  • 1 Post By MoMS3
 Old 05-10-2017, 01:11 PM   #1
GroceryGtr's Avatar
Posts: 472   (View Stats)
Default Mixed Flow turbo.. CS?
As I continue to debate my turbo upgrade path I've been looking into wheel designs and such and from the pictures the CS appears to be a mixed flow whereas the BNR s3 appears to be radial? Can anyone more knowledgeable confirm this.
 Old 05-10-2017, 03:32 PM   #2
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
I think you are talking about the extended tips on the compressor wheel. Details are in the CS turbo white paper. BNR uses a basic cast wheel.
2018 Audi RS3
2007 Acura TSX 6MT
 Old 05-10-2017, 04:42 PM   #3
zenit's Avatar
Posts: 1,364   (View Stats)
-feejay
-wetzel
Tomas (05-11-2017)
 Old 05-10-2017, 05:57 PM   #4
MoMS3's Avatar
Posts: 235   (View Stats)
MoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond repute
As far as I know the only mixed flow turbines available for our platform are used in the Borg Warner EFR turbos. Further, I think you're getting mixed up on mixed flow/extended tip. Mixed flow turbines are for the hot side, billet compressor wheels with extended tips are different animals altogether. From eyeballing the CS turbine, it looks like radial flow.
2012 Velocity Red Mica MS3 Tech
For Powah: JBR Tru 3.5" WP, CP-E TMIC, UR V3 Catless DP/Reso. TP, CS Resonated CBE, CS HPFP Internals, Cobb AP, DM PMM, DM TMM, CS Stg 2 RMM, CS Shifter Bushings, CS Dual VTA BPV, South Bend Stage 3 Endurance clutch, Damond Motorsports SSP, CS 3.5bar MAP, Stratified S-OTS+ Stg 3 E85 tune for summer, Pump S-OTS+ Stage 3 for winter, for now
Handling: JBR .250 RSB w/ billet brackets.
So I can see/be seen better: DDM LED for Nagare Accent lights, DDM Switchbacks Front turn signals, Osram CBI's, ADVmonster LED Fogs
To-do List: BNR S4, maybe S5...bottom end build, probably should do brakes/suspension at some point. Shooting for a 450-500whp daily driver.
MoMS3 is offline   Reply With Quote
The Following User Says Thank You to MoMS3 For This Useful Post:
zenit (05-10-2017)
 Old 05-10-2017, 07:42 PM   #5
zenit's Avatar
You're absolutely right. I misread the previous post- disregard the above.
-feejay
-wetzel
 Old 05-11-2017, 06:13 AM   #6
GroceryGtr's Avatar
MoM answered my question, you have better eyes than I. the hotside wheel was always in the background so I couldn't tell for sure. In the 2nd pic the bottom blade kinda looks angled, but that must be from the camera angle playing tricks. Zenit you were correct, on the first pic that's what I was referencing.
IS EFR across the lineup now? I thought originally they only had one of the series/sizes on a mixed flow wheel.
 Old 05-11-2017, 11:13 AM   #7
MoMS3's Avatar
That's the CS turbine for reference (and probably the angled pic you're referring to) ^^
As far as I know, the only EFR for our application with mixed flow wheel is the 7163.
zenit likes this.
Aftermarket Turbo Flow Rates - Informational List PapaSmurf MazdaSpeed 3/6 - Turbo Induction 16 06-29-2015 03:35 PM
Mixed info on turbo acarmona24 MazdaSpeed 3/6 - Turbo Induction 91 10-24-2014 01:50 PM
Gutted cat flow ~= SLP Loudmouth Resonator? Flow cant be hurt I dont think.. 08Anamoly MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-04-2010 01:07 PM
GM's mixed message Haltech Automotive News 0 04-05-2009 10:10 PM
Page generated in 0.27921 seconds with 23 queries
