Like Tree15Likes
 Old 08-16-2011, 06:17 AM   #41
Ziggo's Avatar
Posts: 3,843   (View Stats)
I updated the spreadsheet. Published as a web page at this link, but you can still edit it with the link above. Added a few rows down to 450g/s for the big dogs, but you will still have to change the pipe diameter to whatever your MAF dia is, and the effective dia to whatever size honeycomb you use.
https://docs.google.com/spreadsheet/...2c&output=html
Ask Me About My:
 Old 08-16-2011, 06:40 AM   #42
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
i got a shipping update from them and it should be here by the end of the week hopefully.
cant wait to test this!!!
so if im reading this sheet correctly, for 400 g/s, i will need approx. 4.5" between honeycomb and maf?
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 08-16-2011, 07:07 AM   #43
Ziggo's Avatar
That would be best. Though I would measure it from the front edge of the honeycomb, but it wont be a disaster if you can only reasonably get 3.5" in front of the MAF. Like AZ said, the equation we are using is a "rule of thumb" equation so it is a conservative ballpark figure.
Ask Me About My:
 Old 08-16-2011, 07:19 AM   #44
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
How are you going to keep the honeycomb in place...jb weld?
 Old 08-16-2011, 07:36 AM   #45
Must Have Teh 10's!
havent figured that out yet
we'll see how snug it is when i get it in there.
 Old 08-16-2011, 07:43 AM   #46
Groans: 35
thats what she said
The Following 9 Users Say Thank You to RichieRichness For This Useful Post:
chaser27 (11-20-2014), djuosnteisn (08-16-2011), Easter Bunny (08-24-2011), lifeownedme (09-17-2011), pebenito (08-16-2011), Pointless (01-02-2013), Tomas (10-19-2011), Vader (09-16-2011), xcoldricex (09-17-2011)
 Old 08-18-2011, 08:57 PM   #47
mrkdspd's Avatar
Posts: 158   (View Stats)
mrkdspd has a reputation beyond reputemrkdspd has a reputation beyond reputemrkdspd has a reputation beyond reputemrkdspd has a reputation beyond reputemrkdspd has a reputation beyond reputemrkdspd has a reputation beyond reputemrkdspd has a reputation beyond reputemrkdspd has a reputation beyond reputemrkdspd has a reputation beyond reputemrkdspd has a reputation beyond reputemrkdspd has a reputation beyond repute
Groaned at 20 Times in 6 Posts
Heres a few pics of my 3.5" blowthrough setup with a honeycomb air straightener. Fuel trims are perfect at idle and cruise. Wot afrs are almost perfect. Just have a small spot when I hit 3 volts I need to lean out a bit.
ESB Jiu JItsu likes this.
Corn-fed MS6-sold
04 STi-racecar
mrkdspd is offline   Reply With Quote
The Following 8 Users Say Thank You to mrkdspd For This Useful Post:
06Speed6 (08-20-2011), BlueStreak (08-18-2011), djuosnteisn (08-24-2011), ESB Jiu JItsu (08-22-2012), Fobio (08-18-2011), RichieRichness (08-23-2011), superskaterxes (08-19-2011), wolly6973 (08-23-2011)
 Old 08-19-2011, 05:09 AM   #48
Must Have Teh 10's!
where did you get your honeycomb? can you tell us a little more about the hole diameter/width of the honeycomb and how far away from the MAF you placed it?
 Old 08-19-2011, 05:30 AM   #49
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
shiat, and i bought that stupid plastic aem air straightner thingy
 Old 08-19-2011, 07:06 AM   #50
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
at least you didn't buy the shitty screen from John
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following 4 Users Say Thank You to 86AmishMs3 For This Useful Post:
06Speed6 (08-20-2011), kgb (08-25-2011), superskaterxes (08-19-2011), wolly6973 (08-23-2011)
 Old 08-19-2011, 10:34 AM   #51
mrkdspd's Avatar
I got it from treadstone, its a little over 3.5" in diameter making it fit nice and tight inside my maf housing. Its probably 2-3" away from the actual sensor. I used some epoxy to hold it in but I wish I would have used jb weld instead
Corn-fed MS6-sold
04 STi-racecar
 Old 08-22-2011, 07:24 PM   #52
Must Have Teh 10's!
ok so i just got my straighteners yesterday but i wont be home until wed to try them out. will post more info then!!!
