Like Tree12Likes
 Old 03-16-2011, 02:47 AM   #81
spike589's Avatar
Posts: 295   (View Stats)
spike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond repute
Groaned at 6 Times in 3 Posts
from what the tech told me the valve cover has some kind of baffle plate built in on the the back runner of the valve cover. ive been running my car hard the last two days and idling seems to be better but i still see smoke but its probably still from all the residual oil thats in my exhaust.
Corksport 3in catback resonator removed, Turbo XS catless downpipe, Cobb AP Stage 2 ots map, COBB SRI, RPMC inlet, Ported/ Rebuilt Ko4, ported exhaust manifold, ported and ects delete, JBR EGR delete, JBarone passenger, rear and tranny mount, JBarone SSP/ knob/ bushings,DDM HID low/high/fogs, Snow performance stage 2 MAF meth kit, Matt Damond OCC and check valve, Tenzo Concept-9 wheels, Turbosmart 50/50, Denso ITV-22, Tinted tailights-reflectors-corners, prosport boost gauge, DIY FMIC, Carbon hood wrap, NRG shorty antenna
spike589 is offline   Reply With Quote
 Old 03-16-2011, 07:05 AM   #82
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
Originally Posted by sicspeed View Post
Yes, i believe your right. Was looking at some photos and see the 3 way solenoid.
So then the only difference is the location of the vent tube closer to the turbo inlet and the redesign of the valve cover vent exit. This leads me to believe that mazda must have done something to that vent but what? I dont think mazda would spend $$ to just refab a new design valve cover for just a vent tube to the tip.
Im sure eventually someone will take those screw off if possible n see whats there if anything.
my guess is that putting the vent closer to the turbo allows it to pull more vacuum on the crankcase thus allowing the oil to drain from the turbo quicker to prevent the smoking.
 Old 03-16-2011, 07:36 AM   #83
ripacrombie's Avatar
Posts: 76   (View Stats)
ripacrombie has much to be proud ofripacrombie has much to be proud ofripacrombie has much to be proud ofripacrombie has much to be proud ofripacrombie has much to be proud ofripacrombie has much to be proud ofripacrombie has much to be proud ofripacrombie has much to be proud ofripacrombie has much to be proud of
Groaned at 5 Times in 2 Posts
After reviewing 01-002/11 TSB, it only applies to Mazdaspeed 3 (2007-2009 w/VIN JM1BK****9*187397 and lower) and CX-7's (2007-2009 w/VIN JM3ER****9*224013 and below) and strictly (in red) references 01-001/11 for 2006-2007 MS6 owners. The 01-001/11 TSB, replaces the turbo itself instead of the Ventilation Set suggested in 01-002/11 TSB. If you managed to get a new Ventilation Set AND a new turbo out of this for Mazdaspeed 3/CX-7, you are extremely lucky. 01-002/11 TSB specifically states that a "turbo" replacement is no longer valid or eligible to fix the "white smoke" issue for Mazdaspeed 3 and CX-7 models. It also points out that once the new Ventilation Set is installed, the issue is no longer service-able and considered a "closed topic". Which means, if it didn't fix your issue, your shit out of luck unless you have a compassionate Mazda dealership.
For Mazdaspeed 6 owners 2006-2007, the 001/001/11 "white smoke" turbo replacement is covered under the standard 35K warranty and 60K powertrain limited warranty. If you are within your powertrain limited warranty, go in and get it fixed before it's to late. Also, having a downpipe/exhaust installed will in no way void your powertrain limited warranty, nor relate to the issue at hand which in turn will prevent you from getting a new turbo. From the words of a close friend who is a the Service Manager in the largest Mazda dealership in New England, "this issue if from the turbo up, not turbo down". Having a downpipe actually helps troubleshoot this issue! It allows us and the service technician a better way to diagnose whether or not our turbo seals have the issue. Having the stock downpipe "disguises" the smoke much much more.
I'm hopefully getting mine (turbo) replaced this weekend on my 07 MS6
001-002/11 Replaces the following for the MazdaSpeed 3:
  • Ventilation Set; Quantity: 1; Part Number: L3Y2-13-S80B; Notes: Mazdaspeed 3 specific
  • Oil Filter Cartridge; Quantity: 1; Part Number: L321-14-302A-9U; Notes: Only for customers returning for 5W-40 Synthetic oil change.
  • Oil (5W-30); Quantity: 6; Part Number: 5555-EG-001; Notes: Only for customers returning for 5W-40 Synthetic oil change.
