(Thread Starter) | Not Ranked : 0 score I think the following criteria should be included; Turbo type: [GT30xx or ATP GT30xx, GTX30xx, etc] Restrictor used: [no restrictor, .035, .040 etc] Failure Mode: [CHRA bearing falure, hotside cracking, etc.] Oil feed line used: [OE, ATP, other] Oil return line used and if modified for length. Vendor Purchased from: Answer/resolution from vendor or manufacturer: Symptoms: [cloud of smoke out of the back + no boost, etc.] Turbo mileage: Turbo failure after blown motor: [yes/no] I think that's about it unless anyone has other ideas of what would be useful. @chimmike @BlueStreak @crazyp and any others
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 09-06-2012 at 08:54 PM. |
| The Following 12 Users Say Thank You to Dano For This Useful Post: | atvfreek (09-06-2012), BlueStreak (09-06-2012), Easter Bunny (09-06-2012), ganque (09-10-2012), GLORIFIEDBOZO (09-15-2012), helmetface (09-06-2012), jack_hammer (09-06-2012), Micha (05-09-2013), TiGraySpeed6 (09-07-2012), TWOptSL0W (09-07-2012), uncorked11 (09-10-2012), Ziggo (09-07-2012) |
![]() Join Date: Dec 2010 Location: Albuquerque, NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,614
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score Here is my wall of frustration... Turbo type: GTX3076 Restrictor used: Told by ATP that no restrictor was needed on new GTX series. Failure Mode: Two time Seal failure. First time had metal bur left inside CHRA housing that caused rubbing and excessive heat. Defective Oil Return line sent from ATP. Oil feed line used: OE Feed line. Oil return line used and if modified for length. Original install had Oil Feed line used supplied by ATP. Now running custom line supplied by ATP that is 1in shorter in length. Vendor Purchased from: Edge AutoSports Answer/resolution from vendor or manufacturer: First time ATP rebuilt entire CHRA housing. Still waiting on resolution for second issue. Symptoms: Oil blow back through Compressor housing. Oil in Intercooler, Intake and Throttle Body. Massive "Spy Hunter" smokescreen from tail pipe. Turbo mileage: About 5k on original install, 1.5k on second failure. Turbo failure after blown motor: No Blown Motor Here are some pics of the bur in the CHRA housing and of the defective Oil Return line sent to me by ATP.
__________________ 2009 MazdaSpeed 3 Spy Hunter Smoke Screen Mod Cobb AP (Custom Tune), ATP GTX3076 28PSi, CP Forged Pistons .020 Over, Pauter Forged Rods, Bore and Hone Block .020 Over, CP-E DISI Injector Seals, ARP Head Studs, MZR Cometic Head Gasket, ACT Stage 2 Heavy Duty Clutch,Cobb SRI Intake, JBR TIG, JBR TB Gasket, JBR 88 Duro Transmission Mount, JBR EGR Delete , JBR TB Coolant Bypass, CP-E Big Turbo TIP, KMD HPFP Internals, Street Unit TurboSmart Dual Port BOV, CorkSport TMIC, CorkSport DP, CorkSport Test Pipe, CorkSport CBE, CPE Single Guage Pod, DashHawk, Prosport Boost Gauge, Devils Own Progressive Methanol Injection Kit 80/20 with D07 Nozzle, E85 Tune 50/50, JBR DogBone 88 Duro Rear Motor Mount, CorkSport Mid Chassis Brace, JBR Stage 2 Short Shift Plate, H&R Springs, 18x8 Drag DR38 +47, Eibach 5mm Spacers, 235/40 18 Brisgestone RE760. Last edited by RayRay; 09-06-2012 at 10:31 PM. |
![]() Join Date: Jun 2010 Location: corpus christ, tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,316
Groans: 68
| Not Ranked : 0 score Turbo type: T3 GT3071 Restrictor used: .035 Failure Mode: CHRA bearing failure Oil feed line used: custom ATP steel braided line Oil return line used : Custom ATP steel Braided line Vendor Purchased from: bought used forum user Answer/resolution from vendor or manufacturer: Symptoms: no boost , mileage unknown and boosted up to 24 psi Turbo type: T3 GTX3076 Restrictor used: .035, Failure Mode: no failure as of yet Oil feed line used: custom ATP steel braided line Oil return line used : Custom ATP steel Braided line. Vendor Purchased from: Edgeautosport Answer/resolution from vendor or manufacturer: Symptoms:working fine so far, bought november 2011 boosted up to 27 psi
