![]() | | #81 | ![]() |
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
| Not Ranked : 0 score
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
![]() | | #82 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
| Not Ranked : 0 score So what is still needed to produce adapters? If they're just going to be a flat spacer style adapter I can probably have some water jetted out of stainless.... You guys get me specs or a file to have cut and if its something I can have cut out of stainless on a waterjet I can probably have it within 2 weeks depending on complexity.
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson |
| The Following 3 Users Say Thank You to El_Diablo For This Useful Post: |
![]() | | #83 | ![]() |
![]() Join Date: Aug 2012 Location: Mundelein, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 322
(Thread Starter) | Not Ranked : 0 score I have been working 2 jobs like crazy to save and buy a house. Will be closing on the 15th and moving by the end of march. I will not have much time to work on drawing up flanges. The problem with the mitsu to MS turbo inlet flange is that they are both threaded for studs. The flange would need to be 3/4 inch thick and countersunk, finding / having custom bolts made in the right thread, shoulder and length have been tough. You would bolt a studded flange to the mitsu turbo. I have all the flange dimensions drawn up. I plan to make a flange and build a jig for a custom downpipe. I want to use the dsm housing with an external wastegate. This does need to be said though. I purchased a stock turbo manifold from a mazdaspeed for mock up. The manifold internally sucks for flow. I think the best solution would be for a custom mani with a custom flange. But that will still require a downpipe to be made too and therefore will kind of make doing all this pointless. I do however have drawn up A pair of conversion flanges for a t2 turbine housing that would allow it to bolt in with the stock manifold/downpipe. You can order a t2 turbine housing made for a td06 mitsu chra. This would make it a true bolt on with only needing a different thread pitch banjo bolt for the oil feed.
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! |
| The Following 3 Users Say Thank You to Turbo_Steve For This Useful Post: |
![]() | | #84 | ![]() |
![]() Join Date: Jun 2009 Location: Riverside, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,560
Groans: 50
| Not Ranked : 0 score Any updates to this? @Turbo_Steve;
__________________ 08 Mazdaspeed 3 Fucking FREEK TUNED and shit Last edited by Boosted Beluga; 09-17-2013 at 04:52 PM. |
![]() | | #85 | ![]() |
(Thread Starter) | Not Ranked : 0 score I have in the works is a k04 - mitsu hybrid. I have a subaru td06 20g turbo and a stock k04 exhaust housing. I always thought they could work together and now I know the td05/6 bearing housing can fit the k04 but with a td05 wheel. I am trying to see if a td06sl2 or hopefully a full td06 can fit.
| The Following 5 Users Say Thank You to Turbo_Steve For This Useful Post: | BigRedSpecial (09-18-2013), Boosted Beluga (09-17-2013), btstarcher (09-17-2013), El_Diablo (09-18-2013), speed3sailor (09-18-2013) |
![]() | | #86 | ![]() |
(Thread Starter) | Not Ranked : 0 score So I am going into the slow season at work. I will have lots of time to devote to this project. I have pretty much deemed the factory k04 turbine housing a worthless piece of junk. I can definetly make a td05 / k04 hybrid. The machine work isn't that involved but the down side is it looks like it can only be done with an oil cooled only chra. The chra needs to be turned down pretty far to fit the k04. It has enough material to do this but it looks like a water passage will be cut into. It may be weldable but this isn't something you want to risk. I also feel like the turbine itself is too restrictive. So the only answer is to make a new turbine housing. I am in the process of designing a high flow 8cm^2 td06sl2 bolt on turbine housing for the mazdaspeed.
| The Following 9 Users Say Thank You to Turbo_Steve For This Useful Post: | BigRedSpecial (09-25-2013), Boosted Beluga (09-25-2013), btstarcher (09-25-2013), cshunter (09-25-2013), Easter Bunny (09-26-2013), El_Diablo (09-25-2013), JTMS3 (09-25-2013), speed3sailor (09-25-2013), Voltwings (09-25-2013) |
![]() | | #87 | ![]() |
![]() Join Date: Mar 2011 Location: HACKNSACK, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 355
Subbed.
