 Old 06-01-2010, 02:49 PM   #1
02stang951's Avatar
Posts: 250   (View Stats)
02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future02stang951 has a brilliant future
Default ETS TMIC vs cobb accessport
ok so im looking for the next mod on my car all i want to know is what one to buy, and if they have equal gains and reliability i was goin to buy the accessport then found a new tmic would also help a lot all i currently have done engine wise is cobb sri
thanks
08.5 true red gt, 35/20% tint, resonators deleted, Tenzo R type M's,Cobb SRI, Hypertech tuned, MSD Dashhawk, SU test pipe, AWR RMM, BC coilovers, Turbosmart duel port bov
02stang951 is offline   Reply With Quote
 Old 06-01-2010, 03:49 PM   #2
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
tagged for punctuation.
 Old 06-01-2010, 03:52 PM   #3
mike8748's Avatar
Posts: 396   (View Stats)
mike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the world
The ETS is nice, I had it for a short time but then sold it and purchased a COBB AP.
I then later got a FMIC.
Check out the CX-Racing FMIC, its about the same price as a new ETS Top mount.
07'MazdaSpeed3 Stage2+SF 93 FMIC Custom Map
Current Mods: COBB AP, COBB SRI, COBB Inlet, COBB Cold Air Box, COBB Shift Weight, COBB STS, COBB PCV Catch Can, COBB Rear Sway Bar, M3M FMIC, TWM Shifter Bushings, FORGE BPV, Nator Rear MM, TurboXS DP, TurboXS RP, TB BYPASS MOD, MSD Dash Hawk, Denso 2-Step Colder plugs, Eibach Springs, BSD, KMD ver2 internals, EGR delete, PTP intake cooler kit, CNT Racing CBE, PG Exhaust Manifold
mike8748 is offline   Reply With Quote
 Old 06-01-2010, 03:56 PM   #4
yearzero's Avatar
Posts: 439   (View Stats)
yearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the worldyearzero is the leader of the world
AP first IMO. it allows you to properly tune for each new mod.
Cobb SRI - CXRacing FMIC - NGK 1step colder - DashHawk - Cobb AP Stage2 + ATR - SU RMM - PTP IM Gasket - CP-E catless downpipe
yearzero is offline   Reply With Quote
 Old 06-01-2010, 11:24 PM   #5
02stang951's Avatar
true but i only plan on doing the intake and one or the other this is my DD so im keeping it simple just want to hit at least 260whp and ill be happy and i need to be reliable
 Old 06-02-2010, 01:58 AM   #6
Big_Burd's Avatar
Posts: 831   (View Stats)
Big_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the worldBig_Burd is the leader of the world
Groans: 118
I'm in the same boat your in, all I have is an HKS intake, I'm trying to decide whether to go with a FMIC or AP and I'm going with an AP because you can get rid of that stupid turbo cut out at 5800rpm and you also get more out of your mods when you run an AP as well, but I'm not sure if a tune is as much of a "must" with a TMIC as with an FMIC but someone let me know if I'm wrong...
Big_Burd is offline   Reply With Quote
 Old 06-02-2010, 09:44 AM   #7
02stang951's Avatar
thats true which is why if i planed on doing more mods i would get the AP but with im only doing 2 power mods
 Old 06-02-2010, 02:31 PM   #8
Big_Burd's Avatar
Groans: 118
Yeah, if you don't plan on upgrading past your next mod i would go with the TMIC, if you're narrowing it down between the AP and TMIC. That being said I would go with an Inlet and RMM instead, you'll see substatntial differences, and spend less money. That's just my 2 cents tho..
 Old 06-02-2010, 03:12 PM   #9
TRex's Avatar
Posts: 3,139   (View Stats)
i am at the same point as you...the only thing holding me back from jumping on the AP is that im not too keen on OTS maps...i feel your tuning solution should be specific for the car...however...you can use OTS maps as a starting point and tune from there
 Old 06-02-2010, 03:16 PM   #10
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
you should do the VIP mod
it's fun to do bad things
yearzero (06-02-2010)
 Old 06-02-2010, 03:16 PM   #11
turbospeed's Avatar
Posts: 113   (View Stats)
turbospeed has a spectacular aura aboutturbospeed has a spectacular aura aboutturbospeed has a spectacular aura about
thanks
I have a SU tmic very very similar to ETS just a bit shinier, looking to sell it cheap just to get rid of it with blue boost tubes if your interested. I just ordered a fmic. Let me know if your interested, gains are pretty impressive with it and looks really good as well.
turbospeed is offline   Reply With Quote
 Old 06-02-2010, 03:55 PM   #12
volodya84's Avatar
Posts: 1,552   (View Stats)
volodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the world
Groans: 42
how much?
Corksport TMIC // Denso ITV22s .028" // COBB SRI // Corksport TIP // Forge V1 BPV // COBB AP // JBR SSP // TWM Bushings // Prosport Boost Gauge // CS Interior LED kit
"ban post whoring brownies"
Forge v1
volodya84 is offline   Reply With Quote
 Old 06-02-2010, 09:48 PM   #13
turbospeed's Avatar
Originally Posted by volodya84 View Post
how much?
How does 250 can sound. Expecting fmic by mid next week
how much?
Shipping extra I'm in Alberta , Canada. If your interested I can see how much shipping is
Last edited by turbospeed; 06-02-2010 at 09:48 PM. Reason: MSF Database - Automerged Doublepost
 Old 06-03-2010, 10:31 AM   #14
turbospeed's Avatar
Hi TRex, I'm having some issues sending you those pics, I can't even reply to your message because i have'nt posted enough or something. Could you send me your email directly?
 Old 06-03-2010, 10:50 AM   #15
volodya84's Avatar
Groans: 42
Sterling, VA, 20164 - how much will shipping be?
Forge v1
 Old 06-03-2010, 07:02 PM   #16
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
Not sure about the TMIC or AP, but the chic in your avator looks yummy.
J/k... I'd go with the TMIC. You'll get about 20whp from it and it's a good mod if you're not going to go too crazy.
Frequentflyer is offline   Reply With Quote
 Old 06-04-2010, 12:00 AM   #17
02stang951's Avatar
that would be Megan fox lol
 Old 06-04-2010, 12:52 AM   #18
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
I have a SU TMIC, Cobb SRI, Cobb Inlet and SU Boost tubes and making 262WHP to the wheels on stock ECU. However, with an AP or anything else alike you can get to tune the ECU you can get slightly more from a 100% stock car with a lot less money, and as long as you don't abuse it won't blow or make any problems because of the stock/poor air cooling.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 06-04-2010, 01:15 AM   #19
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
id say, go FMIC or TMIC first then get AP.
i like the gains of FMIC/TMIC vs my mods no fmic and AP.
when i had stock TMIC and got rid of my AP, the car felt slow. bought the AP again but had FMIC installed by then but sold the Ap, once again, and i have been very satisfied with the stock tune and FMIC. havent thought about getting another AP since.
but the car feels faster with FMIC and stock tune compared to AP and stock tmic. having an AP, running higher boost and no upgrade IC is going to heatsoak the OEM TMIC quicker which means high bats and less power.
oh, FMIC>>>>>>>>>>>>>>>>>aftermarket TMIC
2015 Mazda 6
Cobb Accessport...... mazda3nyturbo MazdaSpeed 3/6 - ECU Computer Tuning 11 04-25-2012 08:00 AM
Page generated in 0.41961 seconds with 31 queries
