Like Tree3Likes
 Old 09-25-2013, 08:31 AM   #1
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Default Headlight Velocity Stack Mod
Intake Air Temps have always been an issue with my car. Normally they are ~20* F or above Actual Air Temps. To lower IATs for track days I would usually remove the driver side headlight. I got tired of this. I thought of trying to route my intake in a way to pull in cold air but a FMIC and windshield washer relocation made this impossible. Packed engine bay is packed. There were only a couple options left. Fabricate some ducting that would route air from the front grille or punch a hole in the headlight. The headlight option was more realistic. It took me some time to find the time and spare headlight. Anyways here is what I did.
Ordered parts from @SPEEDPERF6RMANC3; thanks to @superskaterxes;
4" velocity stack
4" x 1' coupler
4" clamp
Tools needed:
4.25" hole saw - 3 Piece Large Diameter Bi-metal Hole Saw Set
drum sander attached to cordless drill - 4 Piece Quick Change Sanding Drum Set
plyers - used for breaking off some of the plastic
Drill
Air compressor with blower nozzle attachment
No need to bake the headlight. Just find the center of the high beam and drill a hole making sure the hole will be level and perpendicular to the front of your car. User your pliers to break off pieced of plastic that get in your way...or drill straight through it. On the back side you will do essentially the same thing but you need to break away the plastic wire harness so it stays in tact. Once the harness is detached from the housing you can tuck it inside the headlight housing to prevent damage from the drilling.
This is what it looks like after using the 4" hole saw.
Next it's time for the 4.25" hole saw. This is the hard part because it barely clears the inside plastic housing of the headlight. Use the drum sander to clean up your edges and to make adjustments. After you have test fitted the 4" x 1' coupler and everything looks right, clean up the headlight. Working with plastic is messy and there are lots pockets for debris to get trapped inside the headlight. If I had to do this over again I would have tapped off the inside area of the headlight to minimized dust and plastic shavings from entering other areas. Don't attach the velocity stack until the head light is on the car because the bumper won't fit.
IATs are about 10-15*F lower on average while driving at speed of 25 mph +. Looks a little goofy but works!
What I haven't done yet is seal the headlight. I plan on buying some clear silicone adhesive. Maybe this stuff...
http://www.mscdirect.com/product/025...S&026=nv&025=c
Code Monkey and trancehead like this.
The Following 22 Users Say Thank You to RichieRichness For This Useful Post:
6ixof1 (09-25-2013), atvfreek (09-25-2013), BigRedSpecial (09-25-2013), Bolted6 (11-30-2013), breakfstincluded (09-25-2013), BrianB6 (09-25-2013), Code Monkey (09-25-2013), CWP_MS3 (09-25-2013), Downmented (09-25-2013), Easter Bunny (09-25-2013), ink28 (09-25-2013), J'sSpeed3 (09-25-2013), Jh8909 (09-25-2013), KusteLokal (09-25-2013), Kyle Undefined (09-25-2013), Quigs (09-25-2013), Realgib3 (09-25-2013), SofaKingAwesome (11-30-2013), trancehead (09-25-2013), Turbo_Steve (09-25-2013), Vader (09-25-2013), Voltwings (09-25-2013)
The Following User Says NO Thank You to RichieRichness For This Un-useful Post:
Bucker (09-25-2013)
 Old 09-25-2013, 08:42 AM   #2
Turbo_Steve's Avatar
Posts: 944   (View Stats)
This is pretty cool!!! Nice work.
Soon to come.
WHO KNOWS? A.D.D. FTW!
 Old 09-25-2013, 09:16 AM   #3
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
I would just go ahead and glass it in. Something like these-
Unless its hooked directly to the intake I would venture to say that the velocity stack probably isn't doing all that much above what just a headlight modified like the above headlights would do.
The Following 11 Users Say Thank You to El_Diablo For This Useful Post:
alphasaur (11-29-2013), Bucker (09-25-2013), Chimmike (09-25-2013), dan7225 (09-25-2013), Downmented (09-25-2013), J'sSpeed3 (09-25-2013), Jh8909 (09-25-2013), JTMS3 (09-25-2013), mxlplx71 (09-25-2013), racingrayson (12-02-2013), RichieRichness (09-25-2013)
 Old 09-25-2013, 09:22 AM   #4
Groans: 35
The theory is that the velocity stack is gathering more air than if I was to glass it in. It will also reduce turbulence.
