Like Tree3Likes
Closed Thread
 Old 07-10-2010, 09:17 AM   #561
the95z's Avatar
Posts: 130   (View Stats)
the95z is a splendid one to beholdthe95z is a splendid one to beholdthe95z is a splendid one to beholdthe95z is a splendid one to beholdthe95z is a splendid one to beholdthe95z is a splendid one to beholdthe95z is a splendid one to behold
Groaned at 8 Times in 7 Posts
Originally Posted by nyghtryder View Post
comeon now what did you think was going to happen when you removed your cats.
Power like any other turbo car?
00 DPW Honda Prelude 5spd.~ (Husbands)
08.5 CPW Mazdaspeed 3 GT 6spd. ~~(Wifes)
the95z is offline
 Old 07-10-2010, 12:56 PM   #562
nyghtryder's Avatar
Posts: 1,903   (View Stats)
nyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the world
sry this isnt any other turbo car. When you get a catless dp your almost guarenteed to smoke. The best chance you will have is get the ptp pill, an occ, and change to 5w40.
A Kabar is just a paper weight until it's in the hand of a Marine.
If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground.
COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS
NATOR PA
nyghtryder is offline
 Old 07-10-2010, 03:00 PM   #563
the95z's Avatar
^ comment back FAIL! you are putting down our car..it has a big flaw. haha. i kno thx!
the95z is offline
 Old 07-13-2010, 05:09 PM   #564
GAMISTAD's Avatar
Posts: 25   (View Stats)
GAMISTAD is on a distinguished road
Thumbs up
I have an 06 MS6 white pearl, (that was smoking) 22K miles, Saiko OCC installed per COBB, PTP pill, shell 5w 40, and still smoking. Finally about 4 weeks ago I replaced,installed an oil restrictor, for one with less oil flow bolt into the Ko4, surprise, surprise no smoking for a few weeks; Yesterday morning there was heavy traffic on I 10 east Houston and guest what? Smok#$@! It quit soon after.
Oh well, the solution alternatives are just too many to list them at this point.
Happy trails!!
GAMISTAD is offline
 Old 07-14-2010, 03:06 PM   #565
nyghtryder's Avatar
Happy trails!!
you started smoking at 22k or youve been smoking for 22k? if youve been smoking for a long period its possible that the turbo seals are now the problem, not the pcv system.
NATOR PA
 Old 07-14-2010, 03:12 PM   #566
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
just wanted to say i got a bnoon bolt and my smoking is gone
Oil restrictor bolt install
xcoldricex is offline
 Old 07-14-2010, 03:26 PM   #567
nyghtryder's Avatar
is he still making those, i need to pick one up
NATOR PA
 Old 07-14-2010, 09:52 PM   #568
tvissues's Avatar
Posts: 94   (View Stats)
tvissues has a reputation beyond reputetvissues has a reputation beyond reputetvissues has a reputation beyond reputetvissues has a reputation beyond reputetvissues has a reputation beyond reputetvissues has a reputation beyond reputetvissues has a reputation beyond reputetvissues has a reputation beyond reputetvissues has a reputation beyond reputetvissues has a reputation beyond reputetvissues has a reputation beyond repute
i'm telling you guys the krank vents solve the problem. people don't realize we have a regular pcv valve that doesn't react fast enough to a change in pressure. when the intake mani goes from vacuum to positive pressure, pressure will be pushed into the crank case due to the pcv valve not closing until .5 to 1 psi, that's more than enough to cause the oil to not drain from the turbo and the pressure from the oil inlet to push the seals out enough to leak. it did this on my big turbo as well, i put the krank vents on and i have been driving for thousands of miles, i'm even about to take a 3000 mile round trip and will be making 100% sure things are sound. So far though i'm quite satisfied when i pull my dip stick out of the hole while the car is running and HEAR the vacuum. Vacuum that should be there, not pressure. The great thing about the krank vents is that they close BEFORE it even reaches 0 or equal pressure. The vent is made to close when the crankcase side is lower pressure than the intake manifold, vacuum or not. i have researched this and have found logic in this, which causes maximum vacuum for the crankcase yet closes to maintain that vacuum while under boost. If anyone wants a technical on how these work and why just let me know and I can explain the mechanics to it.