__________________ 2006 MS6 -GTX3076 .82 AR-Steedspeed Topmount mani-DJ/PERM Top mount Kit with PERM tune-CXracing FMIC-Tial .44mm WG - KMD Internals- Sure RDM, Turbine tech FDM and FMM=JBR trilogy MM- Whiteline rear sway- eibach prosport springs-jbarone SSP-COBB AP-ACT 6PUCK- ITV22-Prosport Spin On Conversion-Snow Performance stg 2 Meth-CPE Injector seals-Matt Damon OCC |
![]() Join Date: Sep 2008 Location: Toronto, Ontario, Canada
Rep Power: 2202 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,767
| Not Ranked : 0 score Turbo type: GT3071R /w ATP IWG Mileage: 30K KMs Restrictor used: None Failure Mode: Bearing failure. Shaft play in all directions. Damaged compressor wheel. Oil feed line used: OEM Oil return line used and if modified for length: ATP oil return line. Not modified. Vendor Purchased from: StreetUnit Answer/resolution from vendor or manufacturer: Haven't sent it out yet. Symptoms: Zero positive manifold pressure. Smokescreen out the exhaust. I added mileage in there. Figured it would be a good parameter to list.
__________________ '07 CWP MS3 Forged. |
![]() Join Date: Jun 2009 Location: Old Bridge, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,044
Groans: 125
| Not Ranked : 0 score did your turbos blow after a blown motor, or just all by themselves? |
| The Following User Says Thank You to TWOptSL0W For This Useful Post: | Dano (09-06-2012) |
(Thread Starter) | Not Ranked : 0 score From rayray pending more details
Tappin
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | |
| The Following User Says Thank You to Dano For This Useful Post: | RayRay (09-06-2012) |
| Not Ranked : 0 score Updated my post with all important details!!
__________________ 2009 MazdaSpeed 3 Spy Hunter Smoke Screen Mod Cobb AP (Custom Tune), ATP GTX3076 28PSi, CP Forged Pistons .020 Over, Pauter Forged Rods, Bore and Hone Block .020 Over, CP-E DISI Injector Seals, ARP Head Studs, MZR Cometic Head Gasket, ACT Stage 2 Heavy Duty Clutch,Cobb SRI Intake, JBR TIG, JBR TB Gasket, JBR 88 Duro Transmission Mount, JBR EGR Delete , JBR TB Coolant Bypass, CP-E Big Turbo TIP, KMD HPFP Internals, Street Unit TurboSmart Dual Port BOV, CorkSport TMIC, CorkSport DP, CorkSport Test Pipe, CorkSport CBE, CPE Single Guage Pod, DashHawk, Prosport Boost Gauge, Devils Own Progressive Methanol Injection Kit 80/20 with D07 Nozzle, E85 Tune 50/50, JBR DogBone 88 Duro Rear Motor Mount, CorkSport Mid Chassis Brace, JBR Stage 2 Short Shift Plate, H&R Springs, 18x8 Drag DR38 +47, Eibach 5mm Spacers, 235/40 18 Brisgestone RE760. |
Groans: 433
| Not Ranked : 0 score Turbo type: GTX3076R Restrictor used: No, stock oil line via ATP fittings Failure Mode: 'clog' in oil feed inside turbo, bearings failed. Oil feed line used: OE via ATP fittings Oil return line used and if modified for length: ATP, not modified Vendor Purchased from: StreetUnit Answer/resolution from vendor or manufacturer: "user-induced error" Symptoms: No boost, metallic whirring Turbo mileage: 15k Turbo failure after blown motor: NO
| The Following 2 Users Say Thank You to Chimmike For This Useful Post: | Easter Bunny (09-07-2012), rfinkle2 (09-07-2012) |
| Not Ranked : 0 score @SPEED6 KILLAH.. You made mention of seeing this more than once. Could you tag the owners of the turbos in this thread when you have a chance? |
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