__________________ Black Mica Mazdaspeed 6 [SIGPIC][/SIGPIC] NJSpeed P&P IM, KMD internals, SU TMIC, BNR STG 1, Sure V1 Aeros, Cobb TIP, Turbosmart BOV, Magnaflow CBE JBR Trilogy, Jugg & Dread, Corksport Strut tower brace & rear seat brace, Tein Super Street C/Os 18x8 OZ Ultraleggeras, 225/45/18 Dunlop SportMaxx, 17x8 Enkei SC03, 235/45/17 Bridgestone Blizzaks, Evo Brembo mod, StopTech rotors, Techna-Fit S/S brakelines, StopTech & EBC Greenstuff pads The Mad Scientist Tunings | |
![]() | | #88 | ![]() |
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. | |
![]() | | #89 | ![]() |
Think more like ATP a full replacement turbo that is a bolt on, but this will use all the oem oil / coolant lines.
__________________ The Car - 08.5 True Red MS3 GT - MODS -Cp-e nano sri, HTP 3" tip, Autotech internals, Custom fmic 28x8x3.5 cx core, Cobb ap, Autolite XP5263, Turbo_Steve SHIFT HAMMER SSP, TRZ rear mount. Atp Downpipe and custom catted mid pipe. JBR TIG, tb gasket & egr delete, XS POWER V2 turbo manifold, Aem 30-3000 WMI Kit, Ported intake By Turbo_Steve. ADAPTED PERFORMANCE SHIFT HAMMER SSP - ADAPTED PERFORMANCE ENGINE COVERS Soon to come. WHO KNOWS? A.D.D. FTW! | |
| The Following 8 Users Say Thank You to Turbo_Steve For This Useful Post: | Agent_Orange (10-10-2013), Boosted Beluga (11-13-2013), btstarcher (09-26-2013), cshunter (09-26-2013), El_Diablo (09-26-2013), KiwiFlavor (08-04-2014), Koke382 (09-26-2013), Voltwings (09-26-2013) |
![]() | | #90 | ![]() |
![]() Join Date: Feb 2012 Location: Anaheim, Orange County
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,921
| Not Ranked : 0 score Subbed for sure sent from my peepee
__________________ 2007 Mazdaspeed 3 GT 18x8.75 XXR 527 225/40/18r COBB AP// Finkles hypnotic sexyness 50/50 e85// HTP 3.5 Whale Penis// HTP 51R battery box// JBR Adjustable SSP//JBR 88 RMM// Grimspeed 3 port EBCS// CX Racing FMIC// CNT Racing catless DP// AT internals// Lamin-x Fog light inserts// Stiffy Ingals Mtourque Mount// Asian tower brace(lol)// CNT Racing Catback// Turbo XS RFL BOV VTA FTMFW!!// Upgrated clutch// Drilled and sloted rotors (font and back)// UNDER THE KNIFE New fucken miata build: 1993 Red Na6 Some suspension modz yo 1994 Caste White MX5 Miata - sold 1991 Smurf Blue miata - sooooooold Coilovers// Other shit |
![]() | | #91 | ![]() |
(Thread Starter) | Not Ranked : 0 score Headache..... Check! Empty Wallet....... Check! Light at the end of the tunnel.... Check! I have sent off a td06 sl2 turbine housing to be cut into 2 pieces with a wire edm machine and then to be digitized. When I get the digitized file back I can then use the design of the td06 turbine housing and scroll. I will then add in the mazdaspeed flanges and wastegate swing valve with a 34/36 mm flapper. This file will then be used to make a pvc prototype using a 3d printer. If it all fits properly and looks good I then need to find a manufacturer who can cast turbine housings.
| The Following 15 Users Say Thank You to Turbo_Steve For This Useful Post: | 6ixof1 (10-04-2013), Agent_Orange (10-10-2013), BigjohnB20 (10-04-2013), BigRedSpecial (10-04-2013), Boosted Beluga (10-04-2013), btstarcher (10-05-2013), cshunter (10-04-2013), Dimenus (10-04-2013), El_Diablo (10-04-2013), KiwiFlavor (08-04-2014), Koke382 (10-07-2013), Kyle Undefined (10-04-2013), manila (10-04-2013), silvapain (10-10-2013), Voltwings (10-04-2013) |
![]() | | #92 | ![]() |
(Thread Starter) | Not Ranked : 0 score The next time you see these.... They will be one piece. Check back soon.
