 Old 05-12-2014, 08:05 AM   #1
mrQQ's Avatar
Posts: 1,164   (View Stats)
mrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the world
Default Help with some BNR S3 info
Hi,
the vendor isn't replying to my emails for some reason, and I need some info asap..
1) I have replaced the banjo bolt on the K04 with smaller diameter one to combat smoke. Now I'm installing the S3. Can I keep the smaller hole bolt or do I need to find original one? If so, and if I can't find it, what specs of banjo bolt do I need for the S3?
2) The turbo management - K04 had two nipples on the wastegate actuator, one going to turbo vacuum, one to the EBCS I think. The new S3 only has one nipple. Does that mean that I need a T splitter to connect the original ECBS?
3) Do I need a restrictor pill if I use OEM EBCS? If so, what specs?
Damn, how could I miss all these questions earlier...
Thanks guys!!
mrQQ is offline   Reply With Quote
 Old 05-12-2014, 08:13 AM   #2
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
There's info in this thread you should look at. Especially if you have a v2.
New BNRS3 Housing
The bnoon bolt should work fine as I was once told by Bryan to use it.
Mods: stock
 Old 05-12-2014, 08:40 AM   #3
mrQQ's Avatar
Which version of the bolt - the OEM one or the restricted one?
 Old 05-12-2014, 08:42 AM   #4
faeker's Avatar
Groans: 731
Bnoon is the restricted bolt.
now with three times the hate
Mods: stock
mrQQ (05-12-2014)
 Old 05-12-2014, 08:45 AM   #5
mrQQ's Avatar
well, at least one good news about the BNR for now...
 Old 05-12-2014, 08:56 AM   #6
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
The bnoon bolt restricts oil. Being as oil is what lubricates the turbo and keeps it from imploding, you should use the correct banjo bolt(oem) to ensure it receives the correct amount of oil. On the k04 the restriction is a "bandaid" fix to combat leaking seals(less oil means that it wont push past the seals as easily) using the banjo on the bnr means you are essentially starving the turbo of oil for no reason.
As for boost control, Im almost sure you need to upgrade to a 3 port system. Oem waste-gate actuator has a boost reference at the bottom and the bcs goes to the top, with the bnr putting a "t" on the line to your oem controller means that you will be introducing boost directly into it on a port that is not meant for direct boost.
TEAM LUXURY
 Old 05-12-2014, 08:59 AM   #7
faeker's Avatar
Groans: 731
^ is correct about the stock bolt vs bnoon. I wouldn't have mentioned it though hadn't Bryan said to use it. Before you do so, I would get confirmation directly from Bryan though. What was good for one may noT be good for another.
Mods: stock
Anybody have info on these? The Nut 2010 MS3 - Wheels & Tires 10 04-29-2013 12:36 AM
Looking for info on these... hcbr929rr2 2010 MS3 - Wheels & Tires 2 12-15-2011 08:18 AM
Any info if these will fit? SlaminRC17 Wheels & Tires - SILVER 0 10-31-2011 06:07 PM
Page generated in 0.26884 seconds with 22 queries