Ms3ko he owned an t3 gt3071 turbo blew post zzb Twoptslow atp gt 3076 turbo blew post zzb If you blow you're motor there is a big change for the contaminated oil to take out your turbo, this is why he recommended the oil feed filter. | |
| The Following 13 Users Say Thank You to NJSPEED3 For This Useful Post: | atvfreek (09-07-2012), Chimmike (09-07-2012), Dano (09-07-2012), doubleflusher (09-07-2012), Easter Bunny (09-07-2012), JTMS3 (09-07-2012), Micha (05-09-2013), rfinkle2 (09-07-2012), Rokusek (09-10-2012), SPEED6 KILLAH (09-07-2012), TiGraySpeed6 (09-07-2012), TWOptSL0W (09-07-2012), uncorked11 (09-10-2012) |
(Thread Starter) | Not Ranked : 0 score now we're startin to get somewhere. Ziggo made an interesting observation in chimmike's thread about the in-line filter, in that it can be a blessing or a curse. if you don't monitor it and keep it clean of debris it will be the cause of your failure. It will likely never get anything in there unless you do lose a motor but as Pablo said you have to check it religiously. From your data it would seem that if you do blow the motor you WILL blow the turbo as well..
| The Following 3 Users Say Thank You to Dano For This Useful Post: |
Groans: 113
| The Following 2 Users Say Thank You to NJSPEED3 For This Useful Post: | rfinkle2 (09-07-2012), SPEED6 KILLAH (09-07-2012) |
Groans: 433
| Not Ranked : 0 score Yeah, definitely did NOT pop the motor on this end, lol. OEM pistons/rods completely intact, hg intact, etc.
| The Following 6 Users Say Thank You to Chimmike For This Useful Post: | doubleflusher (09-07-2012), helmetface (09-07-2012), NJSPEED3 (09-07-2012), rfinkle2 (09-07-2012), Rokusek (09-10-2012), SPEED6 KILLAH (09-07-2012) |
(Thread Starter) | Not Ranked : 0 score My immediate plan is to not change my setup. Namely no restrictor or filter until some data can be gathered. IMO a guy should install a pressure gauge in the feed line and measure actual pressure at higher RPMs then compare to Garrett's recommended pressure and install the correct size restrictor if needed. It could very well be that we are over oiling the GTs but really have no idea by how much. So ATP is erring on the side of caution and so will I. Maybe when I install my GTX I'll throw a gauge on there and see what's what. Tappin
(Thread Starter) | Not Ranked : 0 score pertinent info from the other thread
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 | ||
Groans: 433
| Not Ranked : 0 score ATP told me specific to the MZR disi a restrictor is not needed. This is why they use the OEM feed without a restrictor. ATP also tells me you cannot "over oil" a turbo, but oil can leak by the seals, at which point a properly sized restrictor will stop the leaking. They say the seals are not rubber and do not "go out", that it's usually another problem. Just repeating what I'm told, that's all. I would be willing to believe we're not over-oiling them if we're not getting smoke/oil leak past the seals, though.
| The Following 2 Users Say Thank You to Chimmike For This Useful Post: | Black Metal (09-07-2012), Dano (09-07-2012) |
(Thread Starter) | Not Ranked : 0 score I understand completely and am in the "no restrictor" camp. I was putting that information up for the restrictor guys. a blanket statement like "all BB turbos on all platforms need a restrictor" is BS until proven otherwise IMO. not hating on the guys that are running them but perhaps ATP knows something we don't in that our motor runs 45PSI in the feed line..enough to feed the bearings. it sounds like Garrett only wants a restrictor to get you to the 40-45PSI oil pressure in the CHRA...but I can't say that for sure...just going off the statement on their site. so if pressure is higher a smaller orifice will only make it more right? so perhaps they are indicating they want a restrictor in there to INCREASE pressure if you don't have enough.
