 Old 02-29-2016, 11:27 PM   #1
Dwightb's Avatar
Posts: 3   (View Stats)
Dwightb is an unknown quantity at this point
Default Low Boost
I lost access to this car for the last couple of years. Now that its returned (from Ohio) to Colorado I note that the torque seems a little low. Yeah, it now has ~100K miles on it but one would think with all the ECU hooks that the OEM boost targets should still be met. The car is basically stock (aftermarket CAI & BOV). A Dashhawk log shows the boost ramping up on a WOT pull and leveling off ~11psi and the WGDC running ~28% from 3K - 5K rpm. The AFR looks normal; 14.6 until the RPM goes past 4k where the AFR drops down to ~11. By all appearances, the ECU looks to have achieved its target otherwise wouldn't the WGDC increase? I assume that altitude (I'm at 5000') doesn't affect the system targets.
Dwightb is offline   Reply With Quote
 Old 03-01-2016, 06:45 AM   #2
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
OEM tune logic is load based, not boost based. In the most general of terms that means you may well not come anywhere close to what you're considering your boost target numbers and the ECU will still meet it's target criteria.
Elevation, seen here as barometric pressure, can reduce targets compared to sea level to protect the engine/turbo. Combine that with colder ambient temps and you can very easily be meeting the conservative OEM targets while seeing low boost pressure.
If you'd like to make changes you'd need an AccessPort or VersaTuner and I'd suggest looking up one of the several great tuners that can provide you with an "E-Tune" where you trade logs and map revisions by email. Best bang for the buck you can get and your car will run as well as it safely can.
340hp / 371tq
robbspeed (03-01-2016)
 Old 03-01-2016, 05:41 PM   #3
Dwightb's Avatar
Default Low boost
Thanks TiGray;
Load based, understood. So what variables does the ECU use to determine "load" and what are the the OEM load targets.
 Old 03-01-2016, 05:44 PM   #4
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Originally Posted by Dwightb View Post
Thanks TiGray;
Load = MAF airflow * 40 / RPM
3 Port Boost Control Solenoid / Boost Question Badinfluence MazdaSpeed 3/6 - ECU Computer Tuning 24 06-24-2013 02:59 PM
Snow maf/boost controller boost Line question speed3gen1 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 10-29-2012 07:29 PM
boost tuning, not hitting easy boost targets? Caldazar MazdaSpeed 3/6 - ECU Computer Tuning 11 05-18-2012 06:09 PM
Cobb ATR Support
26 08-24-2009 06:36 PM
Page generated in 0.24957 seconds with 23 queries
