Like Tree5Likes
  • 2 Post By btstarcher
  • 1 Post By Lex
  • 1 Post By atvfreek
  • 1 Post By skiptowncat
 Old 12-24-2013, 11:12 AM   #1
NuminouSpeed's Avatar
Posts: 36   (View Stats)
NuminouSpeed is a name known to allNuminouSpeed is a name known to allNuminouSpeed is a name known to allNuminouSpeed is a name known to allNuminouSpeed is a name known to allNuminouSpeed is a name known to all
Default Easy Boost Creep Fix?
I'm sure there's some obvious reason this wouldn't work that isn't occurring to a noob like me, but at the risk of being flamed I thought I'd ask:
Why not just install a Stratified Guardian Angel and set the soft boost cut to your desired peak boost?
Granted, this wouldn't address how quickly the boost builds, but it would set an ultimate cap, right?
NuminouSpeed is offline   Reply With Quote
 Old 12-24-2013, 11:27 AM   #2
btstarcher's Avatar
Posts: 4,852   (View Stats)
@Boost_creep;
Because he's calling you out.
Also because I have no idea how to answer your question.
Boost_creep and NuminouSpeed like this.
SnailTune in progress
 Old 12-24-2013, 12:05 PM   #3
The GA is a safety device and although it stops creep and spikes, it should not be used as a boost controller as the turbo is overworked during extended periods of time and system is not efficient.
We need more details on your setup. Is it an OEM turbo or aftermarket? What intake and exhaust, what is boost creeping to? What is the tune doing?
Boost_creep (12-24-2013)
 Old 12-24-2013, 12:14 PM   #4
Voltwings's Avatar
Posts: 3,713   (View Stats)
Depending on a few variables it could also act as a boost leak and throw your AFR off when used this way. in theory what you're saying could be done, but its not very practical.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 12-24-2013, 12:23 PM   #5
I was just asking for a friend who's getting creep on a 3071. He was advised to port WG/add cat/or both. I was just trying to think outside the box. He wasn't looking forward to the hassle of removing the turbo, addressing the issue, and the DD downtime. If nothing else, the GA would be great to have anyways and it may buy him some time until a more convenient time to do the wrenching.
Makes sense that the GA is a safety measure and not meant to be engaged on a frequent basis.
A related aside: I'm about to go BNR. Will I experience creep with my catless setup? I didn't think so, but I wasn't thinking about the catless aspect before. I'll be using a Stratified 3-port.
 Old 12-24-2013, 12:50 PM   #6
atvfreek's Avatar
Posts: 7,787   (View Stats)
Full catless and 3" exhaust will likely cause creep on the BNR as well, especially in the colder weather
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
Lex (12-24-2013), NuminouSpeed (12-24-2013)
 Old 12-24-2013, 12:52 PM   #7
Awww, crap. Better save up for a cat to be welded in. I still have the stock axle-back section. Does that matter?
 Old 12-24-2013, 12:53 PM   #8
Yes, any restriction will help prevent creep. A small exhaust, smaller intake, etc. they all "help" prevent creep.
atvfreek (12-24-2013), NuminouSpeed (12-24-2013), redboat (12-24-2013)
 Old 12-24-2013, 12:57 PM   #9
atvfreek's Avatar
The stock axle back may be just enough. Here is an example. I tuned a friend on a k04 that was catess. We had full control over boost when cold. He added the full 3" CBE and then boost would spool well above 20 with zero wgdc, especially in 5th gear. So as lex said, any type of restriction will help, if you do have creep/uncontrollable boost issues.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 12-24-2013, 12:51 PM   #10
A combination of intake, exhaust and cold temperatures will cause creep. With a big intake, high flowing intercooler and no cat MOST internal gated turbos will creep as temperatures move below 50*F. The same setup could be fine with 80*F temperatures.
So there are many ways to skin the proverbial cat. If you live in a climate that see cold temperatures often and this is a street/daily car, I recommend a high flow cat for IWG turbos as the simplest solution to creep. Yes the BNR will creep as well in lower temps with catless exhaust and open intake. It is not a function of the boost controller as the boost controller can only RAISE boost above the minimum that the turbo can run on spring pressure alone. It is a function of the wastegate not being efficient enough at slowing the turbine down in these conditions. Porting it can be hit and miss if not done properly and I would not do it on the BNR since the exhaust housing is fragile.
atvfreek (12-24-2013), Easter Bunny (12-25-2013), ItsNox (12-24-2013), mituc (12-24-2013), NuminouSpeed (12-24-2013), redboat (12-24-2013)
 Old 12-24-2013, 12:54 PM   #11
3.5" intake. Have FMIC with Treadstone core. Maybe that'll help keep things in check? (More pressure drop that hi-flow TMIC?)
 Old 12-24-2013, 12:57 PM   #12
You can always start out this way and start tuning. If creep is an issue, then adding a high flow cat is relatively easy after the fact. But keep in mind that creep can be an issue especially if boost needs to be limited due to the fuel used to prevent knock.