Groans: 433
They apparently tested the oil pressure in the feed line to determine this data. Doesn't change the fact that these failures are "mysterious" at best, and I'm not sure exactly who is at fault the most; ATP or Garrett or both
__________________ 07 MS3 The original Genpoo Hater PTE 5862cea ball bearing, plus some built stuff. Turismo Vids - Store your car vids and pics here! Blog your builds too! Click here for great deals at The RPM Store! PM me for pricing! I hear that honkey at Protégé Garage is pretty decent too. | |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score right. we are covering two different topics here...lol I don't think your failure mode has anything to do with running or not running a restrictor. the other thing I am trying to put to rest is do we need one or not? lol it may always be a matter of opinion. If I put a gauge on mine and wide open it reads 40-45PSE I will feel confident no restrictor is needed. but if you are flowing too much oil IDK how to solve that...if you put in a restrictor you up the pressure correct? Then you are beyond spec for pressure but running correct volume. catch 22 and prob why ATP says leave it alone unless you blow out smoke/seals. edit: I am wrong according to @Lex so there you have it. restrictor apparently does not increase pressure...I was thinking of the gargen hose analogy...put finger over part of it and the pressrue goes up and volume decreases...still don't understand why that is not the case but it doesn't matter...lol
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 09-07-2012 at 12:15 PM. |
![]() | | #20 | ![]() |
Groans: 433
| Not Ranked : 0 score Your question was answered in my other thread as you know. restrictor reduces pressure/flow.
![]() | | #21 | ![]() |
(Thread Starter) | Not Ranked : 0 score haha I love being wrong...I am getting dizzy and must take a break from MSF for awhile....
![]() | | #22 | ![]() |
![]() | | #23 | ![]() |
![]() Join Date: May 2011 Location: Virginia Beach, Virginia
Rep Power: 3957 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,694
| Not Ranked : 0 score sub'd for future reference
__________________ I'm not back... But help me find SOMETHING Daily: Evelyn (Eve), 04 4Motion 6Speed VW Passat W8 Sold to @yourstruly; : Isabella (Izzy), 06 MS6 GT with Navigation #1271 Sold to @downmented; : Audrey, 95 Miata Totaled: Vivian (Viv), 07 MS3 bolted and built, brutally murdered by a texting driver ![]() |
![]() | | #24 | ![]() |
| Police ![]() Join Date: Dec 2009 Location: Guadalajara MX
Rep Power: 3113 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,737
Groaned at 9 Times in 9 Posts
| Subbed, I'll probably join the list eventually
__________________ SOLD MS3 GT 2009 - Garret GTX3076R -CP-E 4' TIP // CP-E big MAF intake // Turbosmart compact BPV // Lamin-X yellow fog covers // Hella Xtreme yellow fog bulbs // Eonon 7" screen // Prosport Boost Gauge // Ventpod Single Gauge Pod // CPE TowPlate // MSD Dashhawk // COBB AccessPort // USDM ECU // CM Downpipe // Ingalls Torque Damper // Denso ITV24 // GV style front lip // TRZ rear motor mount // PG/Godspeed FMIC // Magnaflow CBE // COBB counter shiftweight // CPE PMM // CPE TMM // Autotech HPFP internals // PERM tune in progress // COBB EBCS // HPFPupgrade injector seals // Apex-i TT // PERM tune // Final numbers: 427 WHP - 471 WTQSOLD: BMW 325ci coupe Formula 1 package 2001 - Daily driven FTW! MS3 vs Focus ST vs Camaro LS1 ---> Click here TEH MEXICAN'T PERM! Current whip: 2013 BMW 135i ///M Sport - BMW Performance Exhaust System - BurgerTuning JB4 - Golf Tee Mod - COBB Charge Pipe - BMW Blackline taillights - BMW Performance CF rear spoiler - 8K LED Angel eyes |
![]() | | #25 | ![]() |
![]() | | #26 | ![]() |
![]() Join Date: Feb 2012 Location: Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 250
Groaned at 7 Times in 3 Posts
Same deal with the oil restrictor, so once the oil gets *past* the restriction, the pressure is reduced to less than it was in the first place. Last time I contacted Garrett about the correct size restrictor they told me that the GT series had the 'correct' restrictor is already built into the top of the CHRA. This still doesn't quite make sense to me because I would have thought that the 'one size fits all' restrictor is really only suited to a certain range of feed pressures. And every car is different in that regard. So it would be good to know what pressures we're actually working with on this platform. Sorry for going off topic, the pressure/restrictor size issue may well need its own thread. Last edited by Spectrix; 03-17-2013 at 06:40 AM. | |
![]() | | #27 | ![]() |
Groans: 111
| Not Ranked : 0 score In 7 days from now my GTX3071 will be one year old. I already pud 20k km/12k miles on it including a track session which left me with no brakes. Knock on wood but no problems so far. The only problem that I have is overheating the engine coolant and the only thing that was changed was the turbo, TIH, and the engine coolant (FL22 50/50 mix, probably I should have to dilute it a bit). today at 0C/32F ambient the ECT after 2 hours of relatively calm city traffic (stop lights, moving speeds of 30-70Kmph/20-45mph) and 5 minutes of idling in the parking lot the ECT's were at 108C/225F).
