  • 1 Post By alien_sporez
  • 1 Post By MSMS3
 Old 07-04-2011, 04:42 AM   #1
misiekwaw's Avatar
Posts: 49   (View Stats)
misiekwaw has much to be proud ofmisiekwaw has much to be proud ofmisiekwaw has much to be proud ofmisiekwaw has much to be proud ofmisiekwaw has much to be proud ofmisiekwaw has much to be proud ofmisiekwaw has much to be proud ofmisiekwaw has much to be proud of
Default How much HP gain from catted DP?
Hi!
Now in my car I have custom CBE with TP all 2'75, SRI with TIP, Precission FMIC and mazdaEdit tune. I'm currently thinking about catted DP. How much HP gain I can count from catted DP with stock K04? Now I have about 320 crank.
Sunlight Silver 2007 Mazda 3 MPS by DISI-tune 303whp 352lbs
mazdaEdit tune, StreetShadows Garage 3" catless DP, 2,75" cat-back and test-pipe, HTP 3" Intake with custom airbox, Precision FMIC with StreetShadows Garage 2,5" piping, KMD Internals, Forge BPV, ACT 6 puck, OZ Ultraleggera 18x8, Kumho KU36 225/40R18, Bilstein B8, Eibach springs, James Barone Racing Rear Sway Bar, Corksport Front Lower Arm Bar, AWR Rear Engine Mount, James Barone Racing Passenger Side Engine Mount, TWM shifter Bushings, Hawk HPS F/R, Goodridge Brakelines, Motul RBF600, MazdaSpeed rear wing, STRI Racing gauges with custom pod
misiekwaw is offline   Reply With Quote
 Old 07-04-2011, 05:06 AM   #2
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I read just last night that 320 crank hp is about the max the stock turbo can blow.
Don't quote me on that. It's just something I scanned over. Seems a little low, but then again, we hais tiny tarbo
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 07-04-2011, 06:25 AM   #3
alien_sporez's Avatar
Posts: 1,199   (View Stats)
alien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the worldalien_sporez is the leader of the world
Based on the CP-E website, a catted DP will add 30hp and 40tq. MazdaSPEED3 3" SS Downpipe System | Custom Performance Engineering
That being said, I suggest you upgrade your fuel pump internals before you do anything else. With your mods, you're probably getting close to the max flow capacity of the stock fuel pump. Adding a less restrictive DP with your stock fuel pump will probably result in a lean condition, which will definitely result in fail.
● 2011 Jaguar XFR ● Full Resonator Delete ● Mina Cat-Back Exhaust ● Staggered Giovanna Portofinos ●
● 2010 Mazdaspeed 3 - GONE ●
alien_sporez is offline   Reply With Quote
 Old 07-04-2011, 07:05 AM   #4
Docnox's Avatar
Posts: 1,435   (View Stats)
Docnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the world
Groans: 35
It's probably the biggest power increase you can get out of the stock turbo.
'06 Speed 6
Black Mica
Mazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe,
3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp
Altered Customs fmic, Autotech fp internals
Cobb AP, Stage 2+ 93 tweaked
Centric blanks, EBC red pads
Lotek center gauge pod: AEM wideband, Autometer boost and volts
Tints, blacked emblems, spec-v front lip, Shark fin
Redline MT-90, ITV-22s, Matt Damond OCC
13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap)
DO Meth kit waiting on install
Docnox is offline   Reply With Quote
The Following User Says Thank You to Docnox For This Useful Post:
AZSPEED3 (07-05-2011)
 Old 07-04-2011, 08:04 AM   #5
misiekwaw's Avatar
OK, but how much more from my 320 crank? I dont believe in 30hp from DP in my case.
 Old 07-04-2011, 08:07 AM   #6
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
Dyno before
Dyno after
Every car is different and responds differently to mods.
Tapawhat?
