 Old 02-26-2009, 09:16 AM   #1
prspect's Avatar
Posts: 22   (View Stats)
prspect will become famous soon enoughprspect will become famous soon enough
Default PG Reworked Turbo Installation
Is it possible to install a PG Reworked Turbo without removing stock manifold?
prspect is offline   Reply With Quote
 Old 02-26-2009, 09:21 AM   #2
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
i really don't think so, i dont know how you plan on getting the turbo past the manifold. although i could be wrong.
 Old 02-26-2009, 10:01 AM   #3
dallasms3gt's Avatar
Posts: 665   (View Stats)
dallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond reputedallasms3gt has a reputation beyond repute
I dont have the exact answer either, but if it's not possible, you might as well go ahead and install an aftermarket Mani while you are installing reworked Turbo... Kill 2 birds..
CPE-SRI - HKS-SSQV - CPE-MM - TWM SB - Cobb AP
Cobb FMIC - Cobb CBE - DP
18x8 +48 HP Design 235/40/18 BFG Riken, H&R Springs
dallasms3gt is offline   Reply With Quote
 Old 02-26-2009, 10:04 AM   #4
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
yes it is possible, i didn't remove my manifold installing a SST - take it out from the bottom (if you have all that stock DP shit out)
 Old 02-26-2009, 05:30 PM   #5
LBV
LBV's Avatar
Posts: 700   (View Stats)
LBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond reputeLBV has a reputation beyond repute
OT, but how are you liking the SST?
2007 White MazdaSpeed 6 for sale ... new wheels = G8 GXP manual.
LBV is offline   Reply With Quote
 Old 02-26-2009, 05:53 PM   #6
Docnox's Avatar
Posts: 1,435   (View Stats)
Docnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the world
Groans: 35
I'm curious too.
Docnox is offline   Reply With Quote
 Old 02-26-2009, 01:20 PM   #7
I<3Groceries's Avatar
Posts: 1,990   (View Stats)
Yeah! Might as well slap an aftermarket mani on there. That's my plan.
 Old 02-26-2009, 06:54 PM   #8
martyxattack's Avatar
Posts: 924   (View Stats)
martyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the worldmartyxattack is the leader of the world
Groaned at 37 Times in 27 Posts
know your roll
martyxattack is offline   Reply With Quote
 Old 02-27-2009, 05:00 PM   #9
SharkDiver's Avatar
Posts: 969   (View Stats)
SharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the world
Yes but you have to remove the DP instead.I would get a new DP since you will have it off already.It looked easier to remove the Dp then it did the mani but either way to do it I would suggest getting a upgraded mani or dp to save you alot of time in the future.
Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more
http://videos.streetfire.net/profile/SharkDiver.htm
http://www.youtube.com/user/sharkdiverjohn
SharkDiver is offline   Reply With Quote
 Old 02-27-2009, 05:29 PM   #10
What AP map are you running with the reworked K04? Have you got a PTP, MPI, or PG K04?
 Old 02-27-2009, 07:36 PM   #11
SharkDiver's Avatar
I have the PG.I running stage 2 V103j 93 FMIC beta map.It runs pretty good with this map.I dont get much knock retard and my afrs are safe in the 11s.I do spike to about 21-23psi sometimes but it drops to about 18-20 and holds pretty good there.I was told I will be fine with the reworked turbo and running the default boost psi settings in the ots maps.I kinda wish I was running at about 18-19psi tho just to be safe.
The Following User Says Thank You to SharkDiver For This Useful Post:
wassup61 (03-02-2009)
 Old 03-02-2009, 04:56 AM   #12
wassup61's Avatar
Posts: 1,232   (View Stats)
wassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the world
PG K04 CAN be installed without pulling the manifold. However, would I do that? Not if i didn't have to, talk about a PITA.
-Jeff at PG
All wagon, No traction
wassup61 is offline   Reply With Quote
103 maps with PG Reworked Turbo subparpunk03
Cobb Access Port/Maps
11 11-13-2008 10:28 PM
PTP reworked turbo 330 and 342 tq andre0121 MazdaSpeed 3/6 - Turbo Induction 63 10-15-2008 04:59 PM
K04 Reworked Turbo Owners, Please Chime In... AutoXRacer MazdaSpeed 3/6 - Turbo Induction 73 09-04-2008 06:21 PM
reworked turbo - to be safe i should... xcoldricex MazdaSpeed 3/6 - ECU Computer Tuning 3 08-23-2008 09:17 PM
Reworked turbo... subparpunk03 Mazdaspeed3/6 General Discussion 3 07-17-2008 01:26 PM
Page generated in 0.33271 seconds with 29 queries
