 Old 04-29-2014, 07:32 PM   #1
MSMS3's Avatar
Posts: 2,826   (View Stats)
Just check the actuator action with a regulated air source. It should not move before 11 psi, and begin slowly opening as you raise pressure. Mine does not fully extend the rod until about 17-18 psi. Don't use a pressure source higher than 30 psi or you could blow the diaphragm in the actuator.
The advice above seems sound regarding actuator and EBC. You can remove the actuator without removing the entire turbo, but it is a bitch and not really necessary for testing.
If you remove the rod end from the wastegate flapper, the flapper should move freely. If it does not, that could be your problem if it is not opening enough when commanded.
Another thing to do is get some soft wire and wire the actuator rod shut in place so it can't move. Boost should hold at 11 psi.
You are correct that max rod movement is less than 1/2".
I'd be looking for a hair split on the tubing going to and from the EBC. Replacing those lines is cheap.
Only boosting 10 to 11psi???? MS6Blaze MazdaSpeed 3/6 - Turbo Induction 12 07-18-2012 02:34 PM
Boosting 4psi bwspeed MazdaSpeed 3/6 - ECU Computer Tuning 5 02-11-2012 08:37 AM
Over boosting? travis9935 MazdaSpeed 3/6 - Turbo Induction 55 01-02-2012 12:35 PM
only boosting 10 psi triple_threat MazdaSpeed 3 - Engine, Transmission & Driveline 11 08-11-2009 09:08 AM
Brake boosting? Sloane Mazdaspeed3/6 General Discussion 14 12-24-2008 01:13 PM
Page generated in 0.22941 seconds with 22 queries