 Old 12-24-2013, 05:24 PM   #13
Smelson's Avatar
Posts: 2,237   (View Stats)
Smelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the worldSmelson is the leader of the world
Hi Zack.
@Redline143; @Zdraveca;
FreekTune
GT2871r- 402/402
Smelson is offline   Reply With Quote
The Following User Says Thank You to Smelson For This Useful Post:
Zdraveca (12-24-2013)
 Old 12-24-2013, 02:02 PM   #14
redboat's Avatar
Posts: 634   (View Stats)
redboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the world
I was having the same problem on my stock K04 with a large dia intake, and catless 3" DP w/ cut out. My solution was lower WGDC, and increase effectiveness of the OTS BEC table. And I have 2 different tunes. One for warmer months, and another for colder.
**also watch you load values.
redboat is offline   Reply With Quote
The Following User Says Thank You to redboat For This Useful Post:
breakfstincluded (12-24-2013)
 Old 12-24-2013, 02:10 PM   #15
If it's a tune issue this is easy to fix. True creep is not a tuning or WGDC issue. It is when WGDC is at 0 and boost still climbs above what your targets are.
atvfreek likes this.
atvfreek (12-24-2013), Boost_creep (12-24-2013), btstarcher (12-24-2013), ItsNox (12-24-2013), redboat (12-25-2013)
 Old 12-24-2013, 05:29 PM   #16
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Groans: 145
Lol zack you were banned from here for a reason.
OP is @Redline143; @Raider; can we do something about this?
Merry Christmas
Sent from Pu
2011 MS3"Princess GRU"
GT2876r
E85 FREEKTUNE
The Following User Says Thank You to Zdraveca For This Useful Post:
Smelson (12-24-2013)
 Old 12-24-2013, 05:41 PM   #17
Zdraveca's Avatar
Groans: 145
http://www.mazdaspeedforum.org/forum/foru...d.php?t=144826
Sent from Pu
GT2876r
E85 FREEKTUNE
 Old 12-24-2013, 07:26 PM   #18
rolanblack's Avatar
Posts: 2,110   (View Stats)
wut.
 Old 12-24-2013, 07:39 PM   #19
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Check post #39 an interesting way to add some restriction and lose it too.
http://www.mazdaspeedforum.org/forum/for...2-build-87868/
Nator is what it does.
 Old 12-25-2013, 12:37 AM   #20
redboat's Avatar
That's a back yard boost controlled cut out. A lot of VW guys use these or use an E cut out like I have. Only think I don't like about these, is unless you have a bleeder value inside the cabin you can only partially control when it opens or closes since it runs off boost pressure.
But then again, open catless downpipe equals rapid boost spikes. So I rarely use my cut out during the colder months.
That's the definition of a mechanical boost creep, I assumed the OP was talking about a boost creep problem due to the tune and cold weather.
NuminouSpeed (12-25-2013)
 Old 12-25-2013, 08:08 AM   #21
atvfreek's Avatar
OP is talking about uncontrolled mechanical boost creep. Zero wgdc and boost going over 24 psi. It's a customer I'm tuning (realized who the OP was talking about last night) My suggestions were add a cat or port the hotside.
taf0422 likes this.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 6 Users Say Thank You to atvfreek For This Useful Post:
865ms3 (12-25-2013), btstarcher (12-25-2013), ItsNox (12-28-2013), kritz (12-25-2013), redboat (12-26-2013), taf0422 (12-25-2013)
 Old 12-25-2013, 12:40 AM   #22
ash4390's Avatar
Posts: 86   (View Stats)
ash4390 has a reputation beyond reputeash4390 has a reputation beyond reputeash4390 has a reputation beyond reputeash4390 has a reputation beyond reputeash4390 has a reputation beyond reputeash4390 has a reputation beyond reputeash4390 has a reputation beyond reputeash4390 has a reputation beyond reputeash4390 has a reputation beyond reputeash4390 has a reputation beyond reputeash4390 has a reputation beyond repute
I had boost creep issues when tuning with Lex, ended up throwing a cat in my CS 3" TBE... resolved all my problems!
BNR S3 | Stratified Tune | Cobb AP | CS 3" TBE & TMIC | JBR PMM/RMM | JBR RSB | JBR 3" Intake | KW V3 | Rotora BBK | 18x9.5 RPF1
ash4390 is offline   Reply With Quote
The Following User Says Thank You to ash4390 For This Useful Post:
 Old 12-25-2013, 06:35 AM   #23
blackms3_71's Avatar
Posts: 2,250   (View Stats)
Same here.
 Old 12-25-2013, 08:33 AM   #24
865ms3's Avatar
Posts: 2,602   (View Stats)
Porting the hotside on my 3071 worked like a champ....but you already knew that
Edit fyi. I hit 26psi on spring pressure(pucker). After port it held 14-16 to redline.
Brent
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
The Following 2 Users Say Thank You to 865ms3 For This Useful Post:
atvfreek (12-25-2013), Easter Bunny (12-25-2013)
 Old 12-25-2013, 09:40 AM   #25
The older GT turbos had bad creep out of the box and porting these was the way to go. The newer GTX ones are better for this and don't really need it. You have to be a little careful since overporting will cause slow spool and boost drop up top.
