 Old 01-31-2015, 08:13 AM   #1
11ms3can's Avatar
Posts: 6   (View Stats)
11ms3can is an unknown quantity at this point
Default Help
just wondering if anyone can help me figure out why my 2011 MS3 won't boost over 7psi. everything was fine yesterday and I was getting the usual 15+ psi but when I went to drive the wife to work this morn it wouldn't boost over 7psi. drove around for and hour to make sure it was nice and warm as it is currently -20 C and there was no change to the boost pressure. any ideas what my problem is?
11ms3can is offline   Reply With Quote
 Old 01-31-2015, 08:27 AM   #2
udntknw's Avatar
Posts: 1,062   (View Stats)
Groaned at 9 Times in 7 Posts
Any tuning device that can log? Or maybe Bluetooth that you can run torque on? Regardless it sounds like you have a massive leak.
What's your mod list?
Any recent work done?
Check your boost tubes from turbo to intercooler, intercooler to throttle body.
Check that the vacuum line is still on the bypass valve.
Can you hear any air rushing?
**Old Motor**
Best trap speed - 112mph
**New Motor**
Best trap speed - 112.5
 Old 01-31-2015, 08:30 AM   #3
11ms3can's Avatar
car is bone stock 24000 km on it and I don't hear any air rushing at all
 Old 01-31-2015, 08:38 AM   #4
udntknw's Avatar
I assume then, you are basing boost levels off of the stock gauge?
**Old Motor**
**New Motor**
 Old 01-31-2015, 08:57 AM   #5
btstarcher's Avatar
Posts: 4,852   (View Stats)
Boost leak.
SnailTune in progress
The Following 2 Users Say Thank You to btstarcher For This Useful Post:
kenny7821 (02-25-2015), SofaKingAwesome (02-11-2015)
 Old 01-31-2015, 08:58 AM   #6
11ms3can's Avatar
yea stock gauge
 Old 01-31-2015, 09:11 AM   #7
Shwa's Avatar
Posts: 322   (View Stats)
Time to start checking clamps. Isn't the stock tip prone to falling off?
Also your stock "boost gauge" is more of a throttle position gauge. Otherwise I'm on "15 psi" all day...
 Old 01-31-2015, 10:30 AM   #8
CFI2008's Avatar
Posts: 259   (View Stats)
CFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the worldCFI2008 is the leader of the world
I pulled mine off with out loosening the clamps lol
CFI2008 is offline   Reply With Quote
 Old 01-31-2015, 12:29 PM   #9
Shwa's Avatar
Lol that's what I'm talking about, Mazda knew we were going to pull that pos off anyway so they barely put it on.
I'm no scientist but if it's past the maf sensor it wouldn't read it unless it was bad enough to effect your a\f ratio to throw a lean or rich at idle code.
 Old 01-31-2015, 09:17 AM   #10
11ms3can's Avatar
would I not get a check engine light if there was a leak
 Old 01-31-2015, 09:58 AM   #11
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
No.
If you have a small/gross leak that shifts your fuel trims dramatically then it may pop a cel.
You most likely have a clamp that isn't tight enough, and while under boost, is letting enough air out to not allow you hit the boost tgt's. (as mentioned above)
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
 Old 01-31-2015, 02:01 PM   #12
shamie's Avatar
Posts: 952   (View Stats)
Sounds like your only on spring pressure.
 Old 01-31-2015, 02:04 PM   #13
spals's Avatar
Posts: 305   (View Stats)
spals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the worldspals is the leader of the world
Already mentioned, but it's most likely a leak between your turbo and throttle body
CP Pistons 88mm, Manley H-Beams, Balanced Crank
BNRS3V2, Cobb Catted DP, ETS TMIC, 3.5" JBR Alum Intake, AT HPFP
GS EBCS, 3 Bar Map, JBR 88 RMM, DM OCC, TIGs, BSD+Baffle
SBC Stage 2 Daily, JBR RSB, Koni Yellow, Konig Miligrams 18x8.5, Nitto NT-05 245/45
Spalsbuilt-Freektuned
spals is offline   Reply With Quote
 Old 02-01-2015, 10:17 AM   #14
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Stock tune is load based.
Considering you've reported your local temp as -4F, I suspect the ECU is not allowing it to boost any higher or the calculated load is near target and higher boost psi isn't needed.
340hp / 371tq
btstarcher (02-01-2015), ms6mil (02-01-2015), tegxsi (02-11-2015)
 Old 02-11-2015, 08:50 AM   #15
11ms3can's Avatar
brought it into Mazda and it's a faulty waste gate causing the lack of boost
 Old 02-11-2015, 09:30 AM   #16
CFI2008's Avatar
At least it was not causing overboost.
 Old 02-11-2015, 09:36 AM   #17
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
I think you still won't hit full boost on really cold days. That's just part of the stock tune protecting you from overloading. Cold air is more dense so less boost pressure is needed.
Think about it if it happens again... Does the car feel any weaker/slower when boost gauge isn't fully pegged to the top?
2018 Audi RS3
2007 Acura TSX 6MT
 Old 02-24-2015, 10:09 AM   #18
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
came in too late...
I WAS going to say though that you can't handle the boost but it turned out to be your WG....
Performance:
Stratified Tune in progress
Page generated in 0.36615 seconds with 29 queries