The Following 6 Users Say Thank You to 08.5MS3 For This Useful Post:
alien_sporez (07-04-2011), Chimmike (07-05-2011), Easter Bunny (08-24-2015), karl-hungus (07-05-2011), predapio (07-04-2011), Speed3eak (07-06-2011)
 Old 07-04-2011, 08:10 AM   #7
2011speed's Avatar
Posts: 1,497   (View Stats)
to the crank? you sound like u just wanna brag about numbers. its what u put down to the wheels what matters. so after all that/tuned ud be 280-310 whp(including downpipe)
FreeKtuned
fitty fitty
The Following 2 Users Say Thank You to 2011speed For This Useful Post:
alien_sporez (07-04-2011), Easter Bunny (08-24-2015)
 Old 07-04-2011, 10:15 AM   #8
^^^that^^^
Dyno before
Dyno after
Tapawhat?
^^^and that^^^
So, exactly how do you know the HP at the crank? You pulled the engine and ran it on a static dyno? Because unless you did that, your HP number is bullshit to begin with. If you're just going by the factory declaration of HP as your baseline, and then "adding" the estimates of the parts manufacturers, you're magnifying the bullshit factor exponentially. Basically, you want to measure how big your cock is in centimetres instead of inches so you can say "My cock is really long, it's 42!!!"
The factory HP number is just an estimate, not a guarantee. You could have a poorly built engine that makes less, or you could have a "factory freak" that makes more. Add to that environmental variables, differences in tire/wheel combinations, modifications, etc. and your attempt at saying "My car makes 340 HP" is absolute fiction. Because just adding the "added HP" estimates from the manufacturer can't be done, because it's not cumulative. You argument is flawed to begin with: "Part 1 adds 30 HP, and Part 2 adds 20 HP, so if I install both part 1 & 2 I will add 50 HP." It doesn't work like that in real life. That is how ricers get their ridiculous ideas their cars are powerful, but they get their asses kicked by stock KIA's. Not all parts interact, and increasing the flow of air/fuel/etc by adding one part might reveal a limiting factor in another part.
Two pieces of advice, brownie:
1) DONATE before @rodrigo shows up and turns you into a crying sack of shit
2) Pay $100 and get a baseline dyno. Install part. Dyno again. Subtract HP from #1 from #2, and you will know how much that part added in HP.
calizoomzoom likes this.
Last edited by alien_sporez; 07-04-2011 at 10:21 AM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to alien_sporez For This Useful Post:
BeastMS3 (08-02-2011), manelscout4life (07-04-2011)
 Old 07-04-2011, 10:44 AM   #9
frodaddyweez's Avatar
Posts: 988   (View Stats)
frodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the world
Exhibit A:
I was fully bolted, minus mani, and my baseline dyno for my Cobb tune was 244whp and 275wtq. On a mustang awd tho. But still. Mods are only half the story btw...you need a good tune too
2009 Mazdaspeed3: PTE 5857 25psi etuned by tooslow2010 --> SOLD
2011 Mustang Shelby GT500 w/SVTPP: 2.3L Trinity TVS w/2.4" VMP pulley, L&M NSR cams, JLT 123mm Intake, FRPP CobraJet Twin 65mm Throttle Body, 56# Injectors, VMP Fuel Pump Booster, AFCO Dual Pass Heat Exchanger, FRPP L Springs, BMR Adjustable Panhard Bar, Shaftmasters Aluminum One-piece Driveshaft, Lethal Performance Catless H-Pipe, Flowmaster Outlaw Axleback, 315 NT05r's
Lund Tuned 683whp/622wtq 11/11/16
Upcoming mods: Full-length Headers and ID1300s for E85
1995 Mazda Miata: Stock (daily)
frodaddyweez is offline   Reply With Quote
 Old 07-04-2011, 10:54 AM   #10
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
If you really want to know how much performance is gained by mods, go do a bunch of 1/4 mile runs before and after.
 Old 07-05-2011, 06:41 AM   #11
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Where are you going to get Dyno runs for $100? IS that $100 and the Best Blow Job of your/their lives?
