  • 1 Post By Code Monkey
 Old 11-09-2015, 07:44 PM   #1
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Default EWG not hitting boost targets
I've noticed that sometimes when I try to transition from an part throttle dump (say at 16psi, 15psi is spring pressure) to WOT the car will stay at 16psi all the way to redline when it should've been at 20psi until I let off and hit it again.
Anyone else have this problem? Is this just inherent with EWG's? Or is something a miss?
 Old 01-20-2016, 07:31 PM   #2
Cheapspeed's Avatar
I'm bumping this.
I've changed my driving habits so that if I'm in part boost, and want to go WOT I'll quick let off and floor it to ensure I'll hit peak boost. Could anybody else tag someone with an EWG to chime in?
Also feels like building boost then letting off quickly lends to some bucking and sounds like faint turbo flutter. I read in some posts that low boost flutter isn't a big deal and most efforts to eliminate it (cleaning/lubing) didn't do much. Just want to know if there's anything I can do to stop it or at least smooth out the bucking.
I have a gtx3076r with the EWG hotside with a tial 38mm wastegate, stratified 3 port, and go fast bits bypass valve in full recirc.
Maybe @Lex; @Justin@Freektune; ?
@Code Monkey; @Enki; @Dano; @Tomas; @Voltwings;
 Old 01-20-2016, 07:55 PM   #3
No experience with EWG, but is it recent or has it always been like that? I think there are like 2 or 3 different ways to setup the EWG, maybe try a different configuration?
 Old 01-20-2016, 08:07 PM   #4
Cheapspeed's Avatar
It's always been like that since it was installed. Initially I didn't notice it because I was simply going WOT everywhere when it was installed, but building slowly on the on-ramp trying to transition to full boost that never came has put me in a precarious spot once or twice.
Code Monkey (01-20-2016)
 Old 01-20-2016, 08:11 PM   #5
I hope it is a glitch of some sort, as I have plans for an EWG....
 Old 01-20-2016, 08:19 PM   #6
Cheapspeed's Avatar
I'm pretty sure I hooked it up like this:
I'd have to go back under and look.
 Old 01-20-2016, 09:55 PM   #7
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
This doesn't quite look right to me...
If you hook it up like this, it's going to dump pressure from the top of the WG first, which is going to reduce boost pressure... If you're at a low WGDC, it may not be enough to bleed from the bottom AND the boost source as well.
If you really want to use both ports on the wastegate, I'd suggest a 4 port EBCS.
Cheapspeed (01-21-2016), Easter Bunny (01-21-2016), Mazdazilla6 (01-20-2016), MS3Shadow (01-20-2016)
 Old 01-20-2016, 08:27 PM   #8
I have this routing in my fail thread, but also this routing as well....
 Old 01-20-2016, 08:29 PM   #9
Cheapspeed's Avatar
I read on a subbie forum that for the fastest response to use the T fitting. But I have seen your VTA version as well. Need to do more research I guess.
 Old 01-20-2016, 08:36 PM   #10
Enki's Avatar
Confirm EBCS config (preferably), provide log of working and non working and map (preferably).
Code Monkey (01-20-2016), Easter Bunny (01-21-2016), ItsNox (01-27-2016)
 Old 01-20-2016, 08:37 PM   #11
Cheapspeed's Avatar
Actually I know I'm using the top port of the EWG because I have a T fitting. No other setup uses the T.
I'll grab logs tomorrow morning.
 Old 01-20-2016, 09:25 PM   #12
Who is your tuner?
Edit: Nevermind, just read your sig. I was going to point to something similar I experienced but it was in the tune.
 Old 01-20-2016, 10:07 PM   #13
IIRC mine is hooked up left side to comp housing, middle to intake and right side to bottom port.
Edit: Actually center is comp housing, left is bottom port on ewg and right is to my intake.
The Following 3 Users Say Thank You to Mazdazilla6 For This Useful Post:
Cheapspeed (01-21-2016), Easter Bunny (01-21-2016), Enki (01-20-2016)
 Old 01-20-2016, 10:29 PM   #14
Enki's Avatar
To clarify:
If middle is normally closed, you should have a hard time exceeding spring pressure unless your exhaust setup flows like crazy (low pressure against the wastegate valve) and your EBCS flows like crazy too.
Nothing on top port, right?
 Old 01-20-2016, 10:44 PM   #15
Nada
OP what spring do you have in the wastegate?
This is from Lex in my build thread:
For the boost control solenoid setup remember the following.
When the solenoid is not energized ports 2 and 3 connected. Port 1 holds whatever pressure has been built up behind it.
