Like Tree5Likes
  • 2 Post By RhoadBlock
  • 2 Post By Code Monkey
  • 1 Post By Dubcnea
 Old 02-29-2012, 01:47 PM   #1
RhoadBlock's Avatar
Posts: 793   (View Stats)
Groaned at 7 Times in 4 Posts
Default The MS6 Intercooler Thread
MS6 Top Mount Intercoolers
$2,090 - AutoEXE TMIC | Part Number: ML3990
An intercooler kit for the original exchange type DISI turbo. The core thickness has been increased over the stock intercooler and the volume capacity has been increased. The air intake temperature is lowered via the optimized outer and inner fins. Also, the inner tube with a tapered air intake entrance has improved the air permeability rate to approximately 60%* compared to the original part, reducing pressure loss. Output and acceleration response is improved. Bolt-on installation is available.
$399 - Corksport TMIC | Part Number: Gen-6-930-200
The CorkSport Top Mount Intercooler (TMIC) provides solid power gains and a great value add to the Mazdaspeed 3, MS6 and CX7 turbo. Made from CorkSport’s own custom cast end tanks which are TIG welded to a 3” thick bar and plate core, the TMIC provides added performance by removing the bottleneck restriction of the stock intercooler and increasing resistance to heat soak by using thicker materials. The cold pipe connection is CNC milled and drilled for a leak proof connection and all bolt holes have been capped off.
CorkSport’s innovative design allows for the reuse of the Mazda OEM plastic shroud giving purchasers the option of maintaining the stock look and feel to the engine bay. An optional aluminum ring is available and can be customized to compliment the finish of your engine bay.
The CorkSport TMIC has been vigorously tested to ensure optimal characteristics. Testing completed on a SuperFlow test bench proved a 46% increase in airflow over the Mazda OEM intercooler. During the testing, the CorkSport TMIC showed an average decrease in pressure across the core by 53% and an increase in overall efficiency of 25% over the stock intercooler.
The CorkSport Advantage:
Proven to provide 46% more airflow over the stock intercooler
Cast aluminum end tanks provide superior airflow over competitors folded tanks
Maintain your factory engine cover and keep the stock stealth and look of your engine bay
Reduces pre-detonation (knock) of the fuel air charge
Increased resistance to heat soak
Bar and plate intercooler core removes bottlenecking for more power with less boost
Fits the 2007-2009 Mazdaspeed 3, 2006-2007 Mazdaspeed 6, 2010+ Mazdaspeed 3, and Cx7
Choose from multiple custom finishing options to compliment your style
Corksport Service and Support: Receive full color installation instructions, all of the needed installation hardware, and knowledgeable telephone installation support
*Please note due to the design of the factory hood scoop on the 2010+ Mazdaspeed 3 the hood scoop seal will rest on the rear intercooler end tank with the optional aluminum shroud.
**Stock shroud molding may cause some fins to benf slightly. If you come across this issue, first of all, this will NOT affect performance or efficiency of your TMIC. The easiest and recommended way of removing the offending culprit is to trim the TMIC shroud. See Shroud Fitment Document for more details.
$399 - Custom Performance Engineering TMIC | Part Number: MMZRTMIKS
Top mount intercoolers have become one of the most popular bolt-ons for the MZR DISI engines. cp-e™ set out to design the best.
The biggest restriction of the stock TMIC is the outlet. Knowing this, cp-e™ alleviated these restrictions through a casting design with a smooth flowing unshrouded outlet. Both endtanks are completely cast to help flow in and out of the core while providing consistency. The core of the cp-e™ TMIC is made of bar and plate for its pressure efficiency and its cooling capabilities. The 3.25” thick core alleviates pressure drop while not interfering with the hood or surrounding components. cp-e™ determined the maximum fin density to create the largest temperature drop across the core. We have even capped every bolt hole location to prevent leaks that would normally go undetected by the consumer. The cp-e™ TMIC comes with 6061 billet CNC brackets machined to perfection on our 4 axis CNC machine.
The shroud is CNC laser cut from billet 6061 aluminum to provide the best possible fitment. The mounting tabs for the shroud are CNC machined from 6061 billet so that they match the shroud exactly.
All of these features add up to the best TMIC out there and cp-e™ is proud to announce the release of it.