The Following User Says Thank You to RichieRichness For This Useful Post:
Mizzle (09-25-2013)
 Old 09-25-2013, 09:25 AM   #5
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Do you hook it right to the intake at the track, without a filter?
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 09-25-2013, 09:28 AM   #6
6ixof1's Avatar
Posts: 700   (View Stats)
Nice write up!
Black Mica Mazdaspeed 6
The Mad Scientist Tunings
The Following User Says Thank You to 6ixof1 For This Useful Post:
 Old 09-25-2013, 09:30 AM   #7
Groans: 35
That was my original plan but no. I think just having the air dumping into the engine bay right in front of the intake is good enough. I can take pics tonight to show you.
 Old 09-25-2013, 09:34 AM   #8
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Monocle MS6.
The Following 8 Users Say Thank You to Enki For This Useful Post:
breakfstincluded (09-25-2013), Chimmike (09-25-2013), Easter Bunny (09-25-2013), El_Diablo (09-25-2013), kby (09-25-2013), Kyle Undefined (09-25-2013), RichieRichness (09-25-2013), trancehead (09-25-2013)
 Old 09-25-2013, 09:40 AM   #9
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Such a classy gent!
Funny thing is if you went bi-xenon, you could still be legal...
The Following 4 Users Say Thank You to Mizzle For This Useful Post:
BigRedSpecial (09-25-2013), Easter Bunny (09-25-2013), Kyle Undefined (09-25-2013), RichieRichness (09-25-2013)
 Old 09-25-2013, 09:54 AM   #10
lilred's Avatar
Posts: 5,792   (View Stats)
In b4 bird in engine bay...
Haha hey if it functions that's all that matters
tapafuck
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
The Following 7 Users Say Thank You to lilred For This Useful Post:
amggilly305 (09-25-2013), Code Monkey (09-25-2013), derek13p (09-25-2013), El_Diablo (09-25-2013), Kyle Undefined (09-25-2013), PhillyCheese (11-30-2013), RichieRichness (09-25-2013)
 Old 09-25-2013, 10:02 AM   #11
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
Groans: 56
I had the same thought about a bi-xenon setup
Needed: Driver mod
 Old 09-25-2013, 10:05 AM   #12
Tokay444's Avatar
Groans: 793
If it's not hooked directly to intake, then I don't see how having less turbulence will be beneficial, since the filter will just mitigate the effect of the stack.
I like the idea a lot, but think glassed in would be cleaner and server the same function.
Demodded.
The Seals
The Following 12 Users Say Thank You to Tokay444 For This Useful Post:
alphasaur (11-29-2013), amggilly305 (09-25-2013), breakfstincluded (09-25-2013), Bucker (09-25-2013), Chimmike (09-25-2013), daafisch (09-25-2013), Downmented (09-25-2013), Easter Bunny (09-25-2013), El_Diablo (09-25-2013), Kyle Undefined (09-25-2013), RichieRichness (09-25-2013), Spiral1183 (11-30-2013)
 Old 09-25-2013, 10:09 AM   #13
Groans: 35
more turbulence = less air making its way into the engine bay. The VS focuses the air. But hey I might still attach a filter on the end of this thing and make a custom intake lol
Velocity_stack Velocity_stack
MonstaSpeed6 (09-25-2013)
 Old 09-25-2013, 10:14 AM   #14
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
if the VS is directed right at the filter it will help straighten the air to be focused right around the filter vs. just shooting cold air all over the engine bay
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 09-25-2013, 10:15 AM   #15
Tokay444's Avatar
Groans: 793
If you put that fucker right to the intake, that's a win. Put a big turbo on it too.
Demodded.
The Seals
Downmented (09-25-2013), Kyle Undefined (09-25-2013)
 Old 09-25-2013, 10:17 AM   #16
El_Diablo's Avatar
Groans: 769
Turbulence isn't always a bad thing and as has been said is mitigated by not being connected directly to the intake.
 Old 09-25-2013, 10:25 AM   #17
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Stop bein a little girl. Fuck an intake cone. Put some thin "open" mesh shit in the middle of the pipe if you're so worried about that damn bird. You wanna go fastz like teh supras right?
