 Old 08-28-2014, 01:00 PM   #1
acarmona24's Avatar
Posts: 62   (View Stats)
acarmona24 is a name known to allacarmona24 is a name known to allacarmona24 is a name known to allacarmona24 is a name known to allacarmona24 is a name known to allacarmona24 is a name known to all
Default Mixed info on turbo
Ok. I took my car to the Mazda dealership cause I wanted to see what the car needed since I just bought it (2007). They said the turbo was bad and so was the fuel pump. They said Intake seal leaking internally also has past and presentt codes in the b c m. Which I have no idea what that means. I took the car back to where I bought it. They said they cleaned the injectors now car doesn't feel like it want to stall at 3k rpms. The owner of the dealership also said he has been driving the car all week to see if the car shows any symptoms and had no problems. The dealership quoted me $1900 for the new turbo and I don't know what to do or what other steps to take to find out if the turbo is really out. Any suggestions!
acarmona24 is offline   Reply With Quote
 Old 08-28-2014, 01:18 PM   #2
biggman026's Avatar
Posts: 453   (View Stats)
biggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the worldbiggman026 is the leader of the world
Groaned at 49 Times in 12 Posts
Are you getting a bunch of white smoke out of the exhaust? If so, your turbo seals are leaking. You can also pull the intake and check for shaft play.
I would ask them how they determined the turbo and fuel pump were bad, and ask them to show you.
2007 Mazdaspeed 6 - Black Mica - ZZB RIP 2016!
BNR S3, JBR 3" wp intake, JBR rmm, JBR heavy shift knob, JBR shifter bushings, JBR SSP, South Bend Stage 3 Endurance clutch, Juggernaught/Dreadnaught, Autotech HPFP, 3 bar map sensor, Stratified Boost Dial, Streetunit TMIC, Forge V2 BPV, ebay DP/TP, 3 inch custom single exit cat-back, magnaflow muffler, H&R springs, Cobb AP, JL Audio 12" W3 w/ 500w Alpine amp, 6000k HIDs, LED fogs, dipped and tinted - Stratified 369awhp/383awtq vdyno on 4 gallons of corn
biggman026 is offline   Reply With Quote
 Old 08-28-2014, 01:24 PM   #3
acarmona24's Avatar
No smoke. They said they plugged it to the computer and thats what it read.
 Old 08-28-2014, 01:28 PM   #4
biggman026's Avatar
Someone with far greater knowledge than I can confirm or deny this, but I don't think you can determine a turbo and fuel pump are bad with a diagnostic scanning tool based on trouble codes. Sure, you can take a datalog and see that fuel pressures are dropping at WOT and thus you've got hpfp problems, but I don't see that being something you can determine with the car just sitting in the shop.
The Following 5 Users Say Thank You to biggman026 For This Useful Post:
acarmona24 (08-28-2014), Downmented (09-02-2014), kgb (08-28-2014), memin (08-30-2014), Vansquish (08-28-2014)
 Old 08-28-2014, 01:59 PM   #5
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
Why are they saying the pump is bad? It is fuel pressure at idle? If so, it could be the relief valve.
The Following 4 Users Say Thank You to JSmith For This Useful Post:
Easter Bunny (08-28-2014), kgb (08-28-2014), SamiChicago (08-28-2014), WetzMS3 (08-29-2014)
 Old 08-28-2014, 02:01 PM   #6
Lakespeed6's Avatar
Posts: 2,403   (View Stats)
No such code for bad turbo.
You by it from a rep dealer? Cleaning our injectors is not an easy task.
Do you have an AP? Did you throw a check engine light?
How many miles. What are the symptoms?
1990 Nissan Skyline GTR
1991 White BMW 325ic
The Following 6 Users Say Thank You to Lakespeed6 For This Useful Post:
Easter Bunny (08-28-2014), kgb (08-28-2014), mr.speedy3 (08-29-2014), SamiChicago (08-28-2014), Vansquish (08-28-2014), WetzMS3 (08-29-2014)
 Old 08-28-2014, 02:10 PM   #7
Police - Grammarhead
Vansquish's Avatar
^^ Agreed.
There are no codes for a "bad turbo" or for an "intake seal leaking internally" (whatever the hell that means). You could be running rich, or running lean, and that could be what they're trying to say. You might consider asking for the specific numbers of the CEL codes stored in the BCM. At least that way, we might be able to provide more specific advice.
The high pressure fuel pump does occasionally fail, but you would have to be monitoring and logging fuel pressure in order to find this out.