| The Following 15 Users Say Thank You to Turbo_Steve For This Useful Post: | Agent_Orange (10-10-2013), alphasaur (10-26-2013), Boosted Beluga (10-11-2013), btstarcher (10-11-2013), cshunter (10-11-2013), Dimenus (10-28-2013), El_Diablo (10-11-2013), goo (10-16-2013), guitarzan134 (10-11-2013), ItsNox (10-11-2013), jtt (10-10-2013), KiwiFlavor (08-04-2014), Koke382 (10-10-2013), memin (10-26-2013), Voltwings (10-10-2013) |
![]() | | #93 | ![]() |
(Thread Starter) | Not Ranked : 0 score 2 weeks and i should have a prototype turbine housing. I need to come up with a good name for this turbo. Something awesome to have cast into the compressor housing cover.
| The Following User Says Thank You to Turbo_Steve For This Useful Post: | Koke382 (10-26-2013) |
![]() | | #94 | ![]() |
Groans: 50
| Not Ranked : 0 score FYHN
__________________ 08 Mazdaspeed 3 Fucking FREEK TUNED and shit |
| The Following 4 Users Say Thank You to Boosted Beluga For This Useful Post: |
![]() | | #95 | ![]() |
| Not Ranked : 0 score I want a turbooooo sent from my peepee
| The Following User Says Thank You to Koke382 For This Useful Post: | Turbo_Steve (10-31-2013) |
![]() | | #96 | ![]() |
| Not Ranked : 0 score introducing the new BNR, the BFA (bad fuckin ass).
| The Following 2 Users Say Thank You to Voltwings For This Useful Post: | Koke382 (10-27-2013), Turbo_Steve (10-27-2013) |
![]() | | #97 | ![]() |
Groans: 769
| Not Ranked : 0 score BAMF-T
| The Following User Says Thank You to El_Diablo For This Useful Post: | Turbo_Steve (10-31-2013) |
![]() | | #98 | ![]() |
| Not Ranked : 0 score IHTFT "I haz teh fast turblo" sent from my peepee
![]() | | #99 | ![]() |
(Thread Starter) | Not Ranked : 0 score BOHICA Bend Over Here It Comes Again?
![]() | | #100 | ![]() |
| Not Ranked : 0 score TSRT sent from my peepee
![]() | | #101 | ![]() |
(Thread Starter) | Not Ranked : 0 score Still waiting for the turbine housing... 1-2 more weeks ![]() But the rest of the turbo is almost ready. Just need to weld the extension on the compressor outlet and install the wga when the turbine housing is here.
| The Following 10 Users Say Thank You to Turbo_Steve For This Useful Post: | BobtailedSnail (11-13-2013), Boosted Beluga (11-13-2013), btstarcher (11-14-2013), dsb_chicago (11-13-2013), El_Diablo (11-13-2013), KiwiFlavor (08-04-2014), Koke382 (11-13-2013), mdl3v8 (11-13-2013), Status Update (11-13-2013), timjs (11-13-2013) |
![]() | | #102 | ![]() |
![]() Join Date: Oct 2013 Location: Harrisburg, Pa
![]() | | #103 | ![]() |
Groans: 224
| Not Ranked : 0 score Lol I'm way ahead of you
| The Following 3 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post: |
![]() | | #104 | ![]() |
![]() Join Date: Apr 2011 Location: Chesapeake,VA
Rep Power: 901 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 672
| Not Ranked : 0 score This turbo is going to be nuts.
__________________ |
![]() | | #105 | ![]() |
Groans: 50
| Not Ranked : 0 score Realistically what kind of numbers at what boost do you think this would put out? IF you need/want any testers I can. I have a built motor, ported intake mani, ported head, 3.5" intake, 3port, catless exhaust, e85, rtubular exhaust mani.