Mod list is in the link, too much to place in here
http://www.mazdaspeedforum.org/forum/foru...28/#post413665
tvissues is offline
 Old 07-14-2010, 09:57 PM   #569
ILL3ST
xcoldricex's Avatar
yeah i still have to get those krankvents. i was the one who suggested them on these boards
 Old 07-15-2010, 04:53 PM   #570
tvissues's Avatar
lol, well quite a suggestion my friend. The operation makes sense unlike some of these other attempts.
tvissues is offline
 Old 07-16-2010, 05:37 AM   #571
MPSdriver's Avatar
Posts: 136   (View Stats)
MPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the worldMPSdriver is the leader of the world
Originally Posted by tvissues View Post
...If anyone wants a technical on how these work and why just let me know and I can explain the mechanics to it.
I wouldn't mind reading that
I might give the krankvents a go. Oil has been seeping through the valve cover vent into and out of the turbo inlet and I'm hoping that installing krankvents might resolve that.
Anyway if you feel like it, you might want to post it in the thread on the CrankCase Evacuation System
Thanks
MPSdriver is offline
 Old 07-16-2010, 06:55 PM   #572
ILL3ST
xcoldricex's Avatar
smoke is back
The Following User Says Thank You to xcoldricex For This Useful Post:
SofaKingAwesome (08-28-2012)
 Old 07-16-2010, 09:04 PM   #573
tvissues's Avatar
Thanks
you have oil seeping out of your valve cover? do you have a catch can on the crankcase vent?
tvissues is offline
 Old 07-17-2010, 05:15 AM   #574
MPSdriver's Avatar
Not directly but oil has been leaking over the transmission housing (see pic) and bottom plate. I'm suspecting it leaks past the worm clamp on the inlet of the turbo via the VC breather.
After the last three dealer oil changes my oil level was way above max when I checked it at home. Dealer claims they did't overfill but couldn't explain why the level was obviously to high. My theory for the oily mess was that under boost the PCV valve wouldn't shut decently and the crankcase would get pressurized. That pressure would be evacuated through the VC breather. As the car had to much oil I would expect the air flow through the VC to be saturated with an oil aerosol.
Funny thing is my car doesn't smoke at all, not even after long periods of idling. I'm planning on disassembling the intake, TIP , I/C and cold pipe to verify and probably clean.
Maybe I should put a CC on the VC to make sure the oil comes from there and not from the turbo b/f I go krankvent.
/jack
 Old 07-17-2010, 12:14 PM   #575
J-villa's Avatar
Posts: 354   (View Stats)
J-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the worldJ-villa is the leader of the world
Groans: 46
That's a common occurrence with our car. The motor in our car requires 6 quarts of oil. However, through some flaw in manufacturing, design, or assembly, our dip stick sits a tab bit too low in the block. This means when you have 6 quarts in your car like you should, it'll read high.
Don't fret it.
Om Nom Nom
[Flickr]
J-villa is offline
 Old 07-17-2010, 02:06 PM   #576
MPSdriver's Avatar
The weird thing is I have seen them fill it up. They put in 5 liters (with a digital readout on the fill hose) and check the dipstick which reads low. They put in another .2 liters and it's still between low and max. They put another .2 liter in and it's right below the max sign. The EU manual states 5.7 liters but the 5.4 liters they put in already puts it at max. Then after some driving the dipstick reads way above the max, I mean up to the serpentine thingy in the dipstick... Its like the oil changes density after the first heat cycle I just can't explain it otherwise.
 Old 07-28-2010, 02:56 PM   #577
Ploppity Drown's Avatar
Posts: 236   (View Stats)
Ploppity Drown has a reputation beyond reputePloppity Drown has a reputation beyond reputePloppity Drown has a reputation beyond reputePloppity Drown has a reputation beyond reputePloppity Drown has a reputation beyond reputePloppity Drown has a reputation beyond reputePloppity Drown has a reputation beyond reputePloppity Drown has a reputation beyond reputePloppity Drown has a reputation beyond reputePloppity Drown has a reputation beyond reputePloppity Drown has a reputation beyond repute
Don't fret it.
Seems more likely that the dealerships just don't fully drain the old oil before dumping a full 6 quarts back in it. There are lots of nooks and crannies for oil to hide in. Even when I lean the car side to side I still can't get all 6 quarts out.
And personally, I wouldn't take an overfill lightly. My last car needed a new valve cover gasket---and I suspect it was my habitual oil overfilling that damaged it. Too much oil --> Too much oil pressure --> Leaks
Ploppity Drown is offline
 Old 07-28-2010, 03:00 PM   #578
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
i go to a local shop since i can get receipts for all my oil changes immediately (they keep all electronically) and they overfilled me once.
the amount of blue smoke coming out my tailpipe was incredible. first and easiest route for the excess pressure is your turbo seals.
