 Old 04-09-2008, 04:37 PM   #1
SgtP's Avatar
Posts: 2,130   (View Stats)
SgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the world
Groans: 106
Default Is this normal?
I installed my Prosport BC(by BC i mean BG....) a while back and had a quick question on the numbers I am seeing. In 3 gear or higher, it spikes to 20 and then settles a little higher than 15psi. Should it be spiking that high? Its not holding that high at all, just a quick spike. The only mods I have so far is a Cobb SRI. Just making sure this is normal before I order a MBC and make my MAP clamp.
SgtP is offline   Reply With Quote
 Old 04-09-2008, 04:38 PM   #2
i hope you invested in a fail safe such as a map clamp or a boost cut defender.
 Old 04-09-2008, 05:12 PM   #3
SgtP's Avatar
Groans: 106
I have neither but I didn't expect to need them just running an intake. I have not experiencing any boost cut at all, just some spikes to 20 that I got worried about.
 Old 04-09-2008, 05:24 PM   #4
Well it will help you control a spike in the 20+ range which you dont want.
 Old 04-09-2008, 05:39 PM   #5
SgtP's Avatar
Groans: 106
Do you think its an actual spike or a lack of accuracy in the gauge. I wonder what I would see if I bought the STRI or DEFI gauge.
 Old 04-09-2008, 05:40 PM   #6
Spike is common, esp with a MBC. What are you currently using to monitor the boost?
 Old 04-09-2008, 07:48 PM   #7
SgtP's Avatar
Groans: 106
Holy shit i just noticed I said it was a Prosport BC.... Its a Prosport BG...my bad lol No BC installed atm. That changes things a lot lol.
 Old 04-09-2008, 07:50 PM   #8
lol yeah it does.
 Old 04-09-2008, 08:03 PM   #9
SgtP's Avatar
Groans: 106
Yea so no BOOST CONTROLLER installed yet. Just the Cobb SRI and Boost GAUGE. Are spikes that high still common with no BC installed?
 Old 04-09-2008, 08:08 PM   #10
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
mine spikes like that. Only to around 19psi though. I has Intake + TBE
 Old 04-09-2008, 08:12 PM   #11
Derek88's Avatar
Posts: 773   (View Stats)
Derek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the world
I have a datalog that shows that I spiked to 23psi in 3rd gear. No worries from over here...
-Derek
No longer in the Mazdaspeed Family
Derek88 is offline   Reply With Quote
 Old 04-09-2008, 08:27 PM   #12
SgtP's Avatar
Groans: 106
makes me feel better now. Its just barely hitting 20. I have the warning set at a little over 20 and it hasn't gone off yet. Can't wait to get my MBC and make my clamp. I want it now but I might get my TBE first. probably makes more sense.
Page generated in 0.31216 seconds with 22 queries
