 Old 03-09-2009, 04:51 PM   #1
Tcman2006's Avatar
Posts: 165   (View Stats)
Tcman2006 is a name known to allTcman2006 is a name known to allTcman2006 is a name known to allTcman2006 is a name known to allTcman2006 is a name known to allTcman2006 is a name known to all
Default Please HELP!!!!!
ok so this has been going on for a while now ever since i installed my cobb sri. it only happens in 5 and sixth and today i noticed that when it does it occasionly there is a kr reading of 4.9 but it didnt happen during this log. anyone have any ideas of what the problem might be. the car only has 3000 miles on it. this log is sixth gear only on the enter state going from about 70 to 85 mph each time.The boost spikes like crazy 3.bmp
Tcman2006 is offline   Reply With Quote
 Old 03-09-2009, 06:48 PM   #2
bnoon's Avatar
Posts: 1,770   (View Stats)
Don't floor it or get into boost in those gears at that speed or you may blow! It's called loading up the engine and you need to stop doing it. There's nothing else to be done...
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
 Old 03-17-2009, 08:56 PM   #3
ptperformance's Avatar
Posts: 4,123   (View Stats)
Agreed, keep it above 3000 RPM if your going to go WOT.
I don't know why it would happen after the install but, give the PCM a while to learn and it might go away.
The Following User Says Thank You to ptperformance For This Useful Post:
glocK23 (03-17-2009)
 Old 03-17-2009, 10:09 PM   #4
SgtP's Avatar
Posts: 2,130   (View Stats)
SgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the world
Groans: 106
loading the engine = bad. dont do it. also scale your logs a little better.
13.2@111
CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is offline   Reply With Quote
Page generated in 0.25307 seconds with 23 queries