The Following 3 Users Say Thank You to superskaterxes For This Useful Post:
BlueStreak (08-22-2011), Fobio (08-22-2011), wolly6973 (08-23-2011)
 Old 08-23-2011, 02:05 AM   #53
2zz mr-s
dooderek's Avatar
Groans: 239
MOAR AIR STRAIGHTNING
 Old 08-24-2011, 07:48 PM   #54
Must Have Teh 10's!
PRELIMINARY RESULTS!!!!!
ok so i finally got around to installing this puppy today. i went with the aluminum one because i diddent have anything to cut the plastic one nicely.
i first put the MAF housing over this and traced a circle inside using a sharpie. then i used an air cutoff wheel which worked surprisingly well.
rich gave me the idea to wrap it in a layer of electrical tape to make sure the sides did not flake any metal pieces off.
fitment was really tight and i diddent need to use anything to keep it in place.
i took some idle logs and things looked a little smoother but not much different. cruising and normal driving is dramatically improved. no more backfiring, WOT pulls are smooth as hell and over all driveability is just better. i did notice my AFR's came down about 1/2 a point but im also pegging my FP sensor so i will know later this week if its really the honeycomb doing it.
i also need to note that i have a CEL for IAT circuit high which im not sure about. nothing seems to be out of the ordinary on logs or anything and i have another maf i can try out to see if thats it.
The Following 14 Users Say Thank You to superskaterxes For This Useful Post:
BlueStreak (08-24-2011), chaser27 (11-20-2014), Ckmazdaspeed3 (08-25-2011), djuosnteisn (08-30-2011), Easter Bunny (08-24-2011), Fobio (08-24-2011), jack_hammer (08-29-2011), magicka (08-25-2011), Pointless (01-02-2013), rfinkle2 (09-07-2011), RichieRichness (08-24-2011), SSinstaller (08-24-2011), wolly6973 (09-12-2011), Ziggo (08-24-2011)
 Old 08-24-2011, 07:51 PM   #55
Groans: 35
pimp
 Old 08-24-2011, 07:56 PM   #56
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Every time I unplug the maf I get that same IAT MIL.. Just clear it.
The Following 2 Users Say Thank You to SSinstaller For This Useful Post:
djuosnteisn (08-30-2011), superskaterxes (08-24-2011)
 Old 08-24-2011, 10:21 PM   #57
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
First mod on a 2nd gen DSM was pull 1 honeycomb and throw it in the trash. Check idle, if fine, pull 2nd honeycomb, leaving only the one in front of the MAF. If still idles ok, go haul ass. Here we are 15 years later adding in honeycombs. FML.
The Following 2 Users Say Thank You to jmhinkle For This Useful Post:
djuosnteisn (08-30-2011), heloboby7 (11-16-2011)
 Old 09-07-2011, 12:22 PM   #58
Islandromeo's Avatar
Posts: 17   (View Stats)
Islandromeo is infamous around these partsIslandromeo is infamous around these parts
Good work thanks for the great info
Islandromeo is offline   Reply With Quote
 Old 09-07-2011, 12:30 PM   #59
Groans: 60
I've got one of these on that way. Hopefully it'll smooth out my erratic MAF readings between 4.0v ~ 4.12v.
The Following User Says Thank You to SSinstaller For This Useful Post:
djuosnteisn (09-07-2011)
 Old 09-07-2011, 12:32 PM   #60
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
I just ordered one myself for the intake dustin is making me.
860whp/677wtq
2.7 V6 Ecoboost
djuosnteisn (09-07-2011), rfinkle2 (09-07-2011)
 Old 09-07-2011, 01:06 PM   #61
steedspeed's Avatar
Posts: 582   (View Stats)
steedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the world
Perhaps try putting one in front of the compressor? Easier for the impeller to grab the air if its straight. A bit like stator blade effect on jet engines.
steedspeed is offline   Reply With Quote
 Old 09-07-2011, 01:39 PM   #62
Must Have Teh 10's!
interesting concept although i dont know how comfortable i would be with it that close to the compressor lol
 Old 09-07-2011, 01:44 PM   #63
PapaSmurf's Avatar
hmmm couldnt you epoxy it so you would have to worry about it getting sucked in and or the edges ripping off?
860whp/677wtq
2.7 V6 Ecoboost
 Old 09-07-2011, 05:15 PM   #64
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
cant you shape the honey comb edge to a taper so it suppresses in and dont fully push it in leave a very very small lip not compressed in so it literally cannot go in. thats what im gonna try to do.