$565 - Extreme Turbo Systems TMIC | Part Number: ETS_MS6_TOPMT
The ETS MazdaSpeed top mount intercooler is the best intercooler on the market, not only price but quality. This intercooler features a direct bolt on design using the factory mounting points. The core is a bar and plate design for maximum cooling and efficency. A direct bolt on aluminum shroud is provided with every intercooler to eliminate the black shroud. The intercooler was designed to eliminate all restrictions and bottle necks the stock intercooler provided. Each intercooler is pressure checked at 35psi and comes with a limited lifetime warranty against cracking.
Features:
Bar and plate core
Dyno proven gains of 20hp and 20tq on a stock vehicle (See Dyno Graph).
Pressure checked at 35psi
Direct bolt on
Upgraded aluminum shroud
Removed bottleneck the stock intercooler provided.
3.25" flows 1176 CFM (705hp based on flow, inlet/oulet restrict flow to ~600hp, surface area = 450hp at ~50mph, speed required for this power rating due to flow through the scoop.
MS6 Front Mount Intercoolers
$899 - Corksport Power Series MS6 FMIC Kit | Ate-6-130-03100
It is important to note that this kit reuses the factory TMIC location as a new air intake. You must keep the factory hood ducting for a ram air effect into the new intake location.
CorkSport offers the ulitmate in a front mount intercooler kit for theMazdaspeed 6.
The CorkSport Mazdaspeed 6 FMIC kit replaces everything from the intake to the engine in one complete package. We started with building a Ram Air system by utlilizing the stock intercooler location with an intake box. The ram air intake allows you to retain the factory intercooler cover to keep the engine bay looking good. Mandrel bent 2.25 ID aluminum pipe moves the charged air to the 21 in x 10 in x 3 inch intercooler then the engine. We have used the largest core possible without having to cut the crash bar or factory plastic undertray. We also offer an innovative solution to the intercooler pipe path allowing the intercooler to be a cross flow type with offset end tanks to get the most temperature difference with minimal pressure drop.
The Mazdaspeed 6 FMIC kit features the following:
- Quality aluminum intercooler core, 21 in x 10 in x 3 in, with cast end tanks
- Polished 2.25? aluminum piping with bead rolled ends and mounting brackets
- Optional Black Powerdercoated intercooler pipes for stealth installation
- CorkSport RAMAIR cold intake system with K&N Filter
- Billet machined MAF housing with turbo inlet pipe
- Black, Red, or Blue Silicone couplers
- Stainless steel T-bolt clamps
- All necessary hardware needed for installation
- Detailed installation instructions
- Pre-purchase option for Stock, HKS, or Greddy BOV flange.
- Optional ATP ?Boost Cut Killer?
The CorkSport Mazdaspeed 6 FMIC kit has undergone extensive testing in the shop and on the street.
You can expect the following from installing the kit:
- Peak power gains of around 30 horsepower and 40 ft-lbs of torque.
- Intake boost increases 1-4 psi over the operating range of the turbocharger compared to stock.
- AFR is safe to support the increase in boost from the more efficient intercooler.
The CorkSport FMIC kit works with the following bypass/blow off valves: Greddy, HKS, Stock, and Forge. If the valve you have is not listed here there may be some clearance issues.
$1,185 - Custom Performance Engineering MS6 Front Mount Intercooler Kit | MMS6FMIK
All front mount intercoolers are not created equal!
After a full year of testing and validation, Custom Performance Engineering(cp-e™) is pleased to announce the release of the ∆Core™Front Mount Intercooler. Being a true "form follows function" design, this intercooler was created from the ground up to outcool, and downright outperform the stock top mount intercooler in every respect. The end result does exactly that, and will maintain its superior efficiency all the way up to 450bhp.
The 20"x6"x3" bar and plate intercooler core is nestled between the bumper and the air conditioning condenser with a slight rake. The end tanks also feature a baffle to ensure that the incoming airflow is equally dispersed along the entire length of the intercooler. Both the 2.25" hot and cold pipes enter the vertical flow core from the driver's side, which eliminates a potentially detrimental 180° bend. And of course, all the hardware including the intercooler pipes are aluminum as opposed to mild steel both for weight savings and for added heat transfer while the air is sliding its way through the intricate piping. This kit also includes a stock BOV flange leaving the choice up to you. These are the kind of clever details that we engineer into all of our products, and is also what makes this more than just any front mount intercooler kit.