![]() | | #106 | ![]() |
| Not Ranked : 0 score Same as me in for beta testing lol If not make some and sell here id be a customer for sure. sent from my peepee
| The Following User Says Thank You to Koke382 For This Useful Post: | Boosted Beluga (11-13-2013) |
![]() | | #107 | ![]() |
Should be pretty efficient at about 20-22 psi. I think the best thing about mitsubishi turbos is that they are inexpensive, reliable, don't have issues with smoking, and make great power.
| The Following 5 Users Say Thank You to Turbo_Steve For This Useful Post: | Boosted Beluga (11-13-2013), El_Diablo (11-13-2013), Koke382 (11-13-2013), MonstaSpeed6 (11-13-2013), Status Update (11-13-2013) |
![]() | | #108 | ![]() |
| Not Ranked : 0 score Im in for sure then lol sent from my peepee
![]() | | #109 | ![]() |
![]() Join Date: Jul 2011 Location: Elk Grove Village, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,411
Groans: 124
| Not Ranked : 0 score So is this a 20g with a mazda flange? Sry, glanced through the thread and saw the turbo. And what is this costing you? I can do a setup just like this......I was thinking of doing a big 16g or 20g swap on the ms3.....Guy that i take my car and big on dsm/evos has these turbos sitting around ((also rebuilds those turbos))
__________________ DBB Gen2 Pte6266, kozmic pte top mount manifold kit, Kozmic 4'' Intake, kozmic hood exit Dp+Dump, 11:1 Custom Wiesco Pistons + Monlar rods, Freek PnP head w/Supertech springs&retainers, L19 Head Studs, JMF PI Intake Manifold W/ custom single Walbro 450+ Fuelab Inline Pump, HKS BOV, Cp-e Stage2 RMM, Trz Tranny Mount, MD PMM, JBR Egr Block Off Plate, Cp-e Fuel Pump, Sheepey Built Fmic Core, 3.5 Bar Map Sensor, Precision Wastegate, TWM Shifter bushings, Freak Tuned! 713whp/569wtq! FIRST MS3 IN 10s! 10.963 @ 136.79 (8/12/2015) 10.72 @ 139.44! (10/1/2015) 10.43 @ 140.95! 10/9/2015 10.35 @ 140.86 (10/30/2015) New Time! Fastest Ms3 to date 10.27 @ 141.55 (5/22/2016) |
| The Following User Says Thank You to mazdafreak For This Useful Post: | Boosted Beluga (11-13-2013) |
![]() | | #110 | ![]() |
Groans: 50
| Not Ranked : 0 score 20g td06 is what I got out of it. Lol I could be mislead with all the different talk in this thread.
| The Following User Says Thank You to Boosted Beluga For This Useful Post: | mazdafreak (11-13-2013) |
![]() | | #111 | ![]() |
Groans: 124
hahaha, thats why i asked. okay sweet. Gonna ask my guy about that setup too....Was planning on going with the pte5858 after winter. I could always try this setup out and have faster spool.
__________________ DBB Gen2 Pte6266, kozmic pte top mount manifold kit, Kozmic 4'' Intake, kozmic hood exit Dp+Dump, 11:1 Custom Wiesco Pistons + Monlar rods, Freek PnP head w/Supertech springs&retainers, L19 Head Studs, JMF PI Intake Manifold W/ custom single Walbro 450+ Fuelab Inline Pump, HKS BOV, Cp-e Stage2 RMM, Trz Tranny Mount, MD PMM, JBR Egr Block Off Plate, Cp-e Fuel Pump, Sheepey Built Fmic Core, 3.5 Bar Map Sensor, Precision Wastegate, TWM Shifter bushings, Freak Tuned! 713whp/569wtq! FIRST MS3 IN 10s! 10.963 @ 136.79 (8/12/2015) 10.72 @ 139.44! (10/1/2015) 10.43 @ 140.95! 10/9/2015 10.35 @ 140.86 (10/30/2015) New Time! Fastest Ms3 to date 10.27 @ 141.55 (5/22/2016) | |
![]() | | #112 | ![]() |
| Not Ranked : 0 score i think you are missing what he's doing. he's not just machining a 20g into a k04 housing he's getting a new housing cast that will flow better then the stock housing but it will still have the stock flanges on it.
| The Following 2 Users Say Thank You to 2.0t03speed For This Useful Post: | btstarcher (11-14-2013), El_Diablo (11-14-2013) |
![]() | | #113 | ![]() |
![]() Join Date: Nov 2011 Location: Lex. Park, Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 866
| Not Ranked : 0 score @Turbo_Steve; Progress is coming along nicely! I too would like to know the cost out of all this? (If you don't mind answering that)
__________________ '12 MS3 Black Mica w/ Tech COBB AP V3 >> AUTOTECH HPFP >> HTP 3.5" >> ATP DP (catless) >> AXLEBACK (no mufflers) >> COBB PIPING/TR6 CORE >> JBR RMM >> SSP/BUSHINGS >> RSB >> STG. 2 OCC >> HYPNOTIC TUNED: tehmadscientist & senor finkle |
| The Following User Says Thank You to manila For This Useful Post: | mdl3v8 (11-13-2013) |
![]() | | #114 | ![]() |
Groans: 124
Yeah that's what I saw when he posted those two pics of the vband and mazda flange hotside. Either way, I'd be done to try something similar.