![]() | | #28 | ![]() |
Groans: 111
This is a total non-sense. When a thermostat fails it should remain open FFS! I don't give a .uck by the quick engine heat-up after startup during cold mornings if I'm going to cook the valve seals 30 miles later!
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score Apparently failed tstats are common Mine runs hot all the time as well You might want to check out the "mzr disi heat management" thread. Tappin
![]() | | #30 | ![]() |
| lulz @Raider ![]() Join Date: Jun 2010 Location: St Louis Mo
Rep Power: 3779 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,132
| Not Ranked : 0 score I think I may be part of this group now, there was a kink in the return line because it is too long and now I am burning oil at a pretty constant rate. There is no oil pre-turbo(in the exhaust mani) intake and intercooler piping seem to be dry as well. The car is doing similar to what ray ray stated, at this point not much but there is some smoke. Has anyone priced what the cost it to have them fixe the issue? Turbo type: gtx3071r Restrictor type: none Failure type: smoking under load Oil return line: ATP, recently replaced by @HTP; with correct size Turbo mileage: 20k Symptoms: smoking like a k04 in boost
__________________ 2008 MS3 gt 470hp/463tq on GT35r at 29psi Wiseco Pistons/Molar Rods/ACT 6 Puck/ARP Head Studs/TurboXS FMIC DP and RP/TurboSmart BOV/Tial 38mm EWG/PERM 5th/6th port injectors HKS CBE/ Koni Yellows and H&R springs/ HTP Whale Penis Intake/ PTP Fuel internals/SteedSpeed Mani/CP-E SafeSeals/E85 Hypnotic Tuned |
![]() | | #31 | ![]() |
| Not Ranked : 0 score Not being read @ the turbo feed line, but maybe a decent link for general oil pressure readings and as a guideline for deciding if you choose to install a restrictor: purple drank oil pressure woes |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | NJSPEED3 (07-03-2013) |
![]() | | #32 | ![]() |
![]() Join Date: Aug 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score interesting read, so restrictor DOES lower pressure... was it decided if our engine should or should not use a restrictor?
__________________ TurboXS: Downpipe, Racepipe, Catback, FMIC C-PE: RMM, TIP, Nano Intake AutoTech Internals, Custom Tuned |
![]() | | #33 | ![]() |
![]() Join Date: Dec 2012 Location: Portland, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 800
![]() | | #34 | ![]() |
| Not Ranked : 0 score I think this is a good thread idea to cover GT and GTX failures. So bump bump. @Dano; I know you have a recent failure also. Turbo type:GTX3071r Restrictor used: no restrictor using Garrett Turbo BB low profile banjo bolt Failure Mode: CHRA bearing failure Oil feed line used: OEM Oil return line used and if modified for length: OEM modified (cut accordion section out and installed 5/8" steel braided hose to allow better flex. Vendor Purchased from: original owner purchased from ATP Answer/resolution from vendor or manufacturer: CHRA exchange with ATP for $742.49 Symptoms: nails on chalkboard sound when turbo experienced any load. Turbo mileage: 20,000-30,000 miles between two owners Turbo failure after blown motor: no I did have some compressor wheel to housing contact. There were some brazing marks on the housing but I was able to smooth it out with some 2000 grit wet sand paper.
