  • 2 Post By monkey.bones.007
 Old 03-15-2017, 11:48 AM   #1
G502S's Avatar
Posts: 2   (View Stats)
G502S can only hope to improve
Groaned at 6 Times in 2 Posts
Default Gen 2 Intake on Gen 1 Speed3?
Noob question here and new to the forum, but I am wondering if an aftermarket intake for a Gen 2 Speed 3 would work on a Gen 1 without use of an AP. Are they different or the same?
Mitch
G502S is offline   Reply With Quote
The Following 4 Users Say NO Thank You to G502S For This Un-useful Post:
g00s3y (03-15-2017), MSMS3 (03-17-2017), tegxsi (03-15-2017), Vansquish (03-15-2017)
 Old 03-15-2017, 12:12 PM   #2
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Same.
Learn to search.
 Old 03-15-2017, 12:56 PM   #3
G502S's Avatar
Same.
Learn to search.
Goodbye to this forum.... I did use search, couldn't find a definitive answer.
The Following 2 Users Say NO Thank You to G502S For This Un-useful Post:
 Old 03-15-2017, 12:57 PM   #4
Police - Grammarhead
Vansquish's Avatar
Tootles, twinkletoes.
 Old 03-15-2017, 01:31 PM   #5
Bingo's Avatar
Posts: 740   (View Stats)
Groaned at 9 Times in 7 Posts
Bye
Things that matter: CS "Stage 2" SRI/TIP, CS TMIC, AT HPFP, JBR 70 duro RMM, Stratified OTS +, Koni FSD's, Whiteline endlinks.
Things that don't: Gen Pu wheels, CPE center pod with Prosport boost, OP, and OT gauges, Eonon G9151A.
 Old 03-15-2017, 04:22 PM   #6
Varomnia's Avatar
Posts: 459   (View Stats)
New intake without maf calibration? Good luck with that.
 Old 03-15-2017, 06:12 PM   #7
sheston's Avatar
Posts: 1,847   (View Stats)
At least he got 2 posts :-)
 Old 03-16-2017, 07:35 AM   #8
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
https://www.youtube.com/watch?v=Eo-KmOd3i7s
2012 NASA Spaceship Gray MS3
monkey.bones.007 (03-19-2017), Varomnia (03-16-2017)
 Old 03-17-2017, 06:25 PM   #9
MSMS3's Avatar
Posts: 2,826   (View Stats)
OP's post was sad, but this one is about as bad.
Most aftermarket intakes when added to the stock turbo and TIP and stock ECU tune require no maf cal or change in tune whatsoever, if they have the same diameter maf housing. Most do.
That's how most intakes from the major aftermarket companies' intakes are made - intended to be plug and play on stock tune, TiP and K04, and often with air straighteners if they are CAI style.
tegxsi (03-17-2017)
 Old 03-19-2017, 10:10 AM   #10
Biobandit's Avatar
Posts: 204   (View Stats)
Biobandit is the leader of the worldBiobandit is the leader of the worldBiobandit is the leader of the worldBiobandit is the leader of the worldBiobandit is the leader of the worldBiobandit is the leader of the worldBiobandit is the leader of the worldBiobandit is the leader of the worldBiobandit is the leader of the worldBiobandit is the leader of the worldBiobandit is the leader of the world
Wow. I'd call that a fairly nice answer and he still got mad. Yea, you don't belong here.
Sent from my ONE A2005 using Tapatalk
Biobandit is offline   Reply With Quote
The Following User Says Thank You to Biobandit For This Useful Post:
 Old 03-19-2017, 12:41 PM   #11
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
Hey op, I found a group that's probably more your style. Look them up and see if they can answer your question.
Crapatalk, it sucks for free!
KiwiFlavor and Biobandit like this.
KiwiFlavor (03-20-2017)
Recommended Air Intake for my 2013 Speed3 Inspec25 MazdaSpeed 3/6 - Turbo Induction 14 05-03-2014 01:11 PM
Speed6 intake on Speed3? michaeljp MazdaSpeed 3/6 - Turbo Induction 4 03-07-2010 06:27 PM
Page generated in 0.31939 seconds with 30 queries