Every local place I called gave me quotes for 5 times as much and then when I started talking about protunes they went into how the Speed3's are so terribly difficult to tune etc..
One of these shops were COBB recommended...bitches!
 Old 07-05-2011, 07:30 AM   #12
darkcambria's Avatar
Posts: 816   (View Stats)
darkcambria is the leader of the worlddarkcambria is the leader of the worlddarkcambria is the leader of the worlddarkcambria is the leader of the worlddarkcambria is the leader of the worlddarkcambria is the leader of the worlddarkcambria is the leader of the worlddarkcambria is the leader of the worlddarkcambria is the leader of the worlddarkcambria is the leader of the worlddarkcambria is the leader of the world
The local shop we go to does 3 runs for $50. He'll even usually let you run a few more times if you want to tweak your tune in between runs.
darkcambria is offline   Reply With Quote
The Following User Says Thank You to darkcambria For This Useful Post:
alien_sporez (07-05-2011)
 Old 07-05-2011, 07:52 AM   #13
helmetface's Avatar
Groans: 219
Just curious, where you located? I could essentially drive to the West Coast (from Boston) and back, plus tunes for the prices I'm getting out here...
I need da hook ups
 Old 07-05-2011, 08:52 AM   #14
EngineLogics.com
Local shop where I got my dynos done on my old car. Got 5 runs including a tune on a Dynamics loaded dyno for $125. Straight dyno of 3 runs (no tune) was $65.
 Old 07-05-2011, 09:06 AM   #15
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
cats are for pussies...just sayin
2015 Mazda 6
 Old 07-05-2011, 09:15 AM   #16
helmetface's Avatar
Groans: 219
EngineLogics.com
Jesus,thos prices are great.. I could probably make it to Texas in 2 days..let me see what my better half wants to do for this years vacation..muaha
*spreads legs*
*looks down*
Yup, I've got a cat.
Last edited by helmetface; 07-05-2011 at 09:15 AM. Reason: MSF Database - Automerged Doublepost
 Old 07-05-2011, 01:06 PM   #17
I need da hook ups
I'm in Lancaster PA, the shop is out near Pittsburgh. Here's their link Home
 Old 07-05-2011, 01:12 PM   #18
shawn.'s Avatar
Posts: 541   (View Stats)
shawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the world
Groaned at 22 Times in 16 Posts
nice! i'm in pittsburgh, definitely gonna head down to this place.
ATP GTX3071r// Cobb 3 Port EBCS // 3 Bar MAP // Cobb Accessport Freek Tuned // E85 Mix // JBR 3.5" Intake/TIP // Treadstone TR8C FMIC // Autotech HPFP Internals // Ported IM //C-pe Catted Downpipe // TRZ RMM // Corksport CBE // ISC Coilovers // EBC Slotted Rotors--Redstuff Pads // TWM shifter bushings // Dashhawk v2 // 6000k HIDs
Built engine--Manley H Beam Rods--Wiseco Pistons
shawn. is offline   Reply With Quote
 Old 08-22-2015, 05:00 PM   #19
Hossanngeorge's Avatar
Posts: 38   (View Stats)
Hossanngeorge has a spectacular aura aboutHossanngeorge has a spectacular aura about
Where is this place?? And what is the name of it, im not too far from you! that link isnt working for me
Hossanngeorge is offline   Reply With Quote
 Old 08-22-2015, 05:05 PM   #20
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
that thread is 4 years old
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
Mooseknuckler (08-22-2015)
 Old 08-22-2015, 06:27 PM   #21
Thepedigree13's Avatar
Posts: 608   (View Stats)
Groans: 64
Wow!!
~2013 BLACK MS3~
COBB: (APV3//Exhaust Hangers)
 Old 08-22-2015, 07:03 PM   #22
Wow, dude. Way to resurrect a old thread
Sent from my HTC M9
 Old 08-22-2015, 07:28 PM   #23
patABQ's Avatar
Posts: 164   (View Stats)
patABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond repute
A lot of inflation in 4 years. I would love dyno's for under $100.