Still not convinced that we manufacture the finest front mount intercooler available for the SPEED6? We realize that people will not buy a product solely based on a manufacturer's word, so we validated our design by measuring the overall thermal efficiency, pressure drop, heat soak, and thermal response of both the stock and cp-e™ intercoolers. To view the FMIC validation paper please click below.
~$528 - There are also a few eBay companies that offer an FMIC kit for the MS6. These have actually been tried and proven as good kits. Find them from stores such as: CXRacing & Just-Intercoolers
You can also make your own custom FMIC using universal pipe kits and almost any intercooler core you like. Many have used ebay cores for their custom FMIC kits with success. A popular better quality core many have gone with is Treadstone Performance. They offer a good variety great quality intercooler cores for a good price.
Use the search function to find MANY threads on several members' own custom FMIC projects for ideas on how you can build one for yourself. Simply search "Custom FMIC" or something similar to see several threads.
If anyone has any links to custom FMIC builds post em up and I'll add em all to the OP.
Also....I know there's an L/A kit too I just can't find the link to it.
ESB Jiu JItsu and chuckms6 like this.
2007 MS6 - broked & gone
2006 MS6 - less broked
The Following 5 Users Say Thank You to RhoadBlock For This Useful Post:
Captain KR (02-29-2012), Raider (02-29-2012), redmnsterut (02-29-2012), SwineFLU (03-11-2012), Toddy22587 (03-02-2012)
 Old 02-29-2012, 01:54 PM   #2
redmnsterut's Avatar
Posts: 838   (View Stats)
redmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the world
Thanks for this, Im going to be in the market for a new TMIC or FMIC soon so this thread will be awesome! Could we also get some people that have said kits to leave some feedback on them?
SURE RMM | SURE Shift Weight | SURE SSP | CP-E CAI | CP-E DP | CP-E TIP | COBB AP |SnailD Tunned| TEIN Springs | SU Turbosmart BPV | Autotech HPFP Internals | Autolite XP step colder plugs | JBR Heavy Shift Knob | CXracing FMIC | Block8 Single Gauge Pod | MSD DashHawk
Waiting to be installed: SURE Dreadnaught | JBR Shifter Bushings | SU Boost Tubes | P&P Intake Manifold
Soon to come:SURE Intake/TB TIG | SURE Juggernaught | RSB |
286awhp / 346lbs tq @4500 ft ASL
redmnsterut is offline   Reply With Quote
 Old 02-29-2012, 01:55 PM   #3
Ya forgot the OG...
ETS, yo.
 Old 02-29-2012, 11:01 PM   #4
Death-From-A-Mile's Avatar
Posts: 1,371   (View Stats)
Death-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the world
Groans: 87
Good work, I still have a sticky up in the turbo section with my L2A, but it is for an MS3. Same concept though.
Death-From-A-Mile is offline   Reply With Quote
 Old 03-01-2012, 12:25 AM   #5
I<3Groceries's Avatar
Posts: 1,990   (View Stats)
Ya forgot the OG...
ETS, yo.
And AutoExe, the REAL OG.
Sent from my Galaxy Nexus using Tapatalk
 Old 03-01-2012, 08:19 AM   #6
RhoadBlock's Avatar
Added em
 Old 06-26-2012, 08:56 AM   #7
ESB Jiu JItsu's Avatar
Posts: 492   (View Stats)
ESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the world
this has been a great resource in me planning my FMIC build thank you! and I will post my build once complete. 2.25 piping should be in thrusday then its work work work!
2006 Mazdaspeed6 GT Liquid Platinum Metallic
"because racecar!" " I love this $%&*ing car"
-Gram Lights 57C 18"x7.5/Cooper SR3-A 2254018/H&R Springs/SURE RMM/Diff Straps
-2.75 Blow Through MAF/Custom CXracing FMIC&BOV/Fujita SRI/AEM dryflow/PG TIP/SLS TP/Exhaust Delete/NGK LTR7IX11 plugs/ TB Coolant BP/Bat->Trunk Relocation/JBR egr delete
-TWM Stage 2 Short Shifter/JBR Weighted Shift Knob/TWM 4in Shifter Extender
-Emil Drilled/Slotted rotors/Hawk HP Pads/Clutch Pedal Mod/Shift Counter Weight Mod
-Custom Vented Hood/Custom Front Bumper/Emblem delete/Prosport Mech. boost gauge
ESB Jiu JItsu is offline   Reply With Quote
 Old 01-01-2013, 08:26 AM   #9
blackstar's Avatar
Posts: 523   (View Stats)
blackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the worldblackstar is the leader of the world
Its the same as this one http://www.mazdaspeedforum.org/forum/foru...cloned-127322/ . It is a clone of the CX racing kit.
