 Old 10-20-2009, 10:47 PM   #1
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
Default GT3076 owners please help
On the top of the stock turbo u have that steel oil line that bolts to it. The part on the stock turbo it threads into looks very deep But on my GT3076 that same hole for the oil feed is very shallow and has a weird looking penis head thing in it. It to me does not look like my stock one will mate up to it or will it?? the bolt looks too long? do i need a different bolt?? It is the mazdaspeed specific Gt3076 turbo. its used so i don't know if i got all the hardware i need. I know its a direct bolt on but it does not look like that stock metal oil line will fit. I have not tried it cause my manifold is not here. Again this is the oil line on the TOP. The one on the bottom has the braided line. it has 2 straight flanges so I'm assuming it needs to be bent around at should fit. I just need to know everything i can about this install so if i need to order shit i can. thanks
 Old 10-21-2009, 09:56 AM   #2
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Here is a link that may help
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 10-21-2009, 06:58 PM   #3
18psiWhiteMS3
Lurkers
Posts: n/a
the link definitely helps but is not specific enough to let me know if im using the stock banjo bolt for the gt3076 for the top oil line. anyone know???
 Old 10-21-2009, 07:18 PM   #4
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
call ATP and order a new one.. me thinks its different. (not 100% sure)
2008 STi
Intake
Turboback
AP
 Old 10-21-2009, 08:36 PM   #5
Captain
Ugh, from the thread i copied lol:
Here's your oil in and coolant out. You'll need the COOLANT OUT banjo bolt and the OIL IN banjo bolt
This is the bolt required for using the stock oil feed line with the banjo on it: Make sure you get the washers too.
This link doesn't work, but contact ATP for the right part number
http://www.atpturbo.com/Merchant2/me...egory_Code=BCS
from whoosh's follow up on the OP:
first off
none of the oem turbo banjo bolts will thread in the ATP turbo...
you can and will use the banjo (round part) for the coolant and oil feed but the banjo bolt and 2 washers should have been screwed in the turbo when received
... the OEM oil feed banjo again is used but the banjo bolt is a different thread and you need that
Long story short, you need a NEW oil feed banjo bolt, atp has them, and you want them.
www.permtuning.com
 Old 10-22-2009, 09:37 AM   #6
18psiWhiteMS3
Lurkers
Posts: n/a
ok
done! gt3076 samsel450r MazdaSpeed 6 - Engine, Transmission & Driveline 122 11-09-2009 04:35 PM
gt3076 and restrictor pill 18psiWhiteMS3 MazdaSpeed 3/6 - Turbo Induction 43 10-21-2009 03:12 PM
411whp with gt3076 @ 25psi... howd he do it phailerider MazdaSpeed 3/6 - Dyno Sheets/Discussions 63 01-05-2009 01:32 PM
More proof that Mazda RX-8 owners want to be Ferrari owners Haltech Automotive News 0 06-11-2008 07:40 AM
Page generated in 0.25840 seconds with 21 queries