I'm also going to call B.S. on "cleaning the injectors." They probably threw some octane booster or "injector cleaner" in the gas, but there's no way that they properly cleaned the injectors. You have to remove the intake manifold, pull the injectors, send the injectors out for cleaning (which probably also means replacing each injector's internal plastic filter with a metal one), acquiring and installing new injector seals along with the cleaned injectors, and then reinstalling the intake manifold and all the other shit that had to be removed to access the injectors.
It sounds like you need to get yourself a different set of mechanics.
The Following 7 Users Say Thank You to Vansquish For This Useful Post:
ALPINEST4RS (08-28-2014), Downmented (09-02-2014), Easter Bunny (08-28-2014), kgb (08-28-2014), mr.speedy3 (08-29-2014), SamiChicago (08-28-2014), WetzMS3 (08-29-2014)
 Old 08-28-2014, 02:17 PM   #8
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
What dealer is this? Just so we can make sure that no one brings their car to them.
Are they a mazdaspeed certified dealer?
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
The Following 3 Users Say Thank You to smoogs12 For This Useful Post:
Easter Bunny (09-02-2014), kby (08-30-2014), kgb (08-28-2014)
 Old 08-28-2014, 03:52 PM   #9
SpencerC's Avatar
Posts: 2,159   (View Stats)
This is all sorts of weird.
As people previously stated, there is no Turbo Fail code. It also is very rare that any dealer would clean injectors on a used car they were selling. Plus $1900 for a turbo job is very high. You could buy yourself a new turbo that is better than stock and still be able to pay most shops to install it for you for that cost. Or buy a used K04 for about $300 and install yourself. Dirt cheap. Honestly if it ain't smoking, and there is no shaft play, you are fine.
 Old 08-28-2014, 09:48 PM   #10
acarmona24's Avatar
Ok. I'm back had fantasy draft tonight. They said that they put BG44k to clean the injectors. So yeah no real cleaning. Now this was the shop that sold me the car. When I went to go pick up the car today it ran fine. But after an hour or so the CEL came back on. It started shaking at 3k rpms and whe I come to a stop I hear a weird noise coming from the engine. Sounds like a diesel truck and like a chain is knocking or rattling.
 Old 08-29-2014, 02:54 PM   #11
buttons's Avatar
Posts: 142   (View Stats)
buttons is a splendid one to beholdbuttons is a splendid one to beholdbuttons is a splendid one to beholdbuttons is a splendid one to beholdbuttons is a splendid one to beholdbuttons is a splendid one to beholdbuttons is a splendid one to behold
I just picked up a mazdaspeed 6 GT a few weeks ago. I thought i had a heatshield rattling, but it was the timing chain hitting the valve cover. When the car is cool, take the oil cap off and see if there is any slack in your timing chain. mine had so much slack that i could probably pull it off the sprocket with one finger. (though it made a horrible racket at idle) my car drove just fine and pulled strong.
To check turbo shaft play, remove battery, remove turbo inlet pipe - -you should be able to see if the shaft has any play.
Ok so I took the car to autozone for a CEL check and it came back as system to lean at idle-right bank or fuel system malfunction or MAF sensor faulty or ignition system malfunction.
Could try taking the the maf out and carefully spraying some maf cleaner on it a few times.
2006 White Mazdaspeed 6 Sport - Sold
2007 Blue Mazdaspeed 3 GT - Sold
2006 Red Mazdaspeed 6 GT - I/TIH/SU TMIC/3 port BC/Springs/Wheels
Last edited by buttons; 08-29-2014 at 02:54 PM. Reason: MSF Database - Automerged Doublepost
buttons is offline   Reply With Quote
The Following User Says Thank You to buttons For This Useful Post:
acarmona24 (08-29-2014)
 Old 08-28-2014, 10:00 PM   #12
ALPINEST4RS's Avatar
Posts: 905   (View Stats)
Groaned at 8 Times in 3 Posts
BG44K is piss in a can. Fuck all dat.
Stop driving your car, check your oil. If its good, go to autozone and get a free CEL scan. Tell me the codes and I will atleast explain to you what you need to do man.
I can't stand these fucking dealers that are Mazda certified. No wonder our customer loyalty is so low. Jesus.
The Following 6 Users Say Thank You to ALPINEST4RS For This Useful Post:
acarmona24 (08-28-2014), btstarcher (08-28-2014), Downmented (09-02-2014), Easter Bunny (09-02-2014), kgb (09-12-2014), mr.speedy3 (08-29-2014)
 Old 08-28-2014, 10:03 PM   #13
acarmona24's Avatar
Thanks. I will do that first thing in the morning and post the codes. I appreciate it. I'm new here so I apologize for the ignorance. But I do appreciate the friendliness and help.
