 Old 03-26-2017, 12:42 PM   #1
pastry00's Avatar
Posts: 154   (View Stats)
pastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud of
Groaned at 5 Times in 1 Post
Default Oil Return Line
I recently replaced my turbo with another stock k04. The oil return line was not fitting properly no matter what i tried. I managed to bolt it on but it is now leaking. I'm not sure if it cracked somewhere. Does anyone have any recommendations? I was looking at the kozmic Motorsports line but i'm not sure if it will come with he flanges that will fit the oem turbo.
Oil Return Line Kit, Mazdaspeed 3 and 6
pastry00 is offline   Reply With Quote
 Old 03-26-2017, 01:24 PM   #2
That's a speed3 kit, it will not fit a speed6, and their website says so.
 Old 03-26-2017, 03:33 PM   #3
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
It will fit, it's just a pain in the ass. You may have cross threaded a bolt, or possibly a gasket came off while installing, it happens to almost everyone.
Just get one bolt threaded in about 2 turns on the turbo side, then get one in on the block side, and go from there.
 Old 03-26-2017, 05:50 PM   #4
Djohns's Avatar
Posts: 3,944   (View Stats)
Jesus man. Aren't you getting rid of the car? You're sinking a lot of money into a car you're saying goodbye to.
2010 black mica speed3
Soon:built motor
 Old 03-29-2017, 07:53 AM   #5
MSMS3's Avatar
Posts: 2,826   (View Stats)
I just replaced my turbo with a BNR stage 1 to address the smoking issue.
The oil return line should be attached to the bottom of the turbo first. You should be able to reuse the metal gaskets if you did not damage them.
When you get to the block side the tube will be standing away from the block perhaps a half inch. You need to push it against the block, line up the gasket and holes and start one bolt then the second and pull it into the block.
I think those two lower bolts are longer. Not sure.
Oil return line Gribbs1469 Mazdaspeed3/6 General Discussion 2 04-18-2016 01:08 PM
Page generated in 0.24718 seconds with 24 queries