![]() | | #115 | ![]() |
(Thread Starter) | Not Ranked : 0 score My thoughts for doing this are that mitsubishi turbos rock. Ko4 turbine housing sucks and can only go as big as a td05 wheel with an oil cooled only mitsubishi chra. So this required a custom housing. Lets add a 34mm wastegate port while we are at it. This design will hopefully open up a ton of options for the platform. There will be at least 4 turbos built. What happens with them is to be determined. Please stay tuned for more info when the prototype is finished. If this works out well and there is demand, I may have a run of these made for sale, but I will have to get an ok from the proper channels on here to sell them. I have some contacts I am going through and may be able to get these out for a really great price.
| The Following 8 Users Say Thank You to Turbo_Steve For This Useful Post: | 6ixof1 (11-14-2013), Boosted Beluga (11-13-2013), btstarcher (11-14-2013), El_Diablo (11-14-2013), manila (11-13-2013), mdl3v8 (11-13-2013), Status Update (11-14-2013), Vansquish (11-14-2013) |
![]() | | #116 | ![]() |
And mad props on working on this seriously. sent from my peepee
__________________ 2007 Mazdaspeed 3 GT 18x8.75 XXR 527 225/40/18r COBB AP// Finkles hypnotic sexyness 50/50 e85// HTP 3.5 Whale Penis// HTP 51R battery box// JBR Adjustable SSP//JBR 88 RMM// Grimspeed 3 port EBCS// CX Racing FMIC// CNT Racing catless DP// AT internals// Lamin-x Fog light inserts// Stiffy Ingals Mtourque Mount// Asian tower brace(lol)// CNT Racing Catback// Turbo XS RFL BOV VTA FTMFW!!// Upgrated clutch// Drilled and sloted rotors (font and back)// UNDER THE KNIFE New fucken miata build: 1993 Red Na6 Some suspension modz yo 1994 Caste White MX5 Miata - sold 1991 Smurf Blue miata - sooooooold Coilovers// Other shit | |
![]() | | #117 | ![]() |
| Not Ranked : 0 score it's going to be iwg according to his last post. it's just going to have a bigger port.
| The Following 3 Users Say Thank You to 2.0t03speed For This Useful Post: |
![]() | | #118 | ![]() |
sent from my peepee
![]() | | #119 | ![]() |
Groans: 50
| Not Ranked : 0 score Block off the iwg.
| The Following User Says Thank You to Boosted Beluga For This Useful Post: | Koke382 (11-13-2013) |
![]() | | #120 | ![]() |
__________________ '12 MS3 Black Mica w/ Tech COBB AP V3 >> AUTOTECH HPFP >> HTP 3.5" >> ATP DP (catless) >> AXLEBACK (no mufflers) >> COBB PIPING/TR6 CORE >> JBR RMM >> SSP/BUSHINGS >> RSB >> STG. 2 OCC >> HYPNOTIC TUNED: tehmadscientist & senor finkle | |
| New Borg Warner EFR Turbochargers!!! | Alpha | MazdaSpeed 3/6 - Turbo Induction | 122 | 11-06-2018 07:05 PM |
| BorgWarner sues Cummins over patents on titanium turbochargers | Haltech | Automotive News | 0 | 10-26-2011 05:10 PM |
| Nissan studying turbochargers for future vehicles? | Haltech | Automotive News | 0 | 08-03-2009 12:00 PM |
| Honeywell discussing U.S. gas turbochargers with GM | Haltech | Automotive News | 1 | 09-16-2008 03:42 PM |
| Honeywell to sell turbochargers to Ford in U.S. | Haltech | Automotive News | 0 | 07-30-2008 10:50 AM |