The Following User Says Thank You to acarmona24 For This Useful Post:
 Old 08-28-2014, 10:15 PM   #14
btstarcher's Avatar
Posts: 4,852   (View Stats)
Also update your profile to include location; maybe find someone local to take a look. Donating to the forum also gets you access to service manuals, forum classifieds, and lots of other goodies, to include Nator. Check it out, it's well worth it.
acarmona24 likes this.
SnailTune in progress
The Following 2 Users Say Thank You to btstarcher For This Useful Post:
acarmona24 (08-28-2014), Easter Bunny (09-02-2014)
 Old 08-29-2014, 01:52 PM   #15
acarmona24's Avatar
 Old 08-29-2014, 01:54 PM   #16
biggman026's Avatar
That's a lot of codes. For the lean at idle check your connections for leaks, for the MAF try cleaning the MAF sensor. Don't know what to tell you on the others.
 Old 08-29-2014, 01:56 PM   #17
JSmith's Avatar
Groans: 106
Did they give actual code numbers?
The Following 3 Users Say Thank You to JSmith For This Useful Post:
btstarcher (08-29-2014), Easter Bunny (09-02-2014), Vansquish (08-29-2014)
 Old 08-29-2014, 02:07 PM   #18
Vansquish's Avatar
Do you have an aftermarket intake?
 Old 08-29-2014, 02:22 PM   #19
Sensei's Avatar
Posts: 318   (View Stats)
Sensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the worldSensei is the leader of the world
It would be a good idea to check your timing chain tension through the oil fill especially since you heard a chain rattling noise.
2009 MS3: Freektune 280/330, CS SRI+TIP, 3" Test Pipe, TR8 FMIC, AT internals, APv3, JBR SSP/CW/SB, JBR RMM 88a, JBR PMM 80, Koni FSD/Stock Springs
Sensei is offline   Reply With Quote
The Following 3 Users Say Thank You to Sensei For This Useful Post:
acarmona24 (08-29-2014), mr.speedy3 (08-29-2014), skiptowncat (09-01-2014)
 Old 08-29-2014, 03:41 PM   #20
Mylifeiseasy's Avatar
Posts: 74   (View Stats)
Mylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud ofMylifeiseasy has much to be proud of
Groaned at 6 Times in 3 Posts
IMO! The dealerships are the worst place ever to take a mazdaspeed they have no clue it seems. Do lots and lots of reading on here and or Find someone local who owns the same car and does there own work on there car. Someone like that can help you get your car sorted out in a hurry and save you loads of butt hurt!! Unless your a rich bitch! And love some butt hurting!
2008.5 gtx fmic dm pd Manley
Mylifeiseasy is offline   Reply With Quote
The Following User Says Thank You to Mylifeiseasy For This Useful Post:
 Old 08-29-2014, 03:49 PM   #21
acarmona24's Avatar
My bad the code that showed up was P2187
No. Everything is stock.
Last edited by acarmona24; 08-29-2014 at 03:49 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-29-2014, 04:10 PM   #22
Lakespeed6's Avatar
Either you have a leak in you're intake somewhere or a dirty maf.
Get some maf cleaner and clean your maf. Follow the directions on the bottle.
Check to make sure your air filter is good too.
Then check all connections on in take to the turbo.
The Following 2 Users Say Thank You to Lakespeed6 For This Useful Post:
acarmona24 (08-29-2014), WetzMS3 (08-29-2014)
 Old 08-29-2014, 04:00 PM   #23
If I start me car and let it idle for too long about 10-15 mins it will throw that code. Idk why. I tried everything I can think of. I just reset it now when it happens and I don't worrie about it. It mostly happens in winter when I'm letting the car warm up so it can shift niclely when driving. At around 0 degrees. It's just easier to warm the trans up then drive. It don't like to shift when it's that cold.
 Old 08-29-2014, 04:36 PM   #24
Vansquish's Avatar
It could be any number of things, actually.
Any leak between the MAF sensor and the O2 sensors could be the culprit. That means it could be a dirty MAF sensor, a busted evap purge valve, an unplugged or otherwise disabled EGR valve, an untightened hose clamp in the intake tract somewhere on the engine-side of the MAF, an intake mani leak, a boost tube leak, an intercooler leak, and so forth.
 Old 08-29-2014, 04:57 PM   #25
acarmona24's Avatar
 Old 08-29-2014, 05:03 PM   #26
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
So you need a VVT job it sounds like (among other things). If you're under 70k, take it in because thats free under warranty.
