  • 1 Post By
 Old 11-12-2018, 05:37 PM   #1
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
You will sink your vacuum at idle, and pull all sorts of oil into the IM if you put in a check valve that flows too freely.
 Old 11-14-2018, 12:19 PM   #2
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
Thanks for the response man! I've got the OCC in place, so that would keep oil out of the IM. The check valve would be the one that Damond Motorsports provided with the OCC. So definitely less restrictive than the PCV valve.
I'm wondering if having the PCV valve out of the equation will pull a stronger vacuum on the crankcase during decel and throttle lift off to prevent oil from being pulled past the turbo seal when back pressure in the downpipe drops.
Do u have experience with this?
I'm planning on measuring crankcase pressure by hooking up my AEM digital boost gauge to a modified oil filler cap to see what difference a setup like this would make with vacuum on the crankcase.
New Product Release!! 2006-2013 MS3/6 & CX7 EGR Valve Delete Kit! JBR JAMES BARONE RACING 39 02-16-2017 08:07 AM
valve guides? valve seal? valve stem? WHAT IS BLOWN?!?!?! eroler1 Gen2 MS3 General Discussion 32 12-29-2016 03:29 AM
EGR delete/VCTS delete codes Speedie6 Mazdaspeed3/6 General Discussion 7 07-24-2009 10:22 AM
Cat delete vs resonator delete taf0422 MazdaSpeed 3 - Engine, Transmission & Driveline 7 04-08-2009 05:57 PM
Page generated in 0.24118 seconds with 22 queries
