 Old 11-11-2009, 11:39 PM   #161
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Did you pick up a stock IM just to pass inspection?
I already had a stock IM, but I don't want to have to swap it out once a year... So I sent it to Whoosh to be ported, but he's going to leave the EGR leg intact, so I can connect it for the OBD2 test and then bypass it the rest of the time...
 Old 11-12-2009, 01:51 AM   #162
Speed3Max's Avatar
Posts: 114   (View Stats)
Speed3Max has a brilliant futureSpeed3Max has a brilliant futureSpeed3Max has a brilliant futureSpeed3Max has a brilliant futureSpeed3Max has a brilliant futureSpeed3Max has a brilliant futureSpeed3Max has a brilliant futureSpeed3Max has a brilliant futureSpeed3Max has a brilliant futureSpeed3Max has a brilliant future
Groaned at 23 Times in 8 Posts
That mount that pulled the engine off center would have caused the drive shaft to stress, and potentially spray grease.
Speed3Max is offline   Reply With Quote
 Old 11-12-2009, 08:16 AM   #163
Groans: 60
It didn't really pull it off center, it just sat a 1/2" low on the passenger side.
I've already replaced the drive shaft. The front boot was completely torn. The shop had to have dropped it or kicked something into the boot while the DS was on the ground.
 Old 11-14-2009, 08:51 PM   #164
Docnox's Avatar
Posts: 1,435   (View Stats)
Docnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the world
Groans: 35
That under-hood shot is sexy as hell. I love the turbo mounted up like that. I hope you get everything worked out soon, I can't imagine having that beast sitting right in front of you without being able to drive her.
'06 Speed 6
Black Mica
Mazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe,
3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp
Altered Customs fmic, Autotech fp internals
Cobb AP, Stage 2+ 93 tweaked
Centric blanks, EBC red pads
Lotek center gauge pod: AEM wideband, Autometer boost and volts
Tints, blacked emblems, spec-v front lip, Shark fin
Redline MT-90, ITV-22s, Matt Damond OCC
13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap)
DO Meth kit waiting on install
Docnox is offline   Reply With Quote
 Old 11-15-2009, 02:38 AM   #165
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
jeez man, can't wait til that thing is finished up, hopefully everything will get ironed out soon. it looks awesome, congrats!
 Old 11-16-2009, 08:39 PM   #166
tropmonky's Avatar
Posts: 4   (View Stats)
tropmonky will become famous soon enough
Wow, what a roller coaster of a story to read... I just read this thread from start to finish! I wish you luck!!!!
tropmonky is offline   Reply With Quote
The Following User Says Thank You to tropmonky For This Useful Post:
SSinstaller (11-16-2009)
 Old 11-19-2009, 09:38 AM   #167
speedms6's Avatar
Posts: 825   (View Stats)
speedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the worldspeedms6 is the leader of the world
thats good stuff
speedms6 is offline   Reply With Quote
 Old 11-19-2009, 10:00 AM   #168
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
lol if i can uninstall my IM in 25 mins flat im sure you can do it faster. once a year isent that bad esp after all you've been through you needa get this shit running lol
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 11-19-2009, 10:31 AM   #169
Groans: 60
I'm not much for unnecessary work.. I want a built, big power motor, but I also want it as reliable, and easy to maintain as possible. Swapping the manifold in and out every year just seems like a big waste of time..
After a year of waiting another few weeks doesn't even bother me...LOL
 Old 11-19-2009, 10:53 AM   #170
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
What are the direct reasons for the egr cel again? I've heard the ecu monitors the IM vacuum level, and expects to see a drop in vac when the egr is open. And if it doesn't it throws the cel right?
Might be a stretch, but could you hook a hose routed off the intake to IM EGR port to fix it and use a different solenoid with the egr solenoid control lines? And on the head side of the egr, you just use the normal block off plate.
Might not be worth it, but would probably work, unless i'm over looking some stuff.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 11-19-2009, 10:55 AM   #171
Must Have Teh 10's!
well considering the CEL delete is top priority for cobb next to the FP tables then i think you wont have to wait too much longer.
