 Old 03-04-2014, 12:35 AM   #1
Status Update's Avatar
Posts: 461   (View Stats)
Status Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the worldStatus Update is the leader of the world
Default MS6 Downpipe/Catback Ground Clearance
Hey guys... If you guys are running a long DP do you have any issues with the downpipe/catback portion of the exhaust sitting lower than the rest? It seems as if mine is sagging and I'm kind of tired dragging my exhaust over every little thing. I am on coilovers and I'm at a 1.5" gap in the front already so I am not ridiculously low. I'll try to grab some pictures of what I am talking about whenever I can tomorrow. I have COBB Poly Exhaust hangers that I'll be putting on in hopes of fixing it but if it doesn't then IDK. Also if you had an ATP DP did you have any issues with the fitment of another catback? The ATP DP that I have didn't want to mate to the CS Catback properly so the flange had to be heated and bent in order for the two to meet up. I'm just hoping to resolve this soon because I plan on adjusting the coils a bit lower during the spring but not if the exhaust is going to drag everywhere, I dont want to rip a hole in either the DP or CBE.
BMW 335xi 6MT
AR Catless Downpipes///HPF Fmic///BMS DCI///CP-e Chargepipe///Cobb AP V2///Volk TE37sl 18x9.5+22F 18x10.5+20R
2007 BM Mazdaspeed 6 GT #10477
SOLD 8/29/14
Status Update is offline   Reply With Quote
 Old 03-06-2014, 07:19 AM   #2
almcbs's Avatar
Posts: 267   (View Stats)
almcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond reputealmcbs has a reputation beyond repute
i have a m2 dp to stock catback with no sagging issue. Might have to get a exhaust hanger welded on to help it sit a little higher.
the dp didnt mate with the catback properly, guessing its becuase of the angle of the flange. I have 4 gaskets on there now to try and prevent the exhaust leak, wouldnt be surprised if it is still there though.
07 Speed6
ETS TMIC | HTP 3" Intake | Turboxs Hybrid BOV | JBR RMM | Ralco RZ STS | CP-E Triple Dash Pod | Prosport Gauges | Bilstein HD Shocks | H&R Springs | SPC Adjustable Ball Joints | Corksport Strut Bar | CP-E Diff Mount | Whiteline RSB | Autotech HPFP | Cobb AP V3 | M2 DP | PU Rims | Unicorn Jizz | Rotella T6 Blood
Next to come : ???????????
almcbs is offline   Reply With Quote
The Following User Says Thank You to almcbs For This Useful Post:
Status Update (03-06-2014)
 Old 03-09-2014, 10:35 PM   #3
It's probably the CS catback. For some reason it dips down right before where it meets the downpipe. I have poly hangers too, they help a little but it's kind of unfixable.
Status Update (03-09-2014)
 Old 03-09-2014, 10:47 PM   #4
Ahh I see thanks man yeah I'm lowered but nowhere near slammed and I have some pretty healthy wheel gap and I keep scraping over speed bumps in my building. But if there's nothing that I can do then fack lol. Hoping for when I switch to some 245/45s I'll gain enough height where I won't scrape anymore lol.
Sent from my DROID RAZR using Tapatalk 2
BMW 335xi 6MT
SOLD 8/29/14
 Old 04-11-2014, 08:42 AM   #5
Dark Lightning's Avatar
Posts: 170   (View Stats)
Dark Lightning is the leader of the worldDark Lightning is the leader of the worldDark Lightning is the leader of the worldDark Lightning is the leader of the worldDark Lightning is the leader of the worldDark Lightning is the leader of the worldDark Lightning is the leader of the worldDark Lightning is the leader of the worldDark Lightning is the leader of the worldDark Lightning is the leader of the worldDark Lightning is the leader of the world
Groaned at 6 Times in 2 Posts
I have a full ATP DP & Corksport catback with zero clearance issues.
