Like Tree15Likes
 Old 12-26-2011, 11:09 PM   #121
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Your scaling won't be linear for the entire maf cal.. You'll most likely peak somewhere around 700 gs..
The Following User Says Thank You to SSinstaller For This Useful Post:
Tomas (12-26-2011)
 Old 12-27-2011, 08:25 AM   #122
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
looks like someone is spraying water/meth into their turbo...
I thought you had a BT so why spray preturbo? I can see doing that to a disposable K04 but why a BT?
Have you been doing this before, how many miles and what does your comp blade look like?
 Old 12-27-2011, 08:36 AM   #123
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
I spray with a D0.75 nozzle pre turbo and D03 post but I want to go down to D02 or D01.
No visible wear on compressor blades.
Doing it for about 4k miles. I can tell you I've seen turbos that sprayed pre turbo for a very long time with bigger nozzles and blade wear was minimal.
Besides. A new compressor wheel + rotor balancing is not that expensive.
The Following 4 Users Say Thank You to Tomas For This Useful Post:
Dano (12-27-2011), J-Liss (01-03-2012), rfinkle2 (07-13-2012), wolly6973 (01-09-2012)
 Old 08-08-2012, 01:32 PM   #124
ESB Jiu JItsu's Avatar
Posts: 492   (View Stats)
ESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the world
I saw this mentioned once before but without answers would the air straightener not help in a situation where you see resistance post hard bends in FMIC piping setups? Example: most FMIC setups have a 90 degree bind right before the inlet/outlets, what if a air straightener was used in these circumstances, would we see a better higher rate of flow into the IC allowing for better cooling??? would it hurt anything?
2006 Mazdaspeed6 GT Liquid Platinum Metallic
"because racecar!" " I love this $%&*ing car"
-Gram Lights 57C 18"x7.5/Cooper SR3-A 2254018/H&R Springs/SURE RMM/Diff Straps
-2.75 Blow Through MAF/Custom CXracing FMIC&BOV/Fujita SRI/AEM dryflow/PG TIP/SLS TP/Exhaust Delete/NGK LTR7IX11 plugs/ TB Coolant BP/Bat->Trunk Relocation/JBR egr delete
-TWM Stage 2 Short Shifter/JBR Weighted Shift Knob/TWM 4in Shifter Extender
-Emil Drilled/Slotted rotors/Hawk HP Pads/Clutch Pedal Mod/Shift Counter Weight Mod
-Custom Vented Hood/Custom Front Bumper/Emblem delete/Prosport Mech. boost gauge
ESB Jiu JItsu is offline   Reply With Quote
 Old 08-08-2012, 05:48 PM   #125
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
it would just be an added restriction
ESB Jiu JItsu likes this.
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
ESB Jiu JItsu (08-09-2012)
 Old 08-10-2012, 07:23 AM   #126
Im trying to find some of this stuff locally... can any of you guys take a look at this website and see if anything looks like a match. Im not 100% sure how they are listing these.
Aluminum Honeycomb - Aviation Metals
thank you!! any other ideas of where i can find an air straightener local in NC?
 Old 08-23-2012, 09:44 AM   #127
ordered some maf screen finally (the good stuff)
Honeycomb for
MAF
Cell size : 3/16 cell 5:1 ratio
Hoping this will help with my setup and calm some readings as most are seeing! great thread! thanks to all contributors!
 Old 08-23-2012, 09:40 PM   #128
Carlo1170's Avatar
Posts: 232   (View Stats)
Carlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the worldCarlo1170 is the leader of the world
With my CP-E Big Maf I've been experiencing a lot of the same issues. Went ahead and ordered some of the 7:1 86mm Honeycomb. From the great info in this thread, it should definitely stabilize my AFRs (a bit more anyways).
I live in Arizona and when its been cooler or raining I am within 3% at idle. My LTFTs are all within 2% after that but my AFR fluctuates an awful lot (between ~13.5-15). My WOT logs do flucuate but not terribly.. I'm on a very conservative tune because of the heat and I'm commanding 11.4 and getting my main values between 11.35-11.48. I do see a little dip in the 3.8v range to 11.25. We will see..
2007 True Red Speed3
--Cobb TIP--Cobb SRI--Sure Shifter Bushings--Prosport Premium Boost Gauge--Block8head Gauge Pod--
2002 Honda RVT1000R RC51
Carlo1170 is offline   Reply With Quote
The Following User Says Thank You to Carlo1170 For This Useful Post:
superskaterxes (08-24-2012)
 Old 09-01-2012, 07:42 PM   #129
Carlo1170's Avatar
Just got my honeycomb installed.. Being that it was only slightly larger, I was able to just shape the sides a bit with compression rather than dealing with cutting. I was able to push it in rather easily, albeit a very snug fit, because the CPE big MAF has a taper at the front of the intake.. I will update with some results later..