blackstar is offline   Reply With Quote
 Old 01-01-2013, 03:39 PM   #10
yonggie3587's Avatar
Posts: 149   (View Stats)
yonggie3587 is a splendid one to beholdyonggie3587 is a splendid one to beholdyonggie3587 is a splendid one to beholdyonggie3587 is a splendid one to beholdyonggie3587 is a splendid one to beholdyonggie3587 is a splendid one to beholdyonggie3587 is a splendid one to behold
Groaned at 5 Times in 1 Post
Sweet!!! Looks like I'm gonna get this one
Sent from my SPH-D710 using Tapatalk 2
yonggie3587 is offline   Reply With Quote
 Old 01-01-2013, 05:53 PM   #11
FullRace vertical flow FMIC as well.
 Old 10-22-2013, 07:55 PM   #12
bigdaddyaaron's Avatar
Posts: 36   (View Stats)
bigdaddyaaron will become famous soon enoughbigdaddyaaron will become famous soon enough
Groaned at 18 Times in 8 Posts
Anyone used the tr8c?
Sent from my iPhone using Tapatalk - now Free
bigdaddyaaron is offline   Reply With Quote
 Old 04-02-2014, 01:41 PM   #13
Police - Grammarhead
Vansquish's Avatar
Originally Posted by dtrackstar View Post
I wonder if the added weight and the cost is worth it. Thanks for your input
Sent from my Nexus 4 using Tapatalk
Once you've got a downpipe, HPFP internals, and a tune, yes. Furthermore, if you ever go for a larger turbo, it's worth it even more so.
 Old 08-06-2014, 03:36 PM   #14
Braindeadx64's Avatar
Posts: 180   (View Stats)
Braindeadx64 has a brilliant futureBraindeadx64 has a brilliant futureBraindeadx64 has a brilliant futureBraindeadx64 has a brilliant futureBraindeadx64 has a brilliant futureBraindeadx64 has a brilliant futureBraindeadx64 has a brilliant futureBraindeadx64 has a brilliant futureBraindeadx64 has a brilliant futureBraindeadx64 has a brilliant futureBraindeadx64 has a brilliant future
So I currently have a 2006 Coldpipe installed on my MS6, and I have a 2007 Intercooler and Coldpipe in the garage. I though i remember reading that the 2006 one was better, but I cant find the thread it was from years ago. Anyone have insight on this?
Braindeadx64 is offline   Reply With Quote
 Old 08-06-2014, 03:38 PM   #15
You will see zero difference by changing them. The design change was for ease of removal.
Braindeadx64 (08-06-2014)
 Old 08-06-2014, 03:39 PM   #16
dale_gribble's Avatar
Posts: 4,720   (View Stats)
It's not better. I ran the 06 v. 07 coldpipe expermient and it went nowhere. This was even on a BNR S3.
6 MS6s have bad choke point in TMIC cold tube
MINI H1 6.0 - CAR LED TAILS
Braindeadx64 (08-06-2014), ItsNox (08-11-2014)
 Old 07-08-2015, 10:36 AM   #17
Douggievee's Avatar
Posts: 71   (View Stats)
Douggievee is just really niceDouggievee is just really niceDouggievee is just really niceDouggievee is just really niceDouggievee is just really nice
So whats everyone doing nowadays for a FMIC setup that doesnt require removing the washer fluid tank?
2006 Mazdaspeed6 GT: Autotech Fuel pump, GT3071R, Cobb AP FreakTune, 3" Custom Magnaflow Turboback Dual Exhaust, Mazdaspeeed intake/turbo inlet tube, NGK XI 1 step colder plugs, Fidanza Flywheel, EGR/VTCS Delete, Cobb EBC, Cross drilled rotors, Corksport BPV, TSW Nurburgrings, Techna-Fit SS Clutch Line
Douggievee is offline   Reply With Quote
 Old 07-08-2015, 10:45 AM   #18
This.