2012 BMW 135i M-Sport
Dark Lightning is offline   Reply With Quote
The Following User Says Thank You to Dark Lightning For This Useful Post:
Status Update (04-11-2014)
 Old 04-11-2014, 10:15 AM   #6
Cheeto's Avatar
Posts: 762   (View Stats)
Cheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the worldCheeto is the leader of the world
I have a CS power series and it dipped and would scrap. Went to a muffler shop and had them move my hangers on my long pipe to suck the exhaust up toward the cab more. It no longer scraps.
Sent while speeding and swerving.....
Chad Erwin -ATX
06 MazdaSpeed6 Gt AWD/Turbo/#5994
MODS:
COBB AP // MSD Dashhawk // Street Unit TMIC // Street Unit Test Pipe // CorkSport Power Series Catless DP // COBB SRI intake // Speedies TIP // Turbosmart BOV // RPM Street Spring // Bilstein Struts/Shocks // TWM Stage 2 Short Shifter // CPE Dogbone rear mount // CPE JuggerNaught Diff mount // COBB Shifter weight // HPFP Internals // Magnaflow FULL 3IN Back// Denso ITV 22s // Full TIGS // EGR Delete // Shorty Antenna // PA Engineering OCC // LED swap
Cheeto is offline   Reply With Quote
The Following User Says Thank You to Cheeto For This Useful Post:
 Old 04-11-2014, 11:01 AM   #7
rymanmazda's Avatar
Posts: 1,531   (View Stats)
Groans: 122
@Status Update; I'm running the ATP catted and a scrape very little only over big speed bumps but the fitment fucking sucks. I have to run like 2-3 gaskets to not leak.
Freektune: 400whp/387awtq
-Autocross Setup-
Other Rides:
The Following User Says Thank You to rymanmazda For This Useful Post:
 Old 04-11-2014, 12:06 PM   #8
I feel like the ATP is a overpriced eBay dp LOL. Paying 400+ for a dp shouldn't have these issues.
Sent from my Nexus 5 using Tapatalk 2
BMW 335xi 6MT
SOLD 8/29/14
 Old 04-11-2014, 12:10 PM   #9
rymanmazda's Avatar
Groans: 122
I know I was pissed when I was installing it. But it hasn't cracked and I got it when edge had a sale last year. Plus vband FTW!
-Autocross Setup-
Other Rides:
 Old 04-11-2014, 12:12 PM   #10
Mi06Speed6's Avatar
Posts: 154   (View Stats)
Mi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond reputeMi06Speed6 has a reputation beyond repute
ATP DP has Vband?
'06 Mazdaspeed 6|| Cobb SF & AP Stage 1 | RPM Street Springs | SPC Ball Joints | SU Rear MM | SURE Dread | Whiteline RSB |18x8 Enkei EKM3 w/ 225/40 | JBR SSP & SURE Anchors | Rotora Blanks w/ EBC Red Stuff | 6K HID lights/fogs | V2 Pre-amp |
Mi06Speed6 is offline   Reply With Quote
The Following User Says Thank You to Mi06Speed6 For This Useful Post:
rymanmazda (04-11-2014)
 Old 04-11-2014, 12:40 PM   #11
I know the ebay ones are pretty hit or miss but ehh if i were doing it again id probably chance it haha!
Originally Posted by Mi06Speed6 View Post
ATP DP has Vband?
Yep!
BMW 335xi 6MT
SOLD 8/29/14
 Old 04-11-2014, 10:42 PM   #12
I love my Cp-e downpipe. I'm so happy to have ditched my ebay one, it leaked everywhere.
MS6 Catback CLEARANCE www.cp-e.com Custom Performance Engineering (cp-e.com) 8 01-15-2010 02:22 PM
anyone have a downpipe with hks catback? blackspeedo MazdaSpeed 3 - Engine, Transmission & Driveline 5 08-15-2008 10:31 AM
Page generated in 0.33297 seconds with 26 queries
