  • 1 Post By Vansquish
 Old 01-25-2016, 05:07 AM   #1
G3nwonMazdaratti's Avatar
Posts: 12   (View Stats)
G3nwonMazdaratti is an unknown quantity at this point
Default Engine Over Boost Condition
Hey guys, so i have a 2007 ms3. Currently on my 91 tune, the car is making 22lbs of boost. The other day I was driving and i hit 25lbs of boost and felt a hard power cut and my check engine light turned on. My accessport said that my had gone into Engine Overboost Condition, and now when i accelerate, my car will not boost properly, and i can't even hit 18lbs until 6,000 rpms. I had gone through and check all the clamps and piping for my fmic and i followed and made sure every vacuum line from my grimmspeed ebcs, and made sure every line was properly hooked up. I also emptied both catch cans, and completely cleaned them out and I reflashed my Tune. I was wondering if maybe I should do a smoke test and see if I can find a vacuum leak that way. Or it could possibly be a wastegate issue. The turbo is a BNR S3 with 20k miles on it, and i am pretty much stumped on how to address this problem. Any thoughts or comments are welcome, because at this point anything will help!!
G3nwonMazdaratti is offline   Reply With Quote
 Old 01-25-2016, 05:52 AM   #2
Police - Grammarhead
Vansquish's Avatar
Sounds like you should contact your tuner.
@atvfreek;
blackms3_71 likes this.
The Following 5 Users Say Thank You to Vansquish For This Useful Post:
G3nwonMazdaratti (01-25-2016), littleloogy (01-25-2016), MS3Shadow (01-25-2016), rymanmazda (01-25-2016), WetzMS3 (01-25-2016)
P0234 Engine Overboost Condition after BNR S3 install MD1032 2010 MS3 - Troubleshoot/Diagnostics 24 12-18-2015 09:02 PM
New Engine, Low Boost, P2187 Cool1Net6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 02-28-2015 10:03 PM
noise with boost/load, only with cold engine btstarcher MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 11-25-2013 03:40 AM
Something wrong with boost and engine mj_ball23 2010 MS3 - Troubleshoot/Diagnostics 5 01-29-2012 08:34 PM
lean condition under boost Super Unique Mazdaspeed3/6 General Discussion 13 06-15-2008 11:02 PM
Page generated in 0.23578 seconds with 21 queries
