 Old 06-06-2016, 07:18 AM   #1
Xxblinddzxx's Avatar
Posts: 126   (View Stats)
Xxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud ofXxblinddzxx has much to be proud of
Groaned at 26 Times in 11 Posts
Default GT3071R Speed 3 questions
Hi guys ,
So i currently have a CS turbo which i just sold since a friend of mine is selling his GT3071R. I been able to answer some of my question but 2-3 of them remains unclear. First i've saw some people hitting up to 394hp on E85 but will it be able to hit 460-480whp ( I've saw that it is 480HP capable but not sure if that was at the crank or wheels) with all supporting mods? (yes that include 1200ml/min meth , hot side ewg , exhaust mani , 3" SRI , built bloc......). How about CFM? Any one knows whats the CFM rating on this turbo ?!?. And last consern, what is the max efficiency PSI you can push on this turbo ?
Thanks =)
Xxblinddzxx is offline   Reply With Quote
 Old 06-06-2016, 07:40 AM   #2
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
You fucked up man.. cs turbo is equal or better than the gt3071. Why would you sell the cs without knowing how the gt performs?
Are you saying YOU have built block? In that case go with a gtx3076
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 06-06-2016, 07:51 AM   #3
I've been told that CS turbo is really unstable
 Old 06-06-2016, 07:43 AM   #4
ATP or Garrett will have compressor maps for you to reference for flow data.
Generally 1lb/min=10hp. Whether or not you have air flow and fuel to get those numbers, is a different question entirely.
Clutch questions for my Mazda speed 6 Williamwillis MazdaSpeed 6 - How-To's 7 04-28-2015 07:10 AM
Noob questions about 6 speed trans Damkid MazdaSpeed 3 - Engine, Transmission & Driveline 25 12-27-2014 06:16 PM
New here and many questions for a 2007 speed 3! Brokenwings Mazdaspeed3/6 General Discussion 36 11-24-2013 12:47 AM
Page generated in 0.24916 seconds with 22 queries
