Like Tree11Likes
 Old 12-03-2010, 03:16 PM   #81
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Originally Posted by Dr. FuelPump View Post
What idea did he steal? The seals? One could assume that this silver demon guy could have stolen the idea from PTP? I don't know all the details, but I recived my parts, they worked and worked well.
lol, you don't know all the details... except you know all the fucking details you idiot.
GET THE FUCK OFF OUR FORUM YOU TRASHY SLEAZEBALL VENDOR
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
The Following 11 Users Say Thank You to djuosnteisn For This Useful Post:
cpolly69 (12-04-2010), essejkcamraw (12-03-2010), gerry@ardesign (12-04-2010), jwilkins88 (12-03-2010), madvillain (12-04-2010), rigor (12-05-2010), sellers (12-03-2010), SilverDemon (12-03-2010), socks (12-03-2010), tbot (12-03-2010), triplejumper18 (12-03-2010)
 Old 12-03-2010, 03:49 PM   #82
spnkr21's Avatar
Posts: 2,827   (View Stats)
This is a pic of the injector for the powerstroke diesel. This is why you do not see failures in the diesel injector seals like we do....The injector is held captive by 2 different sets of o-rings and it looks to be bolted in place, not to mention the multiple shoulders on the nozzle. Meaning the injector has no chance of movement, which is where the problem originates from in the MZR's application. The ports on the MZR head simply does not allow the injector to held stable once the combustion pressure rises. There is about .017" of space around the base of the MZR injector.
Good find there Scott.
Yea, like Silverdemon didn't do all his homework first. Don't question msf gods.
Support our community not these other BS companies like ptp.
2012 WRX HB w/mudflaps yo!
The Following 4 Users Say Thank You to spnkr21 For This Useful Post:
djuosnteisn (12-03-2010), gerry@ardesign (12-04-2010), rigor (12-05-2010), SilverDemon (12-03-2010)
 Old 12-03-2010, 04:22 PM   #83
Amazon's Avatar
Posts: 2,679   (View Stats)
Amazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the world
Groans: 214
Groaned at 114 Times in 83 Posts
GTFO JOHN FAGGOT
Amazon is offline   Reply With Quote
The Following 5 Users Say Thank You to Amazon For This Useful Post:
djuosnteisn (12-03-2010), gerry@ardesign (12-04-2010), jwilkins88 (12-03-2010), rigor (12-05-2010), SilverDemon (12-03-2010)
 Old 12-03-2010, 06:07 PM   #84
kmac's Avatar
Posts: 1,792   (View Stats)
I don't know man,I don't think the inj seals are blowing from the .017 space and the allowance to move slightly. I personal think the factory seals suck anus and the main problem is the shit cast crows feet. I don't think It's movement,I think It's deflection due to the shit hold downs. The increased cyl pressure is causing the crows feet to flex , think with a set of billet this problem will no longer be a problem. I'm working on a set now with someone to make these and I'll see what happens. Also I do think you are an innovator and make some nice shit so keep up the good work. This platform needs people to push limits.
The Following 2 Users Say Thank You to kmac For This Useful Post:
MPSdriver (12-08-2010), SpeedSixxx (12-03-2010)
 Old 12-03-2010, 06:18 PM   #85
SilverDemon's Avatar
Posts: 3,034   (View Stats)
I have explored the billet version of the crows feet.... I have found out that it does not matter what you make the crows feet out of. It all has to do with the fulcrum of the crows foot itself. The distance of the fulcrum from the torx bolt determines the pressure applied to the injector itself. Increase the fulcrum distance from the torx bolt, and the amount pressure applied is multiplied. Since increasing the distance of the fulcrum is not an option (unless a very complicated setup is done to mill a flat on the head) stabilizing the injector in the head with a cup design while incorporating a sealing surface will be the best path to take. Give me a minuet and I will post pictures that show the movement of the injectors that damage the bore.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 4 Users Say Thank You to SilverDemon For This Useful Post:
djuosnteisn (12-04-2010), FreeFlyFreak (12-03-2010), MPSdriver (12-08-2010), rigor (12-05-2010)
 Old 12-03-2010, 06:19 PM   #86
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
SD and kmac are two very knowledgeable dudes and I'm glad we are soon to over come this problem.
i'll be ordering a set of those ford seals and hopefully when kmac completes the billet crows feet i'll be smart enough to follow...
nice work guys... SD and kmac.