If it is over 70k, try calling MazdaUSA AND go to a different stealership. They're basically robbing you saying this and that, and you would have probably paid this or that if you never came to MSF.
We had a local recently who had a stretched chain and was at 86k miles, MazdaUSA pushed the warranty claim through and he got it replaced same day (might be a record there).
Point is, listen to the folks here, we kind of know what we're doing, most of the time at least.
 Old 08-29-2014, 05:13 PM   #27
acarmona24's Avatar
I'm already at 153k miles. I'm gonna have to find a local to help me out.
 Old 08-29-2014, 05:15 PM   #28
For a p2187 it's important to check basics first. It's a very generic code.
There is also a ecu software update depending on your model/year
The Following User Says Thank You to ALPINEST4RS For This Useful Post:
 Old 08-29-2014, 09:03 PM   #29
acarmona24's Avatar
So just an update. As I was getting off the highway coming down the ramp to get on the access road my car complete died on me. I was able to put it in neutral and roll down to the side of the road. It took me like 5 mins to get the car back on. I did not mess with anything. I sat there looking confused and pissed! Try to turn it back on and it came back on as if nothing ever happened. I was able to make it home. Tomorrow I will be cleaning the MAF and making sure everything is connected to the turbo right.
 Old 08-30-2014, 05:59 AM   #30
Try unplugging the maf and see if it runs better.
btstarcher (08-30-2014)
 Old 08-30-2014, 12:47 PM   #31
acarmona24's Avatar
Ok so I checked the turbo and there is no shaft play. Leads me to believe the turbo is good. Come to find out there was not one oz of oil in the car. I can not believe both dealerships didn't check that!! It's my fault for thinking the dealership I bought it from would've checked and fill all fluids on the car before selling it. The one thing that I do hear is the chain knocking every 40 seconds. I don't know how much that's gonna cost. I drove the car after filling it up with oil and it seems ok. It still shakes at 3k rpms though.
 Old 08-30-2014, 05:39 PM   #32
btstarcher's Avatar
So you pulled the drain plug and nothing came out? Or there wasn't any on the dipstick? Because there's a huge difference.
 Old 09-02-2014, 01:51 PM   #33
Vansquish's Avatar
I know this sounds like a dumb question, but how do you know it was low on oil? I know that you checked it via the dipstick, but did you check it while it was on level ground, or was the front end of the car up in the air? If so, the "low" reading on the dipstick doesn't tell you anything useful.
 Old 09-02-2014, 01:56 PM   #34
acarmona24's Avatar
yeah the car was on level ground.
btstarcher (09-02-2014)
 Old 08-30-2014, 03:18 PM   #35
Once these cars run out of oil it's over man. You're going to have problems, sorry man.
 Old 08-30-2014, 05:49 PM   #36
acarmona24's Avatar
Well.. dipstick. I didn't even think of pulling the drain plug as soon as I saw no oil on the stick I went and bought a jug of 5 quarts. I was more worried about damage to the engine at that point.
 Old 08-30-2014, 06:17 PM   #37
btstarcher's Avatar
God I hope you didn't put 5 quarts in....
Downmented likes this.
The Following 3 Users Say Thank You to btstarcher For This Useful Post:
anavrinIV (08-30-2014), Downmented (09-02-2014), Easter Bunny (09-02-2014)
 Old 08-30-2014, 06:32 PM   #38
acarmona24's Avatar
Lmao!!! Oh hell no! Give me a little credit here!lol
The Following 2 Users Say Thank You to acarmona24 For This Useful Post:
btstarcher (08-30-2014), Easter Bunny (09-02-2014)
 Old 08-30-2014, 06:47 PM   #39
btstarcher's Avatar
Well then it was low, how much did you add? I think stock it holds 6 quarts? It wasn't dry though right?
 Old 08-30-2014, 07:15 PM   #40
acarmona24's Avatar
No it wasn't dry just didn't show any at all. I put about 3 1/2
Its time to upgrade the turbo, need help/info with flange and ar setup sg1320 MazdaSpeed 3/6 - Big Turbo Builds 20 12-19-2011 01:30 PM
Info about going big turbo Graham MazdaSpeed 3/6 - Big Turbo Builds 8 04-05-2011 08:34 PM
Looking at the Viper 5301V Alarm/Remote Start/Turbo Timer install info mordant80 MazdaSpeed 3/6 - Car Audio & Electronics 3 10-08-2008 07:52 AM
Page generated in 0.58337 seconds with 32 queries