 Old 09-08-2011, 07:48 AM   #65
steedspeed's Avatar
I could machine a cage to hold the honeycomb and have spokes radiating from the center to support it.
 Old 09-08-2011, 07:57 AM   #66
Must Have Teh 10's!
i used a cutoff wheel to trim the edges on mine and i think just the way i was holding it made the outside cuts somewhat tapered like your describing. when i pushed it into the pipe it def took some serious force.
 Old 09-08-2011, 01:36 PM   #67
LuczOr's Avatar
Posts: 462   (View Stats)
LuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the world
Groaned at 15 Times in 12 Posts
Congrats on results, super. Good to see new shit happening.
SOLUTIONS, BITCHES.
Cool sig coming soon.
LuczOr is offline   Reply With Quote
The Following User Says Thank You to LuczOr For This Useful Post:
superskaterxes (09-08-2011)
 Old 09-08-2011, 02:19 PM   #68
TRex's Avatar
Posts: 3,139   (View Stats)
what of honeycombs in other places?
as was said earlier bends cause issues....im thinking after your FMIC before you enter the throttle body....would removing the eddies from this flow help at all? or is it really only beneficial at the maf because we are actually trying to read something from that flow?
also....is the fact that there are o2 sensor issues after a cat removal have anything to do with the cat being of a honey comb design? similar to the flow needing to be of a specific nature like for the maf?
 Old 09-08-2011, 02:21 PM   #69
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
no the o2 sensor is supposed to see a change in the gas characteristics not flow
The Following User Says Thank You to TWOptSL0W For This Useful Post:
TRex (09-08-2011)
 Old 09-08-2011, 03:02 PM   #70
bcmurphy87's Avatar
Posts: 1,435   (View Stats)
i need to get one of these since im doing blow through
06 Speed6 GT- Sold
The Following 2 Users Say Thank You to bcmurphy87 For This Useful Post:
BobtailedSnail (11-29-2011), djuosnteisn (09-12-2011)
 Old 09-12-2011, 02:43 PM   #71
Daily Driver
Nitr0EngiE's Avatar
just ordered 7:1 96mm
 Old 09-12-2011, 04:13 PM   #72
mason's Avatar
Posts: 946   (View Stats)
maf housing? or screen?
 Old 09-12-2011, 06:48 PM   #73
Daily Driver
Nitr0EngiE's Avatar
honeycomb
 Old 09-16-2011, 08:13 AM   #74
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
Hmm, I have a Sure aeros coming, I might put one of these infront of the air straightener.
 Old 09-16-2011, 11:08 AM   #75
Groans: 60
Just got mine installed, cold idle now shows a steady 4.43~4.5g/s, without it was 4~6g/s.. Seems promising.
Unfortunately while I was doing the install, I noticed I have a slight exhaust leak at the turbo flange, and my damn oil return is seeping oil from the upper fittings. Looks like I'll be pulling the turbo again in the near future.
rfinkle2 (11-26-2012), RichieRichness (09-16-2011)
 Old 09-16-2011, 01:38 PM   #76
Jarods7920's Avatar
Posts: 1,415   (View Stats)
This is exactly what we are using to make my blow through set up to work.
The Following 2 Users Say Thank You to Jarods7920 For This Useful Post:
djuosnteisn (09-19-2011), rfinkle2 (11-30-2012)
 Old 09-17-2011, 06:28 AM   #77
G26
G26's Avatar
Groans: 39
Seems like a few of you are using this in blow through, is it not recommended for pull through?
 Old 09-17-2011, 08:32 AM   #78
Groans: 60
Took some logs last night, I'm now .3~.6 rich just about everywhere above 3.0v. My weird region around 4.0v seems to behave better, and I see much less reversion as the maf voltage rises. I like the new behavior, but it sucks to lose 40-50gs resolution off the top to accommodate the airflow straightener.
I also actually saw a little KR, which is funny considering I was much richer than normal for the entire pull...
Mines in pull through right now, but will soon switch to blow through..
Also, in case anyone didn't notice you can request your part cut to any size you want(at no charge). I had them cut mine to 3.25", and all I had to do when I got it was pick off any little slivers I saw and install it..
djuosnteisn (09-19-2011), rfinkle2 (11-26-2012)
 Old 09-17-2011, 08:37 AM   #79
G26
G26's Avatar
Groans: 39
Why did it lose so much g/s up top?
 Old 09-17-2011, 08:56 AM   #80
Groans: 60
I'm still running the small filter CP-E sends with the big maf housing, I think that coupled with the maf straightener is creating significant vacuum in the compressor at WOT lowering efficiency as the vacuum rises... I will rectify this problem when I go blow through...will be running a full 4" intake with this filter.