The Following User Says Thank You to SpeedSixxx For This Useful Post:
kmac (12-03-2010)
 Old 12-03-2010, 06:36 PM   #87
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 6 Users Say Thank You to SilverDemon For This Useful Post:
djuosnteisn (12-04-2010), Fobio (12-03-2010), gerry@ardesign (12-04-2010), kmac (12-03-2010), rigor (12-05-2010), skeeter149 (12-04-2010)
 Old 12-03-2010, 07:43 PM   #88
kmac's Avatar
I do understand about the foot needing to be longer for added pressure ,but I don't think It's more torque needed to keep them from blowing. I believe that the foot is flexing so a different material would keep it from flexing. Which if t does flex it would cause the inj to walk. Now the pictures look like the seal was blown so long it disintegrated which would now leave plenty of room for the inj to walk around and beat the shit out of the inj hole. If the seal was absent the crows foot would now no longer have enough torque on it to keep it in place. Plus the inj is harder than the head so if it were to walk it would destroy the seat and hole. Nice pics though that shit is wrecked.
 Old 12-03-2010, 07:54 PM   #89
Any evidence of the crows foot flexing?
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 12-03-2010, 08:10 PM   #90
kmac's Avatar
Yup,I took my hood off and put a dial indicator on the inj and watched it move. No I'm just kidding . I have no proof I'm just letting u know what I think. That picture to me also doesn't look like inj walk due to inj not being held steady,it looks like the seal blew out and now u had to little torque to hold it in place as well as excess Clarence inthe inj hole. Which wto me ould cause that out come. That picture doesn't prove the inj walking due to the seal design to me.
 Old 12-03-2010, 08:18 PM   #91
Are you suggesting the seal is what holds the pressure against the crows foot? and without the seal the injector will now be loose in the bore?
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 12-03-2010, 08:52 PM   #92
kmac's Avatar
I am telling u not implying, if the seal blew out there would be more clearance in the bore and there would be less torque on the inj. It would not be loose to no torque where u could move it easily. with that much pressure on it its probably enough to walk it all over causing the damage u see in front of u.
rfinkle2 (03-15-2014), SpeedSixxx (12-04-2010)
 Old 12-03-2010, 09:26 PM   #93
[MSF STIG]
FORZDA 1's Avatar
Posts: 1,206   (View Stats)
I think you're missing the point, at least the way I see it. The FACT is that the injector is not held firmly in ALL directions and that injector MOVEMENT/rocking leads to seal failure as cylinder pressure goes well beyond OEM values. The crows foot hold-down DESIGN is likely a contributor as it doesn't fix the injector well enough, REGARDLESS of the materials used.
IMO, the OEM seal design is just fine for much higher pressures IF the injector is fixed in place and not allowed to move in ANY direction. The SD design will act as both seal and stabilizing fixture that will allow the OEM crows foot to hold the injector well enough to prevent the seal-killing motion. Just my take on the issue....
I will soon have a set of the Ford seals, which appear to be incredibly similar to spark plug gaskets in the parts photos. That tells me they are expected to "crush" to conform very similar to the OEM design.
FORZDA 1 is offline   Reply With Quote
The Following 3 Users Say Thank You to FORZDA 1 For This Useful Post:
kmac (12-04-2010), MPSdriver (12-08-2010), SilverDemon (12-04-2010)
 Old 12-04-2010, 05:44 AM   #94
hahahahaha!! OK man
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 12-04-2010, 07:15 AM   #95
kmac's Avatar
hahahahaha!! OK man
Do tour self a favor torque something down onto a shim now pull that shim out se if it is still the same. I'll bet u its different and if u don't believe that than u are smoking some shit.
 Old 12-04-2010, 07:25 AM   #96
kmac's Avatar
Ok,I got u there is no doubt in my mind he is very smart and very intuitive. I'm also sure his seals are great,but my personal opinion is the crows foot shit ass design is the main culprit and any seal that is quality made will not blow.
 Old 12-04-2010, 08:59 AM   #97
Captain
We explored the whole crow's foot avenue quite a while ago. IIRC, the thread ended with SD's new design for seals.
www.permtuning.com
The Following 6 Users Say Thank You to djuosnteisn For This Useful Post:
FORZDA 1 (12-04-2010), FreeFlyFreak (12-04-2010), gerry@ardesign (12-04-2010), rigor (12-05-2010), SilverDemon (12-04-2010), tbot (12-04-2010)
 Old 12-04-2010, 09:15 AM   #98
Ziggo's Avatar
Posts: 3,843   (View Stats)
I think we ran into a pre-load on the bolt issue. IIRC increasing the pre-load as is risks stripping the head. Any improvement would require drilling the bolt hole and installing a large steel insert so we could increase the torque and thus the preload.