On the bnr s3 the oem exhaust housing develops cracks around the wg opening so porting that area can shorten the life of the housing.
atvfreek (12-25-2013), redboat (12-26-2013)
 Old 01-03-2014, 11:54 AM   #26
redboat's Avatar
Question
On a BNR, GT, or even the stock K04 with boost creep issues, what's the better solution for most power, reliability, and consistent stable tune?
1.) Add a high flow cat?
2.) switch to EWG via EX mani, and block/lock OEM IWG arm?
breakfstincluded (01-03-2014)
 Old 12-25-2013, 09:45 AM   #27
Emew's Avatar
Posts: 217   (View Stats)
Pitty my noobness but I run a catless DP with the stock exhaust and I turned WGDC down by 5-10% from OTS values and this put my boost right at the 20 I'm shooting for on the stock turbo. How does one end up with a similar exhaust flow yet even with 0% WGDC have insane boost creep? If I were to run 5% WGDC I'd assume I'd be boosting like..5 PSI lol.
Just looking to learn more, if anyone could explain how this spike happens?
Flow Student
 Old 12-25-2013, 10:09 AM   #28
atvfreek's Avatar
Variances in intake size, intercooler, exhaust, turbo, etc can all make an impact. No two cars are the same
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
Emew (12-25-2013)
 Old 12-25-2013, 12:18 PM   #29
skiptowncat's Avatar
Posts: 1,592   (View Stats)
Variances in intake size, intercooler, exhaust, turbo, etc can all make an impact. No two cars are different.
Don't you mean "no two cars are the same"?
Tuned with by
 Old 12-25-2013, 12:52 PM   #30
atvfreek's Avatar
Yup. Sorry for the typo. Haha. You all get the idea. Bah humbug
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 12-25-2013, 01:11 PM   #31
Blame the Christmas "spirits"
Tuned with by
The Following 2 Users Say Thank You to skiptowncat For This Useful Post:
atvfreek (12-25-2013), btstarcher (12-25-2013)
 Old 12-25-2013, 10:14 AM   #32
btstarcher's Avatar
Because itty bitty turbo?
LOL yeah I'd go with Freek's answer.
Last edited by btstarcher; 12-25-2013 at 10:14 AM. Reason: MSF Database - Automerged Doublepost
 Old 12-25-2013, 10:19 AM   #33
Emew's Avatar
So basically even with a wide open waste gate you're still creating so much exhaust flow that the turbo just puts out that insane boost?
Flow Student
 Old 12-25-2013, 10:48 AM   #34
Yes. On my BNR the wastegate would completely open at 5000 rpms and I was still building boost all the way to the redline.
atvfreek (12-25-2013), Emew (12-25-2013), redboat (12-26-2013)
 Old 12-25-2013, 02:22 PM   #35
redneck4Christ's Avatar
Posts: 1,803   (View Stats)
Here is an ignorant question. Could the tune be set up to reduce throttle position when boost exceeds a certain amount? In my pea brain that would seem to give enough flow restriction to help? Or are there other problems with this method?
 Old 12-25-2013, 02:44 PM   #36
btstarcher's Avatar
I'm no tuner, but I believe that by decreasing throttle position you would also affect many other parameters, such as spark advance, AFR, load, etc. Especially if it drops out of open loop.
 Old 03-25-2014, 09:44 AM   #37
thuglife2334's Avatar
Posts: 117   (View Stats)
thuglife2334 has much to be proud ofthuglife2334 has much to be proud ofthuglife2334 has much to be proud ofthuglife2334 has much to be proud ofthuglife2334 has much to be proud ofthuglife2334 has much to be proud ofthuglife2334 has much to be proud ofthuglife2334 has much to be proud ofthuglife2334 has much to be proud ofthuglife2334 has much to be proud of
i was going back and forth about getting a cat for my CS tbe... after reading all this. i dont even wanna deal with boost creep so ... catted DP it is!!
thuglife2334 is offline   Reply With Quote
 Old 04-02-2014, 05:37 PM   #38
Weathers warmed up a bit here, no more creep!!
Tuned with by
The Following User Says Thank You to skiptowncat For This Useful Post:
redboat (04-04-2014)
GTX3071R boost creep/boost spike! Need help! MS3 Ventura MazdaSpeed 3/6 - Big Turbo Builds 20 05-11-2013 11:44 AM
Boost Creep? Silver Ecstasy MazdaSpeed 3 - Engine, Transmission & Driveline 17 02-14-2012 04:28 PM
Boost creep? psmith22 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 07-24-2011 11:47 PM
Boost creep? DubVms3 MazdaSpeed 3/6 - Turbo Induction 4 03-11-2011 04:12 AM
Boost Creep RocketScientist MazdaSpeed 3/6 - Turbo Induction 3 08-02-2010 11:13 AM
Page generated in 0.59970 seconds with 37 queries