 Old 11-19-2009, 11:09 AM   #172
Captain
Hopefully, as long as Cobb's priorities don't shift. I know they've been expanding alot into other platforms recently.
www.permtuning.com
 Old 11-19-2009, 11:09 AM   #173
Groans: 60
It might work, but you'd have to use the actual EGR valve to correctly mimic the OEM 4-stage egr function. The issue would be matching the vacuum change created by the actual exhaust gas versus what would happen if it pulled from the intake post MAF.. Without knowing what the expected change for each EGR lift value actually is(or even when the egr uses each lift value) it would be very time consuming to monitor the map and EGR to figure it out... IMO it's way more complication than it is worth..
I'm running the SB, but if cobb keeps up the AP developement, my SB may become a glorified boost and meth controller....
 Old 02-23-2010, 07:46 PM   #174
Groans: 60
Quick update.
Got the IM back from Whoosh.
Got the new flashes and SB firmware from CP-E.
Got the new PTP injector seals.
The IM goes to the powder coater on Friday..
I hope to get the IM and injector seals on the car sometime next week, and get the car inspected and registered shortly after...
The Following 2 Users Say Thank You to SSinstaller For This Useful Post:
djuosnteisn (02-23-2010), SpeedSixxx (02-23-2010)
 Old 02-23-2010, 08:01 PM   #175
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
please, please... get this damn thing running!!!!! hahaa
2008 STi
Intake
Turboback
AP
The Following 3 Users Say Thank You to danesti For This Useful Post:
djuosnteisn (02-23-2010), SpeedSixxx (02-23-2010), SSinstaller (02-23-2010)
 Old 02-23-2010, 08:06 PM   #176
ATE BALLER's Avatar
Posts: 3,227   (View Stats)
ATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the world
You must have the lowest mileage MS6 by now, lol.
Originally Posted by StreetUnitMark View Post
I don't think I could go one day without some sort of meat in my mouth.
ATE BALLER is offline   Reply With Quote
The Following 4 Users Say Thank You to ATE BALLER For This Useful Post:
danesti (02-23-2010), djuosnteisn (02-23-2010), SpeedSixxx (02-23-2010), SSinstaller (02-23-2010)
 Old 02-23-2010, 08:07 PM   #177
Mazdanspeed3's Avatar
Posts: 157   (View Stats)
Mazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond reputeMazdanspeed3 has a reputation beyond repute
looks like a beast! good luck with registration...
Mazdanspeed3 is offline   Reply With Quote
 Old 02-23-2010, 08:10 PM   #178
Groans: 60
lol. Bought it feb of 06, was at ~22500 miles last time I drove it..
The Following User Says Thank You to SSinstaller For This Useful Post:
 Old 02-23-2010, 08:37 PM   #179
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
I think MSP6COP still holds that title at around 5k or something. I so want to see this car run and be a success. Way too many problems lately with other cars.
The Following 3 Users Say Thank You to jmhinkle For This Useful Post:
djuosnteisn (02-23-2010), SpeedSixxx (02-23-2010), spiker98 (02-22-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/new-toys-have-started-arrive-8122/
albuquerque nm mazda 6 owners - Mazda6 / Atenza This thread Refback 02-19-2009 07:02 PM
Day of 12/16/2008: Top 50 of 250 Referring Pages This thread Refback 12-17-2008 09:15 AM
Injector testing is started. ptperformance MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 34 09-26-2008 10:56 PM
ISPs throw their toys out of the pram Haltech Computers & Technology News 0 04-11-2008 01:30 PM
Report: Microsoft May Give XP a Reprieve as New Eee PC Clones Arrive Haltech Computers & Technology News 0 04-01-2008 10:40 AM
Technologue: Booze Clues - Cheap hooch may soon arrive at your corner filling station Haltech Automotive News 0 03-26-2008 01:14 AM
Page generated in 0.37908 seconds with 32 queries