8.5MS3 is offline
 Old 07-28-2010, 03:09 PM   #579
evidence's Avatar
Posts: 1,033   (View Stats)
Yea I have free oil changes for the life of the car with my dealer, so to cover my ass I just bring my PP to them and have em do the swap. If I bring 6 qts they ALWAYS overfill and I wind up having to drain and still waste time i was trying to avoid.. I now dump half of one of the bottles elsewhere and bring them 5.5. Scary that even dealers don't seem to care about overfilling, unless they know something we don't and the dipstick reads low or somethin like mentioned, but I'd like to hear this confirmed as its much safer to be running a bit under full.
Some things.
evidence is offline
 Old 07-28-2010, 04:16 PM   #580
Think with your dipstick, evidence.
It sounds like you already do. Dealership mechanics get paid by the job, not by the hour. They have little incentive to take care and do the job the right way. You've found a way to make it impossible for them to overfill. Stick with it, especially if their labor is "free" to you. I tried a couple times to communicate with the mechanics, but to no avail. Since then I've just been DIY. But I like your idea...
 Old 07-28-2010, 05:23 PM   #581
8.5MS3's Avatar
Groans: 326
well since my fuckup, I have them put 5 quarts in, wait 10 minutes then check the stick and add as necessary. once full, i then have them start the car, let it idle for a minute. turn it off, wait another few minutes and top off as necessary...
still comes out over the full line the next time i check it lol
8.5MS3 is offline
 Old 07-28-2010, 06:37 PM   #582
cudaman's Avatar
Posts: 155   (View Stats)
cudaman has a reputation beyond reputecudaman has a reputation beyond reputecudaman has a reputation beyond reputecudaman has a reputation beyond reputecudaman has a reputation beyond reputecudaman has a reputation beyond reputecudaman has a reputation beyond reputecudaman has a reputation beyond reputecudaman has a reputation beyond reputecudaman has a reputation beyond reputecudaman has a reputation beyond repute
Also note this if you push too much boost for the efficiency of most any turbo, excess heat build up can cause seal failure or shaft issues:
K04 TURBO REPORT FROM NEUSPEED
2. OPERATION
The K04 is designed to provide reliable, long-term service as long as its performance parameters are not exceeded. Driving the car at engine speeds above 5800 rpm with 15spi or greater boost significantly increases the exhaust temperature measured inside the K04 turbine housing. This signals that the maximum efficiency of the turbocharger has been exceeded, and that the energy produced by the turbine housing is now converting to heat rather than accelerating the compressor wheel faster. Unless a careful and extended idle-down is performed at the end of every hard driving session, the rapid heat build-up from high boost/high rpm operation causes the turbine shaft to soften, and allows the inconel turbine head to droop. The result is an imbalance that ultimately leads to a shaft failure.
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and torque is how far you make it through the wall.
cudaman is offline
 Old 07-28-2010, 07:37 PM   #583
8.5MS3's Avatar
Groans: 326
Thats from a 1.8 VW. not a 2.3 MZR
apples to oranges
we have it worse off than the VW
8.5MS3 is offline
 Old 07-28-2010, 07:46 PM   #584
aspiring turbo guru
08_ms3_gt's Avatar
Posts: 1,040   (View Stats)
apples to oranges
as in the 1.8T w/ a swapped K04? or the TT 225hp w/ the stock K04?
haha we may have it worse than a 1.8T w/ the turbo, but not overall. former 1.8T owner here. coilpacks, anyone?
08_ms3_gt is offline
 Old 07-29-2010, 10:55 AM   #585
morgan2112's Avatar
Posts: 29   (View Stats)
morgan2112 is on a distinguished road
Groaned at 7 Times in 4 Posts
GOOD LORD!!!!
I believe the 90 day period for deploying the PCV fix has expired.
Has Mazda decided otherwise?
Seems very strange that they would make an official announcement of the issue and then never follow up?? Has anyone heard anything or should we all start calling Mother MAZDA??
morgan2112 is offline
The Following User Says NO Thank You to morgan2112 For This Un-useful Post:
 Old 07-29-2010, 10:57 AM   #586
8.5MS3's Avatar
Groans: 326
you do that and let us know how it turns out
8.5MS3 is offline
The Following User Says NO Thank You to 8.5MS3 For This Un-useful Post:
 Old 07-30-2010, 03:29 PM   #587
morgan2112's Avatar
Wink
Sorry there YANK 8.5, but I was hoping several of us could collectively call and then compare answers. I am definitely willing to call and raise CAIN. BTW is 1-800-222-5500
The best number?? I hope you can see my logic here??