 Old 09-02-2012, 04:00 AM   #130
thats exactly what i did as well worked perfectly with some jb weld finished off nicely and works well. Improved my setup greatly. Took the ecu a day to get use to it.
 Old 09-02-2012, 10:27 AM   #131
Carlo1170's Avatar
Didn't even need to use the JB. Its a very tight fit and of course the honeycomb is in front of the MAF so it's not moving anywhere. I havent gotten a chance to log any results yet but just by observation its definitely smoothed out my cruising AFRs. I also noticed my trims changed a little bit, by about 6% on the low end of the MAF range so I will do another mafcal.
 Old 09-03-2012, 07:28 AM   #132
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Just ordered the 7:1 86mm as well...
 Old 09-03-2012, 01:41 PM   #133
greg08's Avatar
Posts: 480   (View Stats)
let us know 12pk
 Old 09-04-2012, 03:07 AM   #134
Carlo1170's Avatar
Alright so after driving on my most recent mafcal my AFRs have steadied quite a bit. Before the honeycomb, cruising would fluctuate between 13.5-15.5 AFR. Now, I am between 14.5-14.8 cruising. Huge improvement.
As for WOT. I am now targeting 11.5( slowly increasing) and I was seeing 11.48 for most of my logs with a few random drops to 11.37. This is also a huge improvement from targeting 11.4 and getting 11.2-11.6 through my runs.
I appreciate all the input and research that's gone into this. If it weren't for this thread I wouldn't have done this because CP-E was of NO help at all. I attempted to email them asking the experience they've had. All they said was they never had to use one.. I then Explained myself further and I kind of feel like they made me out to be an idiot because the guy just emailed me back their CP-E bigmaf starting calibration numbers after I clearly told them the issues and that is where I started.. I gave up and bit the bullet.
CPE should really think about integrating or making one of these available for their customers. I find it really hard to believe that these airflow straighteners aren't really needed. With my CPE CAI, my AFRs weren't as erratic and i know the big MAF will cause that. There's no way they think this is okay do they?
ESB Jiu JItsu and J-Liss like this.
 Old 09-11-2012, 08:01 AM   #135
i noticed also once i went back to draw through after attempting blow through that the air straightener helped minimize back firing even when running vta still but also leveled out my afr's and aided flow. This thread is gold and now ill be completely ready for blow through once someone send me their AP lol
 Old 09-11-2012, 08:17 AM   #136
Trail of Fail
Dano's Avatar
I run a honeycomb straightener in my JBR 3.5 and AF is rock solid. Link to thread with pics and a few AF plots.
http://www.mazdaspeedforum.org/forum/foru...0/#post1601663
The Following 4 Users Say Thank You to Dano For This Useful Post:
ESB Jiu JItsu (09-11-2012), JBR (09-11-2012), rfinkle2 (11-26-2012), wolly6973 (09-12-2012)
 Old 09-11-2012, 09:46 AM   #137
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
bragger
it's fun to do bad things
Dano (09-11-2012)
 Old 09-11-2012, 10:14 AM   #138
Trail of Fail
Dano's Avatar
hater
just trying to link as much info together as possible...
 Old 09-12-2012, 04:37 AM   #139
Eth/Meth Junkie
cld12pk2go's Avatar
Originally Posted by greg08 View Post
let us know 12pk
I installed mine in about 3 min after crushing down a little around the edges. It was installed right inside the CPE MAF housing probably 2'' up from the MAF sensor.
Honestly, I cannot say that I have observed any positive or negative changes over the last several days.
I still have a non-crisp region of running in the lower airflow ranges (<~50 g/s) that I was hoping to have a positive influence on.
 Old 09-13-2012, 07:05 PM   #140
greg08's Avatar
hmm, that stinks :p
 Old 06-09-2014, 10:41 AM   #141
Emew's Avatar
Posts: 217   (View Stats)
Hate to necro an old thread but as @Lex had brought to my attention that I am having potential turbulence issues after putting the car in idle at 40 mph causing my RPMs to fluctuate. I am looking at this as a potential solution to my problem. I'm thinking I will go 6:1 ratio and my question lies in if doing a 75 mm for the SURE Full 3 ID300 3" MAF housing unit would be large enough? I know 75 mm comes in like .05 inches short of 3, but I figure it will come damn close and if not perfect I planned on doing similar to skate and wrapping it in electrical tape to seat it which i'm sure will add .05 inches with 1 or 2 layers and get me a nice wedged fit, anyone see a problem with this setup?