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
The Following 3 Users Say Thank You to CWP_MS3 For This Useful Post:
Downmented (09-25-2013), El_Diablo (09-25-2013), Kyle Undefined (09-25-2013)
 Old 09-25-2013, 10:35 AM   #18
Groans: 35
hahh zero fucks given about birds. I neeed dat 2JZ w/nas swap.
CWP_MS3 likes this.
The Following 9 Users Say Thank You to RichieRichness For This Useful Post:
CWP_MS3 (09-25-2013), derek13p (09-25-2013), Downmented (09-25-2013), J'sSpeed3 (09-25-2013), jk_ms3 (09-25-2013), jreiden1 (11-30-2013), Kyle Undefined (09-25-2013), Mizzle (09-25-2013), trancehead (09-25-2013)
 Old 09-25-2013, 10:43 AM   #19
BrianB6's Avatar
Posts: 400   (View Stats)
Its Monocle Man Mazda
2006 - MS6 - Dead RIP
The Following User Says Thank You to BrianB6 For This Useful Post:
 Old 09-25-2013, 10:52 AM   #20
Groans: 35
It may server the same function but not as efficiently as it would with the VS
 Old 09-25-2013, 10:52 AM   #21
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
I'd do mesh right behind the headlight for large particles and then an inline filter behind it and plumb it right into the intake.
The Following 5 Users Say Thank You to helmetface For This Useful Post:
08cosmic3 (11-29-2013), Kyle Undefined (09-25-2013), RichieRichness (09-25-2013), Tokay444 (09-25-2013), Voltwings (09-25-2013)
 Old 09-25-2013, 10:54 AM   #22
Tenchix's Avatar
Posts: 450   (View Stats)
Tenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the world
You should make it bigger, cut out the fake little light to. Hell just cut out all the plastic that's not needed. tons more air flow.
Tenchix is offline   Reply With Quote
 Old 09-25-2013, 11:40 AM   #23
Groans: 56
Hook it up to intake, put some Frogskinz on it and call it a day
Needed: Driver mod
The Following User Says Thank You to BigRedSpecial For This Useful Post:
 Old 09-25-2013, 11:54 AM   #24
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Why not do some testing? It would be simple to do 5 tests to watch the effects:
1) closed headlight with your normal intake setup
2) open headlight no vs normal intake setup
3) open headlight with vs and normal intake setup
4) open headlight no vs with direct hookup to intake pipe
5) open headlight with vs with direct hookup to intake pipe
Because right now, that shit screams rice without a shred of evidence to suggest that it produces additional power. I think it's a cool idea if it works, though!
-06 MS6
-Corn fed 07 MS3 - Sold
The Following 13 Users Say Thank You to phate For This Useful Post:
BigRedSpecial (09-25-2013), derek13p (09-25-2013), Downmented (09-25-2013), El_Diablo (09-25-2013), helmetface (09-25-2013), kritz (09-25-2013), KusteLokal (09-25-2013), Kyle Undefined (09-25-2013), lilred (09-25-2013), NJSPEED3 (09-25-2013), RichieRichness (09-25-2013), TiGraySpeed6 (09-25-2013), Tokay444 (09-25-2013)
 Old 09-25-2013, 12:18 PM   #25
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Really appreciate something new thinking for the 6.
Really appreciate colder temps (IAT's)
So, erm...., yeah, whaddya do when it rains?
Seems to me that there has been much talk about not running CAI's, and this takes essentially every problem that a CAI has and multiplies them by ten.
and, apologies, but, it's seriously goofy looking too
340hp / 371tq
 Old 09-25-2013, 12:23 PM   #26
manila's Avatar
Posts: 1,767   (View Stats)
I like the fact it keeps IAT's lower, but the look is a little too obnoxius for me.
All you need to do to finish it up is with this!:
'12 MS3 Black Mica w/ Tech
 Old 09-25-2013, 01:39 PM   #27
Groans: 35
I can do some legit testing in a couple weeks when I get back from travel. 0 fucks given about looks. This is only for the track. I was fearful of being pulled over and of driving home from the track with one headlight. Also, it was time to try something new.
The Following 3 Users Say Thank You to RichieRichness For This Useful Post:
El_Diablo (09-25-2013), manila (09-25-2013), TiGraySpeed6 (09-25-2013)
 Old 09-25-2013, 01:46 PM   #28
Aw hell man, Because Racecar works for me!