 Old 07-31-2010, 02:59 PM   #588
8.5MS3's Avatar
Groans: 326
your about a year too late there tex
Disclaimer: Above pic is not to generalize all texans, just the brownie above
8.5MS3 is offline
 Old 08-02-2010, 07:43 AM   #589
morgan2112's Avatar
Don't know about you but I am still under warranty for a few months, and was hoping to get my PCV system fixed for free. Thanks for all your wise tutelage..
 Old 08-02-2010, 07:54 AM   #590
8.5MS3's Avatar
Groans: 326
enjoy your free oil change, cuz thats all you're getting
8.5MS3 is offline
 Old 12-09-2011, 03:41 AM   #591
ms3destroyer's Avatar
Posts: 218   (View Stats)
ms3destroyer is the leader of the worldms3destroyer is the leader of the worldms3destroyer is the leader of the worldms3destroyer is the leader of the worldms3destroyer is the leader of the worldms3destroyer is the leader of the worldms3destroyer is the leader of the worldms3destroyer is the leader of the worldms3destroyer is the leader of the worldms3destroyer is the leader of the worldms3destroyer is the leader of the world
you know if an after market turbo will end up smoking
ms3destroyer is offline
The Following User Says NO Thank You to ms3destroyer For This Un-useful Post:
Raider (12-09-2011)
 Old 12-09-2011, 06:00 AM   #592
8.5MS3's Avatar
Groans: 326
8.5MS3 is offline
 Old 12-09-2011, 01:31 PM   #593
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
jesus christ.
http://www.mazdaspeedforum.org/forum/foru...23-11-a-73738/
'08 CWP MS3 w/ T3 3071r
802MS3 is offline
Raider (12-09-2011)
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/official-smoking-turbo-response-mazda-32008/
Mazda3 Totaled (ouch pics) Now a MS3 owner - Mazda3Forums.com This thread Refback 10-07-2012 09:30 AM
• View topic - MPS reputable dealer in Cape Town (long idle smoke) This thread Refback 09-17-2012 02:43 PM
Free PSP ISO Downloads EUR PSP ISO & CSO Downloads This thread Refback 05-02-2012 07:56 AM
MS3 Mazdaspeed 3 Smoking Turbo @ Dealership - YouTube This thread Refback 10-11-2011 08:47 AM
‪MS3 Mazdaspeed 3 Smoking Turbo @ Dealership‬‏ - YouTube This thread Refback 07-24-2011 03:58 PM
YouTube - ‪MS3 Mazdaspeed 3 Smoking Turbo @ Dealership‬‏ This thread Refback 05-18-2011 11:13 PM
Mise fire Mazdaspeed 3 2008 This thread Refback 11-24-2010 01:14 PM
YouTube - MS3 Mazdaspeed 3 Smoking Turbo @ Dealership This thread Refback 11-03-2010 11:35 AM
ANy love for the Mazdaspeed6?: Grassroots Motorsports forum: Grassroots Motorsports Magazine This thread Refback 06-15-2010 06:54 PM
NASIOC - View Single Post - The Mazdaspeed 3 Thread This thread Refback 12-29-2009 11:13 AM
The Mazdaspeed 3 Thread - Page 120 - NASIOC This thread Refback 12-21-2009 08:36 AM
Mazda6 / Atenza > mazda admits smoking problem!!!!!! This thread Refback 08-18-2009 07:54 PM
2.3disit Smoking Turbo - Club Mazda This thread Refback 07-10-2009 11:13 AM
smoke, has anyone had this? - Page 2 - COBB Forums This thread Refback 07-09-2009 08:02 PM
mazda admits smoking problem!!!!!! - Mazda6 / Atenza This thread Refback 07-08-2009 03:45 PM
Official Smoking Turbo response from Mazda - Colorado Mazda Club This thread Refback 07-08-2009 02:07 PM
Im in the smoking turbo club.:( SharkDiver MazdaSpeed 3/6 - Turbo Induction 154 09-26-2012 10:16 AM
Smoking turbo issue - Gone for me! kgb MazdaSpeed 3 - Engine, Transmission & Driveline 16 05-27-2009 03:56 PM
Causes/Solutions: Smoking turbo after DP Install kgb MazdaSpeed 3/6 - Turbo Induction 28 02-25-2009 10:58 AM
ANOTHER Smoking Turbo... div2 MazdaSpeed 3/6 - Turbo Induction 23 10-22-2008 07:27 PM
My turbo was replaced under warranty last month and it's smoking again!! BlackMS3 MazdaSpeed 3/6 - Turbo Induction 34 07-26-2008 09:34 PM
Page generated in 0.51832 seconds with 35 queries