When the solenoid IS energized ports 2 and 1 are connected. Port 3 holds whatever pressure has been built up behind it.
So in the diagram above with a dual port wastegate, when you increased WGDC you will start adding pressure to the top of the diaphragm to keep it closed. The port 1 and 3 when not connected to port 2 are sealed. This means that you will keep building pressure on both sides of the diaphragm.
This allows you to run a very small pressure differential across the diaphragm and therefore a very light spring. If you go with a heavy spring you might have an issue with controlling boost.
This picture in reference was this (looking at the front of the solenoid left to right the ports are 2 3 1):
 Old 01-21-2016, 05:29 AM   #16
Justin@Freektune's Avatar
Posts: 954   (View Stats)
Where is your boost source coming from for the ewg.
Is it coming from a quick tap in the intercooler hot pipe? Or are you tapped off your bov hose?
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
Voltwings (01-21-2016)
 Old 01-21-2016, 04:17 PM   #17
Cheapspeed's Avatar
It's on the quick tap coming off the hot pipe.
As it is, my
P1 goes to my Hotpipe, T, and bottom port on the EWG.
P2 goes to top port, but the side top port because when I post the pictures you'll see the top port is blocked.
P3 goes to my intake.
I'll post logs a little later this evening. Spring pressure is set to 15psi.
 Old 01-21-2016, 04:40 PM   #18
As it is, my
According to the picture you posted you have port 1 and 2 switched. Unless my dyslexia is making me read it wrong.
 Old 01-21-2016, 07:02 PM   #19
Cheapspeed's Avatar
You think I should switch them?
Would there be any danger if that's not correct?
 Old 01-21-2016, 07:18 PM   #20
Well the way you have it set up right now, when the solenoid isn't energized you're pulling a vacuum on top of the diaphragm. This is bad because it will reduce the pressure that the spring is pushing down on the valve with. Then when the solenoid is energized, you're putting boost on both sides of the diaphragm, essentially making it run on spring pressure.
I would recommend to set it up according to the picture that you posted or the routing that I have.
 Old 01-22-2016, 05:04 PM   #21
Boost_creep's Avatar
Posts: 829   (View Stats)
As it is, my
According to the attached Stratified directions, your routing is incorrect. But as Mazdazilla mentioned, I would consult with your tuner.
Interesting you blew your dipstick with one high boost pull. Are you running any sort of crankcase mods, like vented cap, vented can, perm plate, etc?
The Following User Says Thank You to Boost_creep For This Useful Post:
Mazdazilla6 (01-22-2016)
 Old 01-22-2016, 05:57 PM   #22
Cheapspeed's Avatar
No crankcase mods, I only ever see 21psi at the most and it's never been an issue.
By the way, did some logs, and my car is really down on power by about 30whp. I'm barely breaking 300whp. Car is running really rich too. I'm gonna e-mail Freak cause something isn't right (amongst other things). My AFR's at WOT are in going as low as 10.14.
 Old 01-21-2016, 04:18 PM   #23
Cheapspeed's Avatar
uploadfromtaptalk1453418273456.jpguploadfromtaptalk1453418282178.jpguploadfromtaptalk1453418288327.jpg
 Old 01-21-2016, 07:05 PM   #24
It's a Mazdaspeed, what could possibly go wrong.
Cheapspeed likes this.
Mazdazilla6 (01-21-2016)
 Old 01-21-2016, 08:01 PM   #25
Cheapspeed's Avatar
Okay, so that was bad. Swapped P1 and P2. Warmed the car up, slowly went into boost on the on ramp. Let off, then built boost again, decided to floor it. Car hit 30.22psi of boost and 140%IDC.
Babied it home and swapped lines back to original positions. I took several logs trying to replicate the condition (which I believe I did) but I have to sort through all the logs to find them.
Code Monkey (01-21-2016)
 Old 01-21-2016, 08:13 PM   #26
Do you know what kind of wgdc you are commanding? Were you tuned with the lines setup like this?
If you set it up according to the photo you posted earlier then I'm guessing your tune is commanding some high duty cycle and with the setup in the picture you need to command a lower duty cycle.
 Old 01-21-2016, 08:19 PM   #27
Cheapspeed's Avatar
@Justin@Freektune; would know better than I.
Here are the logs. I posted the overboost after I straight swapped P1 and P2. Then there is the roll into boost that falls short of full boost (I gradually depress the pedal staying in high load), and then there's full boost where I floor it, usually hitting 18-19+psi in this cold weather. Hot weather will bring me up to 20-21psi.