The Ventilation Set includes the following:
  • Cylinder Head Cover (A)
  • Ventilation Hose (B)
  • Engine Hanger (C)
  • Air Pipe (D)
  • Vacuum Hose (E)
  • and Plug (F)
http://www.jodriscoll.com/dir/MS6/
ripacrombie is offline   Reply With Quote
The Following User Says Thank You to ripacrombie For This Useful Post:
kunfu (07-10-2011)
 Old 03-16-2011, 07:39 AM   #84
bova's Avatar
Groans: 45
no one is getting a header, which doesn't exist because a it's called a manifold. i'm guessing you meant valve cover and not header.
 Old 03-16-2011, 10:17 AM   #85
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
We haz header and cat muffler?!?!
Tapatalk
 Old 03-16-2011, 11:51 AM   #86
Sorry, I updated my post, I used the incorrect terminology.
 Old 03-16-2011, 11:55 AM   #87
bova's Avatar
Groans: 45
but you are still wrong because they are not replacing the manifold (this is the exhaust between engine and turbo). it states they are replacing the valve cover.
 Old 03-16-2011, 12:04 PM   #88
Give me a damn second jeez, I was updating the whole post lol
P.S. - The correct part name under the Mazda TSB is "Cylinder Head Cover"
 Old 03-16-2011, 12:08 PM   #89
bova's Avatar
Groans: 45
last time i'll nit pick, its not really a pcv re-route either because the pcv is located behind the intake manifold. the vent on the valve cover is just a vent
 Old 03-16-2011, 12:13 PM   #90
There, I updated it to the correct Mazda term for it, "Ventilation Set". nit pick that buddy!
 Old 03-16-2011, 12:17 PM   #91
bova's Avatar
Groans: 45
haha ok there you go...just don't want some people to misunderstand it
The Following User Says Thank You to bova For This Useful Post:
08.5MS3 (04-20-2011)
 Old 03-16-2011, 12:17 PM   #92
08.5MS3's Avatar
Groans: 89
Nit pick man. When I called Mazda, they said 2 fixes for the PCV and I was like, oh rly? Assuming they meant the valve cover of course.
You're doing everyone a favor. On the far end of the spectrum, it's like calling the intake, the exhaust, and vice versa.
However, does this breather hose indirectly effect the PCV in regards to pressure? I understand the PCV is dealing with the crankcase and we are talking valve cover here, but is there a relationship somewhere?
Tapatalk
 Old 03-16-2011, 12:20 PM   #93
bova's Avatar
Groans: 45
i think it just changes how much vacuum is seen in the crankcase, not sure it has any affect on the pcv itself though. like i said before it's probably done to create more vacuum to pull the oil from the turbo drain line and prevent it from backup past the seals.
08.5MS3 (03-16-2011)
 Old 03-16-2011, 12:21 PM   #94
Here is the Mazda explanation of why this fix resolves the white smoke for Mazdaspeed 3 & CX-7.
DESCRIPTION
Some customers may experience white/blue smoke from the exhaust pipes after long idle periods or while driving at slow speeds in heavy traffic.
This condition may be the result of insufficient crank case ventilation, resulting in oil leakage past the exhaust turbine shaft seal.
Other possible causes (determined by reviewing the vehicle’s maintenance records) that should be corrected at the owner’s expense prior to performing this bulletin are:
  • Engine oil viscosity break down due to insufficient oil change(s).
  • Usage of lower than 5W-30 viscosity engine oil.
NOTE:
  • This bulletin is not applicable to vehicles with a prior turbocharger replacement using a “C” level or later part number (i.e. L3Y*-13-70ZC).
  • The oil change program as described in the prior service bulletins under the same subject, is no longer in effect.
  • Provisions are included for a final oil change for customers that are returning for an additional oil change where the concern was corrected using 5W-40 synthetic oil.
  • If the turbocharger is diagnosed with impeller damage caused by contact with the housing (as described in the Inspection Procedure), this bulletin is not applicable.
    Customers having this concern should have their vehicle repaired according to the following repair procedure.
 Old 03-16-2011, 12:24 PM   #95
bova's Avatar
Groans: 45
this is why upping the idle and switching to 5w40 resolve the issue. switching to 5w40 gives you thicker oil which doesn't leak past the seals. and upping the idle increases the vacuum on the crank case.
 Old 03-16-2011, 12:26 PM   #96
I did this last night with my VersaTune tune, and it removed the white smoke and also stopped the idle rattle of my Magnaflow exhaust .