 Old 07-08-2015, 01:34 PM   #19
Douggievee's Avatar
seems like alot of work, itd be easier to get an intercooler that has a driver side exit for hot and cold and just custom fab pipes where the intake goes.
 Old 07-08-2015, 01:45 PM   #20
^ FullRace, and old cp-e and CorkSport fit the bill.
 Old 07-08-2015, 02:01 PM   #21
Douggievee's Avatar
damn thats a nice but expensive ass intercooler from full race
 Old 09-14-2015, 05:16 PM   #22
42boxer's Avatar
Posts: 52   (View Stats)
42boxer is a jewel in the rough42boxer is a jewel in the rough42boxer is a jewel in the rough
Are there any front mounts out still that don't require deleting anything?
2007 Mazdaspeed6
http://www.mazdaspeedforum.org/forum/forum/f415/42boxer-2007-mazdaspeed-6-a-191641/#post2929172
2008 Mazda 3: sold
2000 Toyota Tacoma: sold
42boxer is offline   Reply With Quote
 Old 09-14-2015, 05:55 PM   #23
Currently no. Here's some threads I've started pertinent to your request. There's a few companies working on kits but they are doing the CX Racing over the engine/washer reservoir delete routing because it's easy; most kits are 2.5" ID which is a bit much for k04/BNR/CS turbo. I use my reservoir for meth so that was a non starter to me. Really, the only kit that's worth it and routes on the driver side and out of production is the CP-E kit for MS6.
Here's some more discussion on it.
Why won't any forum sponsors make an MS6 FMIC pipe kit?
Dale's custom FMIC setup for MS6 - take 2
 Old 09-14-2015, 05:57 PM   #24
All front mounts require deleting the top mount.
dale_gribble and BASEDGOD1 like this.
42boxer (09-18-2015), dale_gribble (09-14-2015), Gitcherex (03-14-2016), MS3Shadow (09-14-2015), rob ms6gt (09-14-2015)
 Old 02-01-2017, 03:46 AM   #25
Mazduhspeed6's Avatar
Posts: 157   (View Stats)
Mazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to all
Groaned at 17 Times in 6 Posts
So, I need to change my sig, I missed out on the treadstone kit when i went to order they were out. Sooo. My tuner has said to me I need to do something to remedy my bats, as they are getting high after a few pulls. Understandable on a stock tmic to a cs turbo. But I mentioned to him, that was fine next paycheck Im ordering the CPE tmic cause after looking at the ets and cpe, they are basically the same dimensions, cpe is just cheaper. Both 3.25 thick cores, Ive been doing corksport everything, but i read a thread on the cs tmic and i wasnt impressed so for a first time Im gonna have to do something different. So anyways, i said ok ill order the cpe tmic this paycheck and have it on in a jiffy, my tuner said eggh, you should go fmic with an ms6. Now here in lies my question, no arguement i know fmic is better and for about 100 bucks more or so, i dont feel like making my own piping. Back to, i see alot, and i mean ALOT of people on here with ms6s and they just have upgraded tmic, so give me some input people. What are your bats compared to your intake temp only if your driving ms6 and are you top mount or fmic? Just trying to figure out if i wanna take the time installing a front mount by myself out this cold or just cop a nice tmic for now. Tax time so i have the cash.
2007 Mazda Speed6 GT
Power: rebuilt stock motor*
JBR full power path stage II intake w/JBR TIP*
ATP catted downpipe w/ second cat delete*
Corksport HPFP internals*
Corksport BeCuse injector seals*
Corksport Turbo*
Corksport 3.5 Bar MAP sensor*
Corksport EBCS*
Treadstone Tr8 w/ RPM CX racing piping kit*
Suspension: Corksport Lowering Springs
Brakes: Still stock
Driveline: Sure Motorsports R6*
Sure Motorsports Juggernaut*
Sure Motorsports Dreadnaught*
Sure Motorsports shifter bushings*
Corksport weighted Black shift knob
Electronics: Cobb Accessport V3 w/ tune by Will at PD tuning*Purple Drank Tuning*
Mazduhspeed6 is offline   Reply With Quote
 Old 02-01-2017, 10:51 AM   #26
42boxer's Avatar
I had a upgraded top mount and then when to a front mount (cx racing and an eBay core). My bats improved a lot! By 20+ at the top of my pull. Your tuner is telling you that for a reason. You can buy eBay piping like the cx racing but then buy a nice core like treadstone and be set. You're gonna get much more spending the money to go front mount
2007 Mazdaspeed6
2008 Mazda 3: sold
 Old 02-01-2017, 02:20 PM   #27
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
With various upgraded TMICs (I've owned 4 different brands) and stock turbo, I've seen BATs go up 50F in a single pull/run at the strip. I've also seen BATs that were in the 210-220 range while tracking. They're all roughly the same, as long as you make sure you have some shroud on it.