Silver 2012 MS3 , 2007 Corvette Z06 , 2008 Hayabusa
MS3 Mods
Sure PMM, DMM, REM (all TORQ S3 Street in Stealth Black), Sure Sway Bar, JBR Sort Shifter
Cobb - AP V3 SRI, TIH, 3-port Boost Controller, SS 3” DP
Corksport TMIC
CP-E full HPFP with warranty
All Freektuned with two tunes, one for 15psi and another at 20psi
patABQ is offline   Reply With Quote
 Old 08-22-2015, 07:55 PM   #24
Wow I guess so I didn't even look at the date, lol a friend sent me the link. I was thinking that number was absurd. Thanks.
 Old 08-24-2015, 06:40 PM   #25
HaXiR's Avatar
Posts: 315   (View Stats)
HaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud of
I feel his pain, there are good old threads id like to necro! lol
2008 Ms3 Black Mica R.I.P. March 2008 - March 2016. MODS: HTP 3" intake, CX Racing FMIC with TR8 core, BNR S3, AP V3, Kozmic EGR delete, Matt Damond OCC, JBR short shift plate with bushings, HIDS, CP-E injector seals, TIG, 1 step colder plugs, Grimspeed EBCS, CS RMM, JBR passenger MM, motor craft tranny fluid, Autotech Internals
Current:
08.5 Ms3 cwp GT: Built block (sp63 4032 pistons, eagle h beams, CA625+ rod bolts/head studs, arp main studs, key'd crank, supertech 55lb valve springs, bsd delete, Block/pistons/rings/bearings WPC treated), HTP 4" intake, bnr S5 turbo (when it comes out), HTP hotside under route pipes, TR8 core, custom made cold pipes, ST intake mani, TIG, CP-E downpipe, CNT CBE, autotech hpfp, AP V3, grimmspeed ebcs, GA v3, TWM short shift assembly, JBR short shift plate, HFS-4 Meth kit, HTP front mount custom meth tank, damond motor mount trilogy, damond 3 port pcv plate, dual damond catch cans (one vented), step colder plugs, corksport injector seals, GFB bov, 51r battery, Bilstein B8 shocks, OZ ultralegga rims, custom oem clutch with Kevlar, Gen 2 trans.
2003 Mazdaspeed protégé (spicy orange); pope E manifold and DP, injen cai, PoS fmic kit, Twisted motion gt2871 turbo, aem fic-6.
HaXiR is offline   Reply With Quote
 Old 08-25-2015, 05:43 PM   #26
MSMS3's Avatar
Posts: 2,826   (View Stats)
Just in case someone new comes here looking for the answer to the question raised by this resurrected thread title:
1. Do not run an aftermarket downpipe on these cars without both a high pressure fuel pump upgrade and a tune. You will go boom.
2. The K04 stock turbo limits max power on pump gas to about 300 whp, maybe 310. No matter what combo of bolt on mods you use to get there, that is the ceiling.
A downpipe with pump internals upgrade and tune will go a long way toward getting you there. But don't think that if you are already at, say 280-290 with your tune and other mods that throwing a catless dp on will get you 330 or some shit like that with the stock turbo and pump gas. You cannot add potential gains from individual mods. It is not the sum of the individual parts.
Biglegg likes this.
kgb (08-26-2015)
 Old 08-25-2015, 06:32 PM   #27
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Place by me does 3 runs for $50, dynojet, reputable shop too.
In stock now CNT Racing Mazdaspeed 3 catted and non Catted downpipe ERZperformance ERZPerformance 325 08-04-2013 05:13 PM
Catted or non Catted dp? MSP611 MazdaSpeed 3/6 - Turbo Induction 18 11-28-2010 05:32 PM
Page generated in 0.49298 seconds with 39 queries