Flow Student
 Old 06-09-2014, 11:47 AM   #142
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Nope, I have mine wrapped in a little electrical tape. Definitely helped with the condition you are describing. Just remember to re calibrate.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
Emew (06-09-2014)
 Old 06-14-2014, 03:00 PM   #143
Emew's Avatar
75mm was too small and tape got a nice fit right at the mouth of the intake. I know earlier it was discussed for proper straightening; further from maf is better. Any idea how many g/s of airflow I sacrificed by wrapping something like 9-10 layers of electrical tape around this honeycomb? Or is it just insignificant to the point of like .5 WHP?
Flow Student
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/maf-airflow-straightener-testing-88520/
Untitled document This thread Refback 12-24-2015 02:29 AM
Here's how VW is fixing its emissions-cheating engines - Business Insider This thread Refback 12-02-2015 05:26 PM
Oh, the wicked web you weave... - Page 9 - Motoring Alliance :: MINI Cooper Forums This thread Pingback 12-02-2015 11:51 AM
Here's how VW is fixing its emissions-cheating engines - Business Insider This thread Refback 12-02-2015 10:04 AM
How The Volkswagen 'Flow Straightener' Really Works This thread Refback 12-02-2015 09:01 AM
V8 Brothers - ???????? 447 - 1UZ\3UZ - Altezza & Lexus IS Club - ???????? 447 This thread Refback 11-19-2015 04:05 AM
V8 Brothers - ???????? 447 - 1UZ\3UZ - Altezza & Lexus IS Club - ???????? 447 This thread Refback 11-19-2015 02:07 AM
V8 Brothers - ???????? 447 - 1UZ\3UZ - Altezza & Lexus IS Club - ???????? 447 This thread Refback 11-18-2015 10:40 AM
5VZ-FE Turbo Build Help Thread - Page 20 - Toyota Tacoma Forum This thread Pingback 03-21-2015 08:52 PM
Paper honeycomb in throttle body - FordFusionClub.com : The #1 Ford Fusion Forum This thread Refback 10-20-2014 09:32 PM
Throttle Body Screen Removal - Page 2 This thread Refback 10-10-2014 10:15 PM
What are your (modified) long term fuel trims? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-08-2014 07:34 PM
SRT Intake w/ Air Straightener w/ PIX - my.IS - Lexus IS Forum This thread Pingback 06-21-2014 02:44 AM
Piggy back for turbo is - my.IS - Lexus IS Forum This thread Refback 06-10-2014 09:03 AM
what did you do to your micra today ? | Page 292 | Micra Sports Club This thread Refback 01-03-2014 03:25 PM
TourerV.ru ? ???????? ???? - ??? ????? ????.?????? ?? JZX110/JZS17x? ???????? MAF This thread Refback 07-15-2013 12:24 PM
Cone air filter with a stock look. ? Mazda MPS Owners Club This thread Refback 04-23-2013 12:41 PM
HoneyComb MAF Mass Air Meter Airflow Straightener - Page 2 - NewCelica.org Forum This thread Refback 03-31-2013 03:26 PM
Air Flow Straightners ? Mazda MPS Owners Club This thread Refback 03-10-2013 08:28 PM
intake idea? - Power and Drivetrain - Nissan GT-R Heritage This thread Refback 02-09-2013 12:53 PM
MAF mod completed!! Success!! :) - Page 2 This thread Pingback 08-01-2012 04:52 PM
Check engin - Civic 2012 et plus - Club Civic Quebec :: Forum This thread Refback 07-16-2012 09:55 AM
CAI or modified Intake cure..? This thread Pingback 07-15-2012 06:44 PM
Check Emission System after 60 miles with Injen CAI. Bummer. - Page 2 This thread Pingback 07-15-2012 05:46 PM
Mazda MPS Owners Club • View topic - Air Flow Straightners This thread Refback 05-10-2012 06:24 AM
HELP! ?????????? ????? ? ????????????? ?????? This thread Refback 11-07-2011 12:41 PM
Mazda MPS Owners Club • View topic - Cone air filter with a stock look. This thread Refback 11-02-2011 11:51 AM
Report: Citroen to follow Fiat's lead with DS3 Airflow convertible [w/poll] Haltech Automotive News 0 05-15-2011 09:40 AM
Got airflow? Hectik1 MazdaSpeed 3/6 - Appearance 3 04-21-2011 04:31 PM
Air Straightener? bewsted 2010 MS3 - Turbo Induction 7 12-25-2010 11:51 AM
Engine Load and Airflow vs TQ and HP bova
Cobb Access Port/Maps
9 02-25-2009 07:25 AM
v103 MS CAI maps... will they REQUIRE the airflow straightener? bast525
6 09-15-2008 01:15 PM
Page generated in 0.48033 seconds with 30 queries