I purchased a PTP PCV fix and Windage tray and neither of those did shit. Don't waste your money everyone...
 Old 03-16-2011, 12:26 PM   #97
08.5MS3's Avatar
Groans: 89
Do you have a link to the new TSB?
It's just funny how my dealership stated there were 3 fixes for this and the turbo replacement was one of them. I'm assuming this is if there is damage to the impeller.
 Old 03-16-2011, 12:28 PM   #98
bova's Avatar
Groans: 45
as far as i know the 3 were
-replace oil with 5w40
-replace turbo
-replace valve cover
 Old 03-16-2011, 12:38 PM   #99
08.5MS3's Avatar
Groans: 89
-replace turbo
Right. It's just odd how my dealership said they were all still valid, even when all the TSB's state each new one supersedes the old ones.
After this next service, I'll switch to 5W40. And I'll also have Matt's OCC, which hopefully alleviates some.
Maybe I'll get a new turbo and valve cover! Seems the biggest thing with the new TSB is the valve cover, with its baffles inside. I can't see how the relocation of the breather hose has that much effect on pressure, especially when it's next to the turbine, and is downhill from the valve cover.
 Old 03-16-2011, 12:38 PM   #100
I do, but the fine print clearly states I am not allowed to distribute it, sorry bro.
-replace turbo
Post #95 which is a direct copy and paste from the TSB. It is basically saying if the service technician thinks the issue is turbo side, you WILL get a new turbo, but NOT a Ventilation Set. I highly doubt the Mazda technician is going to hook you up with both when it clearly states it's EITHER OR in the TSB workflow for diagnosing a fix.
 Old 03-16-2011, 12:40 PM   #101
bova's Avatar
Groans: 45
being downhill has no affect at all. its just there is more pull right there than farther up the intake.
 Old 03-16-2011, 09:28 PM   #102
wildacex187's Avatar
Posts: 154   (View Stats)
wildacex187 has a reputation beyond reputewildacex187 has a reputation beyond reputewildacex187 has a reputation beyond reputewildacex187 has a reputation beyond reputewildacex187 has a reputation beyond reputewildacex187 has a reputation beyond reputewildacex187 has a reputation beyond reputewildacex187 has a reputation beyond reputewildacex187 has a reputation beyond reputewildacex187 has a reputation beyond reputewildacex187 has a reputation beyond repute
my turbo has been smoking bad today for some reason. took a couple of blocks to alleviate. ugh its embarrassing. does it get worse with warmer temps? waiting to see if this is worth it or not before i purchase.
red mazdaspeed 6 gt
fujita cai, tip, test pipe, turbosmart dual port bpv, SURE rmm (in blue ), jabrone shifter bushings and 1lb shift knob, cobb ap stg 1 fucai93 map with LC and idle edited just cuz
wildacex187 is offline   Reply With Quote
 Old 03-16-2011, 10:19 PM   #103
kpuser1's Avatar
Posts: 91   (View Stats)
kpuser1 has a reputation beyond reputekpuser1 has a reputation beyond reputekpuser1 has a reputation beyond reputekpuser1 has a reputation beyond reputekpuser1 has a reputation beyond reputekpuser1 has a reputation beyond reputekpuser1 has a reputation beyond reputekpuser1 has a reputation beyond reputekpuser1 has a reputation beyond reputekpuser1 has a reputation beyond reputekpuser1 has a reputation beyond repute
My shit was smoking with a ebay tp(stock dp). Wanted to take to dealer since I'm still in warranty but was worried about testpipe so
I put back to stock and it hasn't smoked since(over 1,000 miles) Dealer wasn't able to get it to smoke either..wtf..It's amazing what that cat covers.
Debating taking a chance and puting tp back on and taking to dealer because i'm sure it will start smoking again...idk...
