 Old 03-23-2008, 02:07 PM   #1
ZoomMS3's Avatar
Posts: 94   (View Stats)
ZoomMS3 has a spectacular aura aboutZoomMS3 has a spectacular aura about
Default Map Clamp
I will be running the Corksport FMIC, TXS DP/RP, PG Manifold, CPE FP, MBC, Forge BPV and a straight pipe (literally straight.. no bends, resignators or mufflers) within the next 2 weeks. Just waiting for my car to comeback and break in. Ill be driving down to CPE breaking the engine in and installing the FP in the parking lot..
I got rid of my BCD.. how is the setting up of the map clamp? Ive got to go search for your writeup on that...
On motor #3
Turbo #2
Now have a SSM 08 STi!!
ZoomMS3 is offline   Reply With Quote
 Old 03-23-2008, 02:11 PM   #2
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
how is the straight straight pipe going to work?
 Old 03-23-2008, 05:06 PM   #3
ZoomMS3's Avatar
Its is going to be a pipe.. that is straight..?
It will just run under everything.. if it scrapes.. who cares it cost like $90. No mufflers to fuck up. I would go open dp, but the car runs alot more lean with it. I dont like the vibrations from the dp being right there under my ass in the seat and the length of the pipe helps keep some backpressure.
This thread freaked me out. I was like WTF i didnt start a damn thread! Really freaked me out until i opened it. Did a double take at first
On motor #3
Turbo #2
 Old 03-23-2008, 04:08 PM   #4
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
i suggest starting a new thread for the map clamp and straight pipe as this is for the fmic.
 Old 03-23-2008, 04:14 PM   #5
** Thread Moved **
 Old 03-23-2008, 06:37 PM   #6
aaronc7's Avatar
Groans: 370
lol ok cool, thats what i figured I just wanted to check. I didn't know if you were doing like a side exit or somethign else
 Old 03-23-2008, 08:19 PM   #7
ZoomMS3's Avatar
Lol.. I want to go side exit, but I dont want an empty hole out the back
On motor #3
Turbo #2
 Old 03-28-2008, 12:23 PM   #8
mazdaspeedjay's Avatar
Posts: 99   (View Stats)
mazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the worldmazdaspeedjay is the leader of the world
where'd you get the instructions for the wiring on the map clamp. i've been trying to get another map clamp from pt performance for ever now. i talk to the guy at pt and it isn't his fault but still sucks cause it's been forever and they're still out of stock. but i do need the wiring diagram for the install where do i get it. Driver 311 is the only person i've seen or know of personally thats using one and installed it himself
mazdaspeedjay is offline   Reply With Quote
 Old 03-28-2008, 11:44 PM   #9
occschemguy's Avatar
Posts: 1,149   (View Stats)
occschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the worldoccschemguy is the leader of the world
has someone or can some one do a how to?
You can see more on mymyspace
occschemguy is offline   Reply With Quote
 Old 03-29-2008, 09:35 AM   #10
TRU-BOOST's Avatar
Posts: 801   (View Stats)
TRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the world
How To: Map Clamp - Mazda Forums
TRU-BOOST is offline   Reply With Quote
The Following User Says Thank You to TRU-BOOST For This Useful Post:
occschemguy (03-30-2008)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/map-clamp-398/
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 03-28-2008 11:45 PM
Map Clamp not working oskinosmee MazdaSpeed 3/6 - ECU Computer Tuning 10 08-17-2008 11:37 AM
installing pt performance map clamp ? HELP mazdaspeedjay MazdaSpeed 3/6 - ECU Computer Tuning 2 04-05-2008 06:34 AM
Page generated in 0.29795 seconds with 26 queries