I don't have FMIC data, yet; it was only recently installed.
@nindoja;
-Wetz
QFT
 Old 02-01-2017, 03:01 PM   #28
nindoja's Avatar
Posts: 2,395   (View Stats)
No FMIC on my 6, but even with the 3.5" ETS TMIC on my BNR S3, I was seeing 45-50 degree difference in temps between runs at the strip. Same day as @xfeejayx; was seeing similar.
Needless to say, FMIC is on my list once I get my engine back together.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
 Old 02-04-2017, 03:17 PM   #29
Honestly, I think the Treadstone kit is pretty nice and for what you get it's not overpriced. If I didn't already have an FMIC it's probably what I'd go with. My only complaint is I'm not a fan of Al crash bars.
Treadstone Front Mount Intercooler Kit Mazdaspeed 6 2006-2007 - EdgeAutosport.com
 Old 03-18-2019, 01:23 PM   #30
Reactorpwr's Avatar
Posts: 9   (View Stats)
Reactorpwr is an unknown quantity at this point
Corksport sent me a response to my FB message about their upcoming release of their new fmic. Said they were still on target for late spring/early summer release at a price of 499$. If it is loke their pictures, the hot side will route down driver side to IC back to IM on driver side. Thus your creature comforts that had to be removed for the other flavor fmic’s out there can be added back.
Reactorpwr is offline   Reply With Quote
 Old 03-18-2019, 01:50 PM   #31
Dubcnea's Avatar
Posts: 223   (View Stats)
Dubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond reputeDubcnea has a reputation beyond repute
Is that for a kit including IC? Or just a new IC?
2012 CPW Mazdaspeed 3
Dubcnea is offline   Reply With Quote
 Old 03-18-2019, 06:57 PM   #32
Reactorpwr's Avatar
From what i read it is a full kit
 Old 03-18-2019, 07:54 PM   #33
Dubcnea's Avatar
Hmmm interesting. Depending on core size that’d be one of the cheaper name brand kits. Curious to see final product now.
 Old 03-18-2019, 08:56 PM   #34
Reactorpwr's Avatar
Is what they showed in their blog announcing it in December
 Old 03-18-2019, 09:05 PM   #35
Dubcnea's Avatar
Wow. Weird. Pretty much the entire radiator. Hope their testing proves that to be, ya know, fine.
Reactorpwr likes this.
 Old 03-19-2019, 06:39 AM   #36
LenSpeed6's Avatar
Posts: 164   (View Stats)
LenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud of
@Dubcnea; its the same as the kit they previously had for MS6 but with improved piping design, if people had an overheating problem I would put money on that it came up with the original kit.
I wish that it came with a different crash bar, Im not about to spend a ridiculous $599 for just a crash bar from New Age...
06 Speed6
White/Black interior
Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts
To think... this is suppose to be my winter car... because,
'72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far
'12 1/2 Triumph Daytona 675R stock some how
'79 AMC Spirit AMX, 4.6L stroker I6
LenSpeed6 is offline   Reply With Quote
 Old 03-19-2019, 03:44 PM   #37
eroler1's Avatar
Posts: 133   (View Stats)
eroler1 is just really niceeroler1 is just really niceeroler1 is just really niceeroler1 is just really nice
yeah, damn that crashbar is expensive,
eroler1 is offline   Reply With Quote
LTA Intercooler Concept Thread J-Liss Mazdaspeed3/6 General Discussion 164 02-24-2014 10:48 AM
Page generated in 0.61210 seconds with 43 queries
