 Old 10-27-2017, 03:20 PM   #1
meekerMS3's Avatar
Posts: 29   (View Stats)
meekerMS3 will become famous soon enough
Default K04 coolant leak
I finally found the source of the coolant, it appears to becoming from the bolt circled in the picture below. It’s a very slow leak, ends up being 3-4 drops in a 6-8hr period of sitting. Just curious if anyone has a better idea than just taking it out and using high temp thread sealant then reinstalling? I have no idea what this bolt is called so can’t find torque specs either.
Assuming coolant will need to be drained before removal?
Any ideas would be awesome, thanks!
[IMG]https://imgur.com/a/xrU2V.jpg[IMG]
[IMG]https://imgur.com/a/xrU2V[IMG]
Of course imgur isn’t working, trying to get the pic posted now
08 MS3 - RMM, AP, Autotech internals, CS TIP/SRI, CS Boost tubes/recirc tube, CS TMIC, CS BPV, DP, DMS OCC
Last edited by meekerMS3; 10-27-2017 at 03:22 PM. Reason: MSF Database - Automerged Doublepost
meekerMS3 is offline   Reply With Quote
 Old 10-27-2017, 03:24 PM   #2
meekerMS3's Avatar
That was a struggle
File Type: jpeg CF7E2973-38C4-4AC9-988C-C6CAA7E42036.jpeg (430.6 KB, 23 views)
 Old 10-27-2017, 04:24 PM   #3
Djohns's Avatar
Posts: 3,944   (View Stats)
How positive are you? I had a leak that looked like it was coming from that bolt, but it turned out I needed new crush washers, and my feed line needed to be tightened up with a smaller hose. But the drips were coming right from that bolt.
2010 black mica speed3
Soon:built motor
 Old 10-27-2017, 04:45 PM   #4
meekerMS3's Avatar
Not positive at all to be honest. The coolant hose is directly above that bolt right? I ordered new new crush washers and new banjo bolt already. You went with a smaller hose? Was this on a Turbo other than the stock K04? Cause mine is stock, as is the coolant line.
 Old 10-28-2017, 06:22 PM   #5
meekerMS3's Avatar
I’m getting ready to replace the bolt, do I need to drain the coolant before doing so? And do you have any idea the torque specs on it?
 Old 10-28-2017, 07:04 PM   #6
Djohns's Avatar
Yes you’ll need to drain some otherwise you’ll have a big mess to clean up. No clue on torque, just go till it’s tight.
Soon:built motor
 Old 10-28-2017, 07:22 PM   #7
meekerMS3's Avatar
Alright cool thanks for confirming!
 Old 10-28-2017, 07:25 PM   #8
Djohns's Avatar
Also I thought I responded, yes this was on a ko4, I needed a smaller hose since I previously replaced it after I clocked my turbo and the line was a tad big.
Soon:built motor
 Old 11-01-2017, 12:11 PM   #9
meekerMS3's Avatar
So the new bolt and crush washers seem to fix the problem! Thank you for the suggestion!
The Following User Says Thank You to meekerMS3 For This Useful Post:
Djohns (11-01-2017)
 Old 11-01-2017, 12:14 PM   #10
Djohns's Avatar
No problem.
Soon:built motor
 Old 11-01-2017, 12:19 PM   #11
meekerMS3's Avatar
Before starting a new thread let me ask you one other quick question. After installing my catted DP, I got the typical white smoke at idle (oil is RP 5w30 for ethanol so can’t go up to 5w40). I ordered an oil restrictor bolt, the next the smoking was totally gone (the turbo has about 8500 miles on the rebuild so I’m assuming the seals are still in good shape).
My question is, will it hurt to install the restrictor bolt even though it’s not smoking at the moment?
 Old 11-01-2017, 12:21 PM   #12
Djohns's Avatar
Well it is a ko4 so that’s completely fine. From the factory that bolt feeds just a little too much oil anyway so I would recommend you use the Restrictor bolt to make the turbo last longer.
Soon:built motor
 Old 11-01-2017, 12:40 PM   #13
meekerMS3's Avatar
Alright awesome, I will go ahead and put it in on. I didn’t realize the extra oil would actually shorten the life of the turbo. Thank you very much!
Coolant leak Khang88 Mazdaspeed3/6 General Discussion 1 04-17-2016 07:56 PM
coolant leak? json CX-7 > Issues & Troubleshooting 2 02-27-2013 10:18 PM
1st log after coolant leak volodya84 MazdaSpeed 3/6 - ECU Computer Tuning 19 06-14-2011 04:21 PM
Coolant Leak for me Derek88 MazdaSpeed 3 - Engine, Transmission & Driveline 11 08-23-2008 05:33 PM
Page generated in 0.31782 seconds with 22 queries