Cosmic Speed3 - Cobb AP | JBR Tru-3.0 Intake | EBay Racepipe | MD OCC | Eibach | Enkei | Aeroforce Interceptor gauge | JBR SS, Knob, PMM, RMM, TMM, RSB...
kpuser1 is offline   Reply With Quote
 Old 03-16-2011, 10:34 PM   #104
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
i would. thats what i had to tell them when they kept saying they needed to replicate the smoking with the car stock.
i told them that its pointless b.c the exhaust has two cats which are covering up the smoke
2015 Mazda 6
The Following User Says Thank You to IshiKage For This Useful Post:
kyzomo (06-22-2011)
The Following User Says NO Thank You to IshiKage For This Un-useful Post:
cbspeed3 (03-16-2011)
 Old 03-16-2011, 11:12 PM   #105
make sure they are mod friendly though.
red mazdaspeed 6 gt
 Old 03-23-2011, 01:11 PM   #106
dsmluck's Avatar
Posts: 1,193   (View Stats)
dsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the worlddsmluck is the leader of the world
Groans: 60
Just got a call from the dealer. They are replacing the Turbo and not the valve cover on my 2009 ms3. NNot sure why. I will try to get more info when I have time. Also I had a downpipe and intake and the dealer wanted me to take off the dp before Bringing it in but I explained to them how the oil killed my cat and they allowed it and Mazda USA approved the work.
dsmluck is offline   Reply With Quote
 Old 03-24-2011, 08:48 AM   #107
bzwyatt's Avatar
Posts: 543   (View Stats)
bzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the worldbzwyatt is the leader of the world
Groaned at 35 Times in 14 Posts
Huh. Got a new turbo on my 08 CX-7 (BPV only mod) last December. Wonder if I should ask dealer about this.
bzwyatt is offline   Reply With Quote
 Old 03-24-2011, 01:45 PM   #108
evidence's Avatar
Posts: 1,033   (View Stats)
You likely have the new turbo from the previous TSB.. they are instructed not to do the vent fix if you have the new turbo. If you have a cool dealer and a stock TIP not sure it would hurt.. Mazda couldn't have worsened the design, right?
Some things.
 Old 03-24-2011, 02:23 PM   #109
bzwyatt's Avatar
That's right. My car didn't smoke until late last year and I never changed the oil viscosity or did anything else with the first TSB info since I never had a problem. By the time mine started smoking, the second TSB was out and I found it here, went to the dealer and got the new turbo. I guess if I get a catch can I should be good. Can't help wanting all the fixes they offer though. Then again, I changed my oil last weekend and the cover under my engine had 4 or 5 bolts missing, dealer forgot to put them back I guess so I'm scared at what else they might have forgotten...
 Old 03-29-2011, 01:11 AM   #110
dsmluck's Avatar
Groans: 60
Dealer replaced the turbo and not the valve cover on my 2009 MS3. Not really sure why but that was the instructions from Mazda USA.
 Old 03-31-2011, 12:00 PM   #111
jeff4880's Avatar
Posts: 46   (View Stats)
jeff4880 has a spectacular aura aboutjeff4880 has a spectacular aura aboutjeff4880 has a spectacular aura about
Is there a part number for just the valve cover? I would like to see the diffrences if it's cheap enough I will buy one and compare the 2.
jeff4880 is offline   Reply With Quote
 Old 03-31-2011, 12:54 PM   #112
08.5MS3's Avatar
Groans: 89
It's probably not cheap coming from the dealer. With everything, the dealer quoted $506. Thank you warranty.
Tapawhat?
 Old 04-02-2011, 06:09 AM   #113
ms3.703's Avatar
Posts: 2   (View Stats)
ms3.703 has a little shameless behaviour in the past
only if they had done this in the first place..
Cobb turbo inlet, Cobb SF intake, Cobb A/P stage 2, Cobb sport springs, CNT Racing 3" dp catted, CNT Racing 3" cat-back, PT-perfomance PCV plug, Saikou Michi OCC, JBarone SSP, Sure motorsports RRM, Sure motorsports Return, Sure motorsports Anchors, Crossed drilled/slotted rotors F+R, EBC Redstuff pads F+R, 18" Volk GT-N/Nitto NeoGen 225/40/ZR18, bnoon oil restrictor bolt
ms3.703 is offline   Reply With Quote
 Old 04-05-2011, 10:55 PM   #114
clydesdale29er's Avatar
Posts: 12   (View Stats)
clydesdale29er will become famous soon enough
ok, I'm new to this board and have been doing a ton of catching up as the 07 MS3 I just bought is smoking at idle. it has almost 70K miles on it. do TSBs still apply to me? honestly thinking it is worth a shot anyway.
But if not would a second OCC on the valve cover vent to intake tube do basically the same thing as this up fit? Thanks for the info guys!
clydesdale29er is offline   Reply With Quote
 Old 04-05-2011, 10:58 PM   #115
08.5MS3's Avatar
Groans: 89
Did you buy the extended warranty? Maybe you'll have a nice dealer and they'll do it under warranty. If not, it's a $500 fix.