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score So my GTX3071 failed a few weeks ago. Turbo type:GTX3071r Restrictor used: "Garrett BB turbo restrictor bolt" off e-bay. Full description below. Failure Mode: CHRA bearing failure Oil feed line used: -4AN PTFE SS Oil return line used and if modified for length: ATP -10AN 1.5 " removed to make it fit. Vendor Purchased from: forum member in FS section Answer/resolution from vendor or manufacturer: FU cuz used - bought entire new kit Symptoms: no boost with rough bearing sound upon shutdown - very slight contact with comp housing Turbo mileage: 15-20K miles between two owners Turbo failure after blown motor: no So here are some details on my setup cross posted from ATP/Garrett Hate - failure GTX3076 So while swapping out turbos to get the GTX back in I thought I'd take a closer look at the restrictor's I have on hand. In the below pic, from left to right you have: the bolt that comes with a brand new ATP GTX kit, the Garrett BB bolt on e-bay and the Garrett "restrictor" bolt on e-bay. ![]() ![]() Its hard to tell but the middle bolt is just slightly larger than the one on the far right. The one on the far right is what I was running on the failed GTX. So I have to wonder, if a "restrictor" bolt is needed, and we see that in Garrett's documentation, why does ATP ship out a new kit with the bolt shown on the far left hand side? Not sure which bolt I'll use, out of the two on the left, the most restrictive bolt is out for sure. The far left bolt is what I ran my GT28 with for almost its entire life, 20-25K miles and I just ran it for 2 weeks as a temp with zero trouble - it runs like new. The middle bolt was run on the GTX for a while then I ran the most restrictive version for just a few K miles. anyway I thought it would be good to have more data on this subject. edit: Here is a pic of a restrictor my buddy is running on his GTX3582r in his bugeye. comparo to my smallest restrictor.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 11-10-2014 at 09:44 PM. |
![]() | | #36 | ![]() |
I think we should all start using a filter inline with the feed. When I took my 3071 off, I had a very small black piece of hardened something that I'm lucky didn't cover the feed hole. | |
![]() | | #37 | ![]() |
(Thread Starter) | Not Ranked : 0 score 1) why no avatar. 2) I did 1 last pull on my load tune and just drove the car home without looking at the log...just planned to look when I got home. it was a 10 minute drive and when I got off the freeway and pulled into my hood I noticed the car had no power...but no screeching noise either. I pull up into the garage shut the car off and then I hear the bearings as it spun down. no screeching but a horrible dry/toasted bearing sound..lol it was gone. changed my oil 2x and did get metal shavings off my mag pan bolt which totally sucks but so far no oil pressure drop in the new motor. I am fairly sure my restrictor bolt was the cause of my failure.
| The Following User Says Thank You to Dano For This Useful Post: | rfinkle2 (11-09-2014) |
![]() | | #38 | ![]() |
What do we need to do to actually measure this feed pressure so we can figure this out? Just a standard oil pressure gauge @ the turbo? Fuck, I'll do that this week. | |
![]() | | #39 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'd have to go back and look at my build v1 thread but I measured the pressure unrestricted out of the block (my original oil sender location) and it was the same as at the sammach plate IIRC.
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score updated post 35 with a pic of an inline restrictor the subbie guys use on their Garrett/FP BB turbos.
| Display Modes | |
| Garrett m33 turbo | skiptowncat | MazdaSpeed 3/6 - Turbo Induction | 9 | 08-14-2012 03:41 PM |
| Who DOESN'T run a Garrett turbo | Ezekiel81923 | 2010 MS3 - Turbo Induction | 138 | 08-02-2012 05:20 PM |
| GARRETT 3" Turbo Inlet Pipe Kit | Blackedout1978 | 2010 MS3 - Turbo Induction | 3 | 03-13-2012 01:51 PM |
| Failed Thread | essejkcamraw | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 57 | 11-17-2010 11:16 AM |