I haven't finished the map revisions yet, but it looks like it will be closer to 20~30g/s...so even on my current setup it's not that big of a restriction..
BlueStreak (09-17-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/maf-airflow-straightener-testing-88520/
Untitled document This thread Refback 12-24-2015 02:29 AM
Here's how VW is fixing its emissions-cheating engines - Business Insider This thread Refback 12-02-2015 05:26 PM
Oh, the wicked web you weave... - Page 9 - Motoring Alliance :: MINI Cooper Forums This thread Pingback 12-02-2015 11:51 AM
Here's how VW is fixing its emissions-cheating engines - Business Insider This thread Refback 12-02-2015 10:04 AM
How The Volkswagen 'Flow Straightener' Really Works This thread Refback 12-02-2015 09:01 AM
V8 Brothers - ???????? 447 - 1UZ\3UZ - Altezza & Lexus IS Club - ???????? 447 This thread Refback 11-19-2015 04:05 AM
V8 Brothers - ???????? 447 - 1UZ\3UZ - Altezza & Lexus IS Club - ???????? 447 This thread Refback 11-19-2015 02:07 AM
V8 Brothers - ???????? 447 - 1UZ\3UZ - Altezza & Lexus IS Club - ???????? 447 This thread Refback 11-18-2015 10:40 AM
5VZ-FE Turbo Build Help Thread - Page 20 - Toyota Tacoma Forum This thread Pingback 03-21-2015 08:52 PM
Paper honeycomb in throttle body - FordFusionClub.com : The #1 Ford Fusion Forum This thread Refback 10-20-2014 09:32 PM
Throttle Body Screen Removal - Page 2 This thread Refback 10-10-2014 10:15 PM
What are your (modified) long term fuel trims? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-08-2014 07:34 PM
SRT Intake w/ Air Straightener w/ PIX - my.IS - Lexus IS Forum This thread Pingback 06-21-2014 02:44 AM
Piggy back for turbo is - my.IS - Lexus IS Forum This thread Refback 06-10-2014 09:03 AM
what did you do to your micra today ? | Page 292 | Micra Sports Club This thread Refback 01-03-2014 03:25 PM
TourerV.ru ? ???????? ???? - ??? ????? ????.?????? ?? JZX110/JZS17x? ???????? MAF This thread Refback 07-15-2013 12:24 PM
Cone air filter with a stock look. ? Mazda MPS Owners Club This thread Refback 04-23-2013 12:41 PM
HoneyComb MAF Mass Air Meter Airflow Straightener - Page 2 - NewCelica.org Forum This thread Refback 03-31-2013 03:26 PM
Air Flow Straightners ? Mazda MPS Owners Club This thread Refback 03-10-2013 08:28 PM
intake idea? - Power and Drivetrain - Nissan GT-R Heritage This thread Refback 02-09-2013 12:53 PM
MAF mod completed!! Success!! :) - Page 2 This thread Pingback 08-01-2012 04:52 PM
Check engin - Civic 2012 et plus - Club Civic Quebec :: Forum This thread Refback 07-16-2012 09:55 AM
CAI or modified Intake cure..? This thread Pingback 07-15-2012 06:44 PM
Check Emission System after 60 miles with Injen CAI. Bummer. - Page 2 This thread Pingback 07-15-2012 05:46 PM
Mazda MPS Owners Club • View topic - Air Flow Straightners This thread Refback 05-10-2012 06:24 AM
HELP! ?????????? ????? ? ????????????? ?????? This thread Refback 11-07-2011 12:41 PM
Mazda MPS Owners Club • View topic - Cone air filter with a stock look. This thread Refback 11-02-2011 11:51 AM
Report: Citroen to follow Fiat's lead with DS3 Airflow convertible [w/poll] Haltech Automotive News 0 05-15-2011 09:40 AM
Got airflow? Hectik1 MazdaSpeed 3/6 - Appearance 3 04-21-2011 04:31 PM
Air Straightener? bewsted 2010 MS3 - Turbo Induction 7 12-25-2010 11:51 AM
Engine Load and Airflow vs TQ and HP bova
Cobb Access Port/Maps
9 02-25-2009 07:25 AM
v103 MS CAI maps... will they REQUIRE the airflow straightener? bast525
6 09-15-2008 01:15 PM
Page generated in 0.62297 seconds with 38 queries