 Old 01-21-2016, 08:27 PM   #28
Okay you're not running very high wgdc according to the full boost log. Something seems very wrong though. On the overboost log you're not really overboosting until there's any wgdc. On the full boost log you have what I would consider a normal wgdc ramp. And then on the underboost/roll into it log you have 0 wgdc all the way down, so it's just on spring pressure.
Possibly something faulty with the boost controller?
Edit: To be clear, I feel guilty for the overboost situation. Swapping lines around like that is definitely something you should consult with your tuner about. Routing lines wrong or in a fashion that doesn't work with the tune can blow an engine.
 Old 01-22-2016, 03:54 PM   #29
Cheapspeed's Avatar
So apparently 30+psi will blow out my dipstick. Didn't notice it last night in the dark. Oil everywhere. Glad the pressure didn't blow my block. Gonna take some logs at my normal logging spot to see if there's any noticeable change in performance.
Code Monkey (01-22-2016)
 Old 01-22-2016, 05:17 PM   #30
England15j's Avatar
Posts: 1,910   (View Stats)
Same thing happened to me at 30psi. Switched to a vented oil fill cap and VTA OCC and never happened again.
On the ewg I have mine routed like this and it's perfect.
The Following 3 Users Say Thank You to England15j For This Useful Post:
Boost_creep (01-22-2016), Cheapspeed (01-22-2016), Mazdazilla6 (01-22-2016)
 Old 01-22-2016, 04:24 PM   #31
Enki's Avatar
Lol.
 Old 01-22-2016, 06:08 PM   #32
Enki's Avatar
Crancase evac will cause you to lose that much power, or more.
 Old 01-22-2016, 06:21 PM   #33
Cheapspeed's Avatar
I bought a touch-up from Justin and will just baby the car in the meantime. Not hard staying out of boost on the 3076. I need to get a beater so I can let the car sit for a while. I've beat the shit out of this thing and it still reliably gets me to work. It's pretty amazing.
 Old 01-23-2016, 01:19 PM   #34
Cheapspeed's Avatar
Blew the dipstick out again doing the logs I sent to Freek. Hose at the TB was pushed back. Fixed that, and checked my plugs (they looked pretty good).
Did 2 logs again, still running 10 AFR's at WOT but no dipstick blowout.
I looked at my old logs on this revision if anything I was running leaner then. He gave me a blind fix to my IDC issue where I was hit 107% IDC if not higher and the car stuttered (as in he didn't view any logs for it).
Here' one of those old logs, and here the ones I just took, same map.
 Old 01-25-2016, 08:33 PM   #35
Cheapspeed's Avatar
Here's logs from this afternoon that I sent to Justin. Still rich AFRs, but power isn't abnormal for 65*ambients and up to 117*bats after 3 back to back pulls.
 Old 01-29-2016, 01:46 PM   #36
Cheapspeed's Avatar
Quick update. Rerouted all my lines as @Mazdazilla6; and Justin said to. Also remade another gasket for the bpv, double checked all fitting and boost tubes. Haven't done a boost leak check yet because I'll have to borrow compressor and gauge from somebody.
So I've still managed to replicate the issue where part throttle boost won't translate to full boost at WOT, still annoying but tolerable. However I did take another set of logs and they're looking decent again, WOT AFR's look good. Car doesn't act noticeably different from my previous hose routing but I'm glad it's fixed anyway.
Car was struggling to hit 100% IDC and it's a little down on power. It's been a while since I've driven in weather this warm, but I don't recall having difficulty maxing out the injectors before. Maybe the tune needs to be adjusted now?
I have a pre-ebcs log and post-ebcs fix log to compare, similar boost temps.
Mazdazilla6 (01-29-2016)
 Old 03-06-2016, 10:11 AM   #37
Cheapspeed's Avatar
Looks like the car is doing much better now. Freek adjusted some boostload tables post EBCS vac line fix. The dark green and red are the new logs. I posted one the green log if anybody wants to look and give me some feedback.
boost tuning, not hitting easy boost targets? Caldazar MazdaSpeed 3/6 - ECU Computer Tuning 11 05-18-2012 06:09 PM
Not hitting Stage 2 boost targets (boost leak?) Bubba Ho-Tep 2010 MS3 - ECU Computer Tuning 15 04-26-2012 08:25 PM
not hitting boost targets exentix MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 04-13-2012 05:57 PM
Not hitting boost targets jvella22 Mazdaspeed3/6 General Discussion 2 04-08-2012 08:26 PM
Not hitting boost targets again (AP).. dsmluck MazdaSpeed 3/6 - ECU Computer Tuning 28 08-01-2011 05:35 PM
Page generated in 0.58087 seconds with 27 queries
