 Old 03-04-2009, 08:21 PM   #1
oncogene1's Avatar
Posts: 50   (View Stats)
oncogene1 is a jewel in the roughoncogene1 is a jewel in the roughoncogene1 is a jewel in the rough
Default over boost
I am working on a custom tune with christian at cobb for my ms6 that is fully bolted with a pt performance sst turbo. After doing the logs we are seeing boost above 22 psi with the wgdc at 0. Christian is suggesting I add a cat to my catless down pipe or drill out the restrictor pill.
I don't want to add a cat unless I have to because it just seems like a backwards thing to do to control boost. I guess what I asking is if there is another way around the boost problems like adding an external gate? Any suggestions? Thanks
oncogene1 is offline   Reply With Quote
 Old 03-04-2009, 09:17 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
You could do an external gate, but drilling the restrictor out would probably work.
 Old 03-04-2009, 09:45 PM   #3
oncogene1's Avatar
Any idea on how much should be drilled out?
 Old 03-04-2009, 09:38 PM   #4
I<3Groceries's Avatar
Posts: 1,990   (View Stats)
Well, sheyat. This is what I have to look forward to.
 Old 03-04-2009, 09:47 PM   #5
oncogene1's Avatar
I must say I actually like the way the car runs with this turbo and at 22psi! The problem is its just not controlled. It rips though
 Old 03-17-2009, 09:01 PM   #6
ptperformance's Avatar
Posts: 4,123   (View Stats)
Wait till you get it up to 24 psi, its damn scary at those levels.
 Old 03-04-2009, 10:23 PM   #7
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Trust me, you want control man. The drilled out pill will basically allow more boost to press against your waste gate spring. Cobb suggests .042 - .060" for big turbos IIRC. You could prob drill yours out to like 0.05" or so. Don't go too big though, otherwise you'll have a hard time bleeding enough air through your solenoid to actually build boost. Just do a little bit at a time.
Somewhere on cobb's site there is a paper about how mazda controls boost, it talks about the effects of drilling the pill out.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 03-17-2009, 09:01 PM   #8
You could just get off the silly stock control and go with a real boost controller?
Now before I get flammed let me explain. Why would you try to use the stock controller and the pill mod if your not on a stock turbo? There are enough problems with the set up that you shouldn't have to start drilling on the turbo. Not only that but you cannot take the cover off your turbo (sealer holds it on) so you will have to drill the pill and let the shavings fall down into the compressor cover, not good.
Pull it away from the stock controll and solenoid and you will see that the turbo really wakes up and there is 250 RPM of additional spool time that you pick up. The stock control is great for the stock turbo, get a quality EBC or MBC and tune it with one of those. You will be much happier later on with the results and your turbo will run better as well.
 Old 03-17-2009, 10:30 PM   #9
LBV
LBV's Avatar
Posts: 700   (View Stats)
LBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond repute
Any update on what happened from oncogene1?
2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual.
LBV is offline   Reply With Quote
 Old 03-17-2009, 10:38 PM   #10
Nothing yet, I think he swapped over to a MBC to control the boost. Other then that I think they got the problem worked out. I just wish we could get some high boost numbers from the SST on a dyno. I know it has 350 WHP in the turbo.
 Old 03-19-2009, 08:46 AM   #11
oncogene1's Avatar
Actually I am still running the boost off of the factory control right now. I am going to use a bracket to hold the wastegate shut and then go ewg with the steedspeed mani. The gate is at my doorstep and the mani should ship out tomorrow I think. Once it is all on I will be finishing my tune with christian and heading to the dyno.
Little off topic but the closest awd dyno around me is a dynopack...anyone know how they read? Thanks.
The Following User Says Thank You to oncogene1 For This Useful Post:
802MS3 (03-19-2009)
 Old 03-19-2009, 09:12 AM   #12
Noice! Looking forward to your developments.
 Old 03-19-2009, 12:10 PM   #13
yoichi's Avatar
Posts: 557   (View Stats)
Dynapack is the highest reading dyno.
It measures power from the hub.
2003 E39 ///M5
yoichi is offline   Reply With Quote
Boost gauge vs. AP boost reading.. which is correct? Unoriginalusername MazdaSpeed 3/6 - Turbo Induction 13 05-23-2011 05:41 PM
fixed boost psi vs boost table settings? johnac08 MazdaSpeed 3/6 - ECU Computer Tuning 8 02-03-2009 04:05 PM
why so much boost etant333 Mazdaspeed3/6 General Discussion 21 02-02-2009 11:34 AM
Is my Boost too low?? Lagwagon
Cobb Access Port/Maps
13 10-06-2008 01:10 PM
Page generated in 0.35012 seconds with 26 queries