A second CC couldn't hurt, however, I think the difference is within the valve cover itself.
Tapawhat?
 Old 04-05-2011, 11:10 PM   #116
No warranty. thinking the valve cover difference is just a different/higher/larger baffle. $160 OCC should have plenty of baffling to perform as well as a $500 valve cover....
 Old 04-06-2011, 06:27 AM   #117
Supernova Mafia's Avatar
Posts: 26   (View Stats)
Supernova Mafia is on a distinguished road
Groaned at 6 Times in 2 Posts
It funny the last time I was at the dealer they noted they are recommending a 0w-20 full synth now for the MS3,.....right up until it starts smoking.
Supernova Mafia is offline   Reply With Quote
 Old 04-14-2011, 01:13 AM   #118
theurgy's Avatar
Posts: 2,580   (View Stats)
Anybody who is eligible for this warranty TSB but because of mods is not installing it yet still willing to get the kit and send it to a fellow Canadian Speed3 owner ... gimme a shout.
As usual, Mazda Canada fails again at keeping up to date on TSB's. To hell if they are even going to release it up north.
 Old 04-18-2011, 08:26 AM   #119
MoparGo
Lurkers
MoparGo's Avatar
Posts: n/a
Thumbs up I want to give a heartfelt...
...thanks for the OP of this thread...
My dealership is doing the "smoke at idle fix" for me on thursday this week.
Complete "360 inspection" today and the problem was slight... but they will fix it anyway.
Kit... $485. Labor 1.5hrs to 3hrs (books at 1.5 but takes longer to complete).
My turbo etc... checked out 100% and they said it should live much longer after the fix is in.
OP rocks. www.mazdaspeedforum.org/forum rocks. Thanks.
 Old 04-18-2011, 09:01 AM   #120
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
so is cp-e or cobb updating their TIPs to take advantage of the new breather hose location?
my car is beginning to look like a chain-smoker.
'08 CWP MS3 w/ T3 3071r
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/final-smoke-idle-fix-mazda-tsb-01-a-73738/
Design's Long Term Ownership/Build Thread This thread Refback 09-18-2015 04:13 PM
Design's Long Term Ownership/Build Thread - Page 8 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Pingback 09-14-2015 03:22 PM
Turbo inlet Corksport - Page 2 - Mazda 3 Quebec This thread Refback 09-05-2012 09:26 AM
Tonka Toughest Mighty Truck (handle color may vary) (Oct 15, 2007) This thread Refback 06-25-2012 05:56 PM
404 Not Found This thread Refback 06-15-2012 11:29 AM
White smoke - Page 3 This thread Refback 11-12-2011 07:02 PM
White smoke - Page 2 This thread Pingback 10-03-2011 11:52 PM
???????? ???!!!!!! This thread Refback 05-15-2011 10:06 AM
Smokey turbo seals - NEW mazda fix apparantly? This thread Pingback 05-08-2011 10:02 PM
FUMEE BLANCHE DE L'ECHAPEMENT - Mazda 3 Quebec This thread Refback 05-03-2011 01:23 PM
Mazda savuttaa pitkän tyhjäkäynnin jälkeen / osia mistä / takaisinkutsu ...? This thread Refback 04-29-2011 12:08 PM
Mazda savuttaa pitkän tyhjäkäynnin jälkeen / osia mistä / takisinkutsu ...? This thread Refback 04-29-2011 03:01 AM
Any input on the 'speed3, Civic Si, and GTi as family cars? - MX-5 Miata Forum This thread Refback 04-27-2011 07:25 AM
Seal de Turbo - Mazda 3 Quebec This thread Refback 03-20-2011 08:42 AM
smoking at idle fix at mazda This thread Refback 03-09-2011 09:33 AM
smoke on idle? kraz3y MazdaSpeed 3/6 - Turbo Induction 20 01-09-2013 03:26 AM
The Smoke at Idle TSB. New Turbo required. TSB 01-004/10 Dated 08/18/2010 FreeFlyFreak MazdaSpeed 3/6 - Turbo Induction 66 08-27-2011 08:24 PM
idle smoke getting serious Chriscote MazdaSpeed 6 - Engine, Transmission & Driveline 16 11-03-2010 01:43 PM
Smoke at idle sleeper329 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-13-2010 01:56 PM
smoke at idle ms3-87 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 05-31-2008 01:15 PM
Page generated in 0.59057 seconds with 36 queries