Ask Me About My:
The Following 4 Users Say Thank You to Ziggo For This Useful Post:
FORZDA 1 (12-04-2010), rigor (12-05-2010), SilverDemon (12-04-2010), tbot (12-04-2010)
 Old 12-04-2010, 05:12 PM   #99
11cruzito11's Avatar
Posts: 824   (View Stats)
11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world
Groaned at 5 Times in 2 Posts
I'm back to OEM injector seals, the prototype version2 seals from pt-p that I was running one of them started to leak.
Scott, put me on the list for a set of seals from you!
11cruzito11 is offline   Reply With Quote
The Following 4 Users Say Thank You to 11cruzito11 For This Useful Post:
djuosnteisn (12-04-2010), gerry@ardesign (12-04-2010), rigor (12-05-2010), SilverDemon (12-04-2010)
 Old 12-04-2010, 05:26 PM   #100
Gotcha man!!!
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 3 Users Say Thank You to SilverDemon For This Useful Post:
11cruzito11 (12-04-2010), djuosnteisn (12-04-2010), rigor (12-05-2010)
 Old 12-04-2010, 08:51 PM   #101
Look at the pics of my leaking seal.
The Following User Says Thank You to 11cruzito11 For This Useful Post:
SilverDemon (12-05-2010)
 Old 12-04-2010, 09:47 PM   #102
Captain
cyl 3 eh? shit that bore looks pretty bad. Sorry bout the troubles man.
www.permtuning.com
 Old 12-05-2010, 01:03 AM   #103
Yeah #3 it is. What do you mean the bore looks bad?
 Old 12-05-2010, 01:09 AM   #104
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
what power you making ?? when seal blew ??
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
The Following User Says Thank You to jracer For This Useful Post:
 Old 12-05-2010, 01:14 AM   #105
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
The bore is where the seal sits.
Since the material of the seal is much harder than the aluminum material of the head it grinds away at the bore. You may need a new head that does look pretty bad Carlos sorry man. I know Scott has been looking into using a product from loctite with his seals im not sure if that will help with your issue. I wouldnt be surprised if your stock seals on #3 will leak as well. Try to mellow out your tune until you have this figured out bud.
The Following 2 Users Say Thank You to NJSPEED3 For This Useful Post:
djuosnteisn (12-05-2010), SilverDemon (12-05-2010)
 Old 12-05-2010, 10:47 AM   #106
Last time i dyno'd i did 385 but the seal has been leaking for a while now, I might just be 1 bad seal from the set, the others are not leaking.
Yea, I'm going to take it easy from now on until I get a new set of seals.
Last edited by 11cruzito11; 12-05-2010 at 10:47 AM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to 11cruzito11 For This Useful Post:
 Old 12-05-2010, 08:24 PM   #107
Tripple OG
NJSPEED3's Avatar
Groans: 113
Scott what's the loctite product that you suggested using with the seals bud?
The Following User Says Thank You to NJSPEED3 For This Useful Post:
 Old 12-05-2010, 08:43 PM   #108
Loctite 518 was the first sealant I was looking at, but it seems that permatex #2 has a higher temperature range with the same flexible/removable properties as the 518 does, it's also easier to find the permetex at auto parts stores.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
Boosted Beluga (12-06-2010), djuosnteisn (12-05-2010), gerry@ardesign (12-06-2010), jracer (12-05-2010), NJSPEED3 (12-06-2010), tbot (12-06-2010)
 Old 12-06-2010, 11:02 AM   #109
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
Should we put the loctite on both the inside and outside of the seal?
SilverDemon (12-06-2010)
 Old 12-06-2010, 02:02 PM   #110
The loctite/permetex idea was for cruzito, he had problems with one of the seals leaking. Now, I do not know how the seals were made that cruzito had, but I had suggested to him to try one of those products, he had no success with stopping the injector from bypassing a bit of exhaust gas. So, was it defect in the seal, or was the port worn too much? I do not know.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
11cruzito11 (12-06-2010), Boosted Beluga (12-06-2010), djuosnteisn (12-06-2010), NJSPEED3 (12-06-2010)
 Old 12-06-2010, 02:31 PM   #111
gerry@ardesign's Avatar
Posts: 136   (View Stats)
gerry@ardesign has a reputation beyond reputegerry@ardesign has a reputation beyond reputegerry@ardesign has a reputation beyond reputegerry@ardesign has a reputation beyond reputegerry@ardesign has a reputation beyond reputegerry@ardesign has a reputation beyond reputegerry@ardesign has a reputation beyond reputegerry@ardesign has a reputation beyond reputegerry@ardesign has a reputation beyond reputegerry@ardesign has a reputation beyond reputegerry@ardesign has a reputation beyond repute
Love my gearheads!!
