default Dp + Turboback
So I've been reading online that an aftermarket exhaust is essentially useless unless you're going to be/ or already are making big power, since the stock exhaust flows pretty well. But, I've also read in a few places that with the combination of a DP and E, yields anywhere between 30-40 whp. Is this mainly the numbers of replacing the restrictive design of the stock downpipe to a more free-flowing design, or is the aftermarket exhaust actually making a substantial addition to the power? Can someone clear this up for me? Thanks in advance.
frontrightpocket is offline   Reply With Quote
 Old 12-24-2009, 10:28 AM   #2
soccerballz's Avatar
Posts: 596   (View Stats)
soccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the world
I wouldn't say that either is 100% correct. A TBE is going to give you a good amount of power whether your lightly or heavily modded, most of that power is from the downpipe which is the most restrictive part of the exhaust. But I wouldn't expect 30-40whp from it either. Hope that helps.
08' Black Mica MS3
Mods: Vibrant 3" SRI, CP-E 3" TIP, GT3071 IWG, Manley H-beam rods, Wiseco Pistons, BSD, PG Exhaust Mani V3, CP-E Catted Downpipe, Borla CBE, CP-E FMIC, Cobb AP, CP-E HPFP, Turbosmart DP BOV, Cobb SS + Bushings, Cobb Shifter Weight.
Sponsored by NATOR VA
soccerballz is offline   Reply With Quote
 Old 12-24-2009, 11:11 AM   #3
Yeah this clears up a bit, but I'm still not sure how a TBE can derive "a good amount" of power on a lightly modded application because for it to work effectively, wouldn't you need a highly increased air flow pattern for the benefits in power? As it holds, (with the stock exhaust) the air flow isn't constricted all that heavily save for the downpipe area... in total, can you explain how it can benefit in power, and can it be a good power-getter through getting a downpipe, since that will increase air flow by a significant amount?
 Old 12-24-2009, 11:47 AM   #4
Docnox's Avatar
Posts: 1,435   (View Stats)
Docnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the world
Groans: 35
Turbos feed off the exhaust, making it typically the easiest power adder. Make the car inhale and exhale easier, with an intake and exhaust and you'll be very happy.
'06 Speed 6
Black Mica
Mazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe,
3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp
Altered Customs fmic, Autotech fp internals
Cobb AP, Stage 2+ 93 tweaked
Centric blanks, EBC red pads
Lotek center gauge pod: AEM wideband, Autometer boost and volts
Tints, blacked emblems, spec-v front lip, Shark fin
Redline MT-90, ITV-22s, Matt Damond OCC
13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap)
DO Meth kit waiting on install
Docnox is offline   Reply With Quote
 Old 12-24-2009, 12:06 PM   #5
prenedo's Avatar
Posts: 423   (View Stats)
prenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the worldprenedo is the leader of the world
The 'catback' isn't gonna net much, but the dp/rp will remove the cats which are the restriction. TBE is just a term used for the dp and catback put together, essentially making it a free flow from the 'turbo-back'. No need to change out the catback, putting dp in will essentially turn your stock exhaust into a turbo back.
prenedo is offline   Reply With Quote
The Following User Says Thank You to prenedo For This Useful Post:
frontrightpocket (12-24-2009)
 Old 12-24-2009, 01:00 PM   #6
darth vader's Avatar
Posts: 665   (View Stats)
darth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the world
Groaned at 9 Times in 9 Posts
ANY turbo car, gains most from adding better stuff to the front of the exhaust, not the back. Closer to the front, generally the more the gain is. I'll tell you that a DP/RP combo COULD easily net you 30-40 over stock, paired with a decent intake, using the stock cat-back.
Wanna do it a bit at a time? Do it the easy way: Intake first, then RP, then DP if you're still motivated.
darth vader is offline   Reply With Quote
 Old 12-24-2009, 02:56 PM   #7
JoshC23's Avatar
Posts: 375   (View Stats)
JoshC23 is the leader of the worldJoshC23 is the leader of the worldJoshC23 is the leader of the worldJoshC23 is the leader of the worldJoshC23 is the leader of the worldJoshC23 is the leader of the worldJoshC23 is the leader of the worldJoshC23 is the leader of the worldJoshC23 is the leader of the worldJoshC23 is the leader of the worldJoshC23 is the leader of the world
Groaned at 8 Times in 4 Posts
It definitely gains 30whp with a full catless TBE. Its not worth the money to get a catback, though. It probably will get you 5whp with the aftermarket catback added to an aftermarket DP/RP. With the stock DP/RP and and an aftermarket catback you wont get anything but louder. And at 500-700 dollars you can do a lot better(like a Mani). But if you want a loud ass ms3 get a Mani/DP/RP/CBE. Its about 40whp over stock and with an intake and TIP its about 60whp over stock. Stock being 220whp.
AEM CAI, Cobb TIP, HKS BOV, SU MM, TurboXs FMIC, PG Mani, TurboXs DP/RP, Borla Catback, CPE Standback/20psi, DH, ITV22 plugs, KMD cdfp, DO Meth stage 2, N2MB WOT BOX, HKS TT, Prosport boost guage w/vent pod, Mazdaspeed springs w/camber links, OZ Ultraleggra's w/G-Force KDW's
JoshC23 is offline   Reply With Quote
The Following User Says Thank You to JoshC23 For This Useful Post:
flyrevs2 (12-24-2009)
 Old 12-24-2009, 03:52 PM   #8
Alright, thanks all. I'm much more clear on this. I appreciate it
 Old 12-24-2009, 04:01 PM   #9
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
i actually like the stock catback you ms3 guys get, i dont think i would fork out for an aftermarket CBE.
2008 STi
Intake
Turboback
AP
 Old 12-24-2009, 04:10 PM   #10
Yeah, uncut and paired with a Corksport DP and RP, the car sounds really nice. Makes me roll the window down and turn up the floor heat full blast just to listen to it, despite the fact it's freezing outside.
 Old 12-24-2009, 04:53 PM   #11
reddeerspeed3's Avatar
Posts: 689   (View Stats)
reddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the world
lmao! i've been doing the same thing lately
reddeerspeed3 is offline   Reply With Quote
 Old 12-24-2009, 05:34 PM   #12
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
do what i is do done did it...nut in the gas tank!
 Old 12-24-2009, 09:17 PM   #13
I get on it so much, just to hear the stock catback roar, i love it. I only have a test pipe though, need that dp lol.
Cobb Turboback Exhaust xandrake MazdaSpeed 3 - Engine, Transmission & Driveline 72 10-16-2011 09:06 PM
Turboback is squeaking KeysMS3 MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-16-2009 12:19 PM
got the turboXS turboback exhaust and have questions johnsonroda27 MazdaSpeed 3/6 - Turbo Induction 19 07-27-2009 09:23 PM
Page generated in 0.34214 seconds with 28 queries
