 Old 02-24-2016, 07:12 AM   #1
wes3id's Avatar
Posts: 611   (View Stats)
wes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the world
Default Grimmspeed EBCS nipple fitting swap
I just installed a BNR S3 and noticed how much bigger the fitting for the vacuum line is compared to the K04....and how tiny the ports are on the grimmspeed ebcs. are those nipples changeable? and would they all need to be the same size? anybody have experience doing this? i just dont like having to use a bigger id hose on a too small fitting.....too much risk as zip ties eventually break after long heat exposure.
07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS
K04 93 FREEKTUNED 271 AWHP/296TQ
K04 E85 FREEKTUNED 309 AWHP/360TQ
BNR S3 93 FREEKTUNED 336 AWHP/360TQ
BNR S3 E85 FREEKTUNED 375 AWHP/376TQ
wes3id is offline   Reply With Quote
 Old 02-24-2016, 07:20 AM   #2
Police - Grammarhead
Vansquish's Avatar
I just got a step-down connector from Lowe's and used two differently-sized pieces of vacuum hose. It's working perfectly, and has done since day 1.
wes3id (02-24-2016)
 Old 02-24-2016, 08:42 AM   #3
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
You basically want the Cobb fitting kit, or to source the same size brass barbs from your local hardware store which don't look nearly as cool but work fine.
COBB Tuning - EBCS 1/4" EWG Fitting Kit
340hp / 371tq
wes3id (02-24-2016)
 Old 02-26-2016, 12:27 PM   #4
connor_cwp's Avatar
Posts: 119   (View Stats)
connor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond reputeconnor_cwp has a reputation beyond repute
These look nearly identical to the Cobb fittings.
https://www.zoro.com/pneumadyne-inc-...18/i/G2388391/
Or in bulk (25) here.
1/8 NPT Thread to Barb Elbow Fittings | Pneumadyne
These don't look as good but are way less expensive if not buying in bulk.
https://www.fastenal.com/products/details/69942
2009 CWP MS3 Sport
DM EGR Delete, TMM, and PMM. JBR RMM, BSD, Oil Baffle, Shift Weight. HTP 3.5" intake, Under Route IC Piping. Treadstone TR8. AEM gauges. CPE Gauge Pod. Progress RSB. Evo X Enkei. 245 Pilot Super Sport. Rally Armor Mudflaps. Custom test pipe, catback, and MAC EBCS in 3 port.
connor_cwp is offline   Reply With Quote
The Following User Says Thank You to connor_cwp For This Useful Post:
wes3id (02-26-2016)
 Old 02-26-2016, 12:32 PM   #5
wes3id's Avatar
I found and bought these 1 4 OD Hose Barb End Nipple to 1 8 NPT Fitting 90 Degree | eBay
will go good with all blue accents and car
Barb fitting for boost NIPPLE doctavus Gen2 MS3 General Discussion 5 08-20-2015 06:18 PM
Grimmspeed EBCS Zoomzoomevans 2010 MS3 - How-To's 6 12-19-2013 06:39 AM
Grimmspeed EBCS? Need It? RedBliss MazdaSpeed 6 - Engine, Transmission & Driveline 5 07-28-2010 07:43 AM
Page generated in 0.27117 seconds with 23 queries