Need CPE parts at a great price and fast PM me.
gerry@ardesign is offline   Reply With Quote
The Following 4 Users Say Thank You to gerry@ardesign For This Useful Post:
Boosted Beluga (12-06-2010), djuosnteisn (12-06-2010), SilverDemon (12-06-2010), tbot (12-06-2010)
 Old 12-06-2010, 02:45 PM   #112
tbot's Avatar
Posts: 2,821   (View Stats)
Groans: 40
Originally Posted by gerry@ardesign View Post
Love my gearheads!!
Can I thank this...I'm not a gear head
The Following 3 Users Say Thank You to tbot For This Useful Post:
djuosnteisn (12-06-2010), NJSPEED3 (12-06-2010), SilverDemon (12-06-2010)
 Old 12-06-2010, 11:14 PM   #113
One thing I do remember about the seals I was running is that two of them (cylinder#3 was one) the seal fit into the injector was veryyy tight. I remember PTP telling both spnkr21 and I to heat the seals a bit to be able to insert the seal in the injector. When I took off injector #3 the seal was stuck in the injector, I had to use some plyers to remove it out. Maybe seal size too small/tight?
SilverDemon (12-07-2010)
 Old 12-07-2010, 12:21 AM   #114
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
No the bolt is stretch to yield and cannot be over torqued without failure. I also spent several weeks looking for a vendor for a stud but no one makes the diameter and length needed.
The PTP seal is crap. Iirc it is flat out .002" too thin to even fill the gap between the inj and the bottom of the injector bore so its going to leak no matter what you do. Also the proper seal design is not to seal around the inj nozzle like PTP did, but to seal between the seat of the injector and the bottom of the inj bore in the head by using the clamping force of the crows feet.
2006 Mazdaspeed 6
 Old 12-07-2010, 12:43 AM   #115
I think your talking about the ptp v1's, Cruzito has the v2 which are the "cup style" seal like silverdemon's.
The Following User Says Thank You to gerry@ardesign For This Useful Post:
 Old 12-08-2010, 12:19 AM   #116
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
Lmfao @ file-to-fit PTP V1 seals
The Following 3 Users Say Thank You to madvillain For This Useful Post:
djuosnteisn (12-08-2010), SilverDemon (12-08-2010), Spoolme (12-09-2010)
 Old 12-08-2010, 03:52 AM   #117
spnkr21's Avatar
haha. So true. He told me the reason they may not fit is because of the tumbling process. WTF? Then told us to double them up haha. Good times. Good times.
djuosnteisn (12-08-2010), madvillain (12-08-2010), SilverDemon (12-08-2010), Spoolme (12-09-2010)
 Old 12-08-2010, 02:16 PM   #118
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
i found some nice brass washers, ohh i mean injector seals ill sell you! 50 dolera, life time warranty, i got a thousand in stock!
pm me, and ill slide you in the back door! lol
joke ! haha
at 104000 2 bent rods
tuned by nishan
The Following 3 Users Say Thank You to rigor For This Useful Post:
djuosnteisn (12-08-2010), SilverDemon (12-08-2010), socks (12-08-2010)
 Old 12-08-2010, 03:00 PM   #119
hahahaha...comedian in every bunch!!!
Thanks to everyone for being patient.....I was hoping to hear something this week on the paperwork. I have all the installation instructions typed up, prints have been submitted, so the ball is in the vendors court at this point.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 8 Users Say Thank You to SilverDemon For This Useful Post:
Boosted Beluga (12-08-2010), djuosnteisn (12-08-2010), essejkcamraw (12-08-2010), hnda etr (12-08-2010), rigor (12-08-2010), socks (12-08-2010), Spoolme (12-09-2010), tbot (12-08-2010)
 Old 12-08-2010, 03:04 PM   #120
tbot's Avatar
Groans: 40
Light a fire Scott!!!
The Following User Says Thank You to tbot For This Useful Post:
rigor (12-08-2010)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/injector-seals-63858/
BlueStreak's ATR Tuning Journey This thread Refback 03-31-2011 11:30 AM
Injector Seals Replaced aaronc7 MazdaSpeed 3 - Engine, Transmission & Driveline 53 06-18-2012 12:52 PM
After shift bog and injector seals 06Speed6 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 07-27-2010 12:02 AM
Injector Seals, revisited.... ptperformance Mazdaspeed3/6 General Discussion 107 07-24-2010 09:22 PM
Injector Seals! ptperformance Mazdaspeed3/6 General Discussion 71 06-02-2010 10:13 PM
Page generated in 0.62151 seconds with 37 queries