All Go!
340hp / 371tq
 Old 09-25-2013, 01:48 PM   #29
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
this is my very first thought lol
 Old 09-25-2013, 02:19 PM   #30
Groans: 35
All Go!
Livin life a qtr mile at a time yo!
Sent from my iPhone using RichieTalk
 Old 09-25-2013, 03:37 PM   #31
Mizzle's Avatar
Groans: 324
You better put a mustache and monocle chain on that shit.
Please attach it to the intake next. I feel like it'll help a lot at high speed - true ram-air type thing going on.
For anyone that wants to see it glassed in, it would be less effective. If anything, just paint it car color so it hides a bit.
The Following User Says Thank You to Mizzle For This Useful Post:
 Old 09-25-2013, 03:51 PM   #32
Voltwings's Avatar
Posts: 3,713   (View Stats)
inline air filter? If not carefully done id see if wreaking havoc on a Maf sensor, but hell, could very well be awesome.
Could also incorporate an airbox, assuming you were able to get enough outside air to matter.
http://www.jegs.com/i/Spectre/865/98...ductId=1902166
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 09-25-2013, 03:59 PM   #33
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
But will it make you go 11's
www.tunedbynishan.com
Downmented (09-25-2013), RichieRichness (09-25-2013)
 Old 09-25-2013, 04:32 PM   #34
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Ultimate sleeper mod FTW.
I feel like if I got drunk and I walked by your car I'd probably pee in that.
Honestly, its pretty cool. That is some cold high pressure air, it would be great if you could devise a way to couple that through an inline filter and the MAF body.
MINI H1 6.0 - CAR LED TAILS
El_Diablo (09-25-2013), RichieRichness (09-25-2013)
 Old 11-29-2013, 01:23 PM   #35
racingrayson's Avatar
Posts: 190   (View Stats)
racingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the worldracingrayson is the leader of the world
You do realize that cork sport sells a fmic system that does this without being externally obvious? My IATs are almost always within a couple degrees of ambient.
racingrayson is offline   Reply With Quote
The Following 2 Users Say NO Thank You to racingrayson For This Un-useful Post:
breakfstincluded (11-29-2013), Downmented (11-29-2013)
 Old 11-29-2013, 01:49 PM   #36
helmetface's Avatar
Groans: 219
CS's FMIC is a joke.
The Following 3 Users Say Thank You to helmetface For This Useful Post:
breakfstincluded (11-29-2013), Downmented (11-29-2013), RichieRichness (11-30-2013)
 Old 11-29-2013, 02:03 PM   #37
dubtastic's Avatar
Posts: 204   (View Stats)
dubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond reputedubtastic has a reputation beyond repute
Groaned at 44 Times in 13 Posts
Not the sexiest mod, but hot damn! Points for going balls deep and wrenching on your own rig. It's so steampunk and gentleman at the same time!
dubtastic is offline   Reply With Quote
The Following User Says Thank You to dubtastic For This Useful Post:
 Old 11-29-2013, 02:55 PM   #38
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
You do realize that you sound retarded right?
700HP CLUB
11.479@124mph
#DIX
The Following User Says Thank You to Downmented For This Useful Post:
 Old 11-29-2013, 03:17 PM   #39
alphasaur's Avatar
Posts: 2,847   (View Stats)
Groans: 235
Really want to like this but I can't.
I'm going to agree with others and say that the vs isn't doing much not being directly ducted into the intake.
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/lol nator.
The Following 2 Users Say Thank You to alphasaur For This Useful Post:
El_Diablo (11-30-2013), RichieRichness (11-30-2013)
 Old 11-30-2013, 04:12 AM   #40
Groans: 35
Meh
alphasaur (11-30-2013)
Anyone drive test an ST? Does it stack up? [R]usty Gen2 MS3 General Discussion 92 07-30-2013 06:17 PM
Video: How does Ferrari's new F12 Berlinetta stack up against the 599 GTO? Haltech Automotive News 0 08-05-2012 06:10 PM
Put a BLOX velocity stack on my intake MCG89 2010 MS3 - Engine, Transmission & Driveline 14 12-25-2010 11:14 AM
Page generated in 0.59930 seconds with 45 queries
