  • 1 Post By Raider
 Old 08-22-2013, 11:24 PM   #1
Invisible_2.3's Avatar
Posts: 68   (View Stats)
Invisible_2.3 has a spectacular aura aboutInvisible_2.3 has a spectacular aura about
Groaned at 23 Times in 9 Posts
Default Problems w/ cpe xcel cai install
Installed it on my friends stock ms3...bought it used w no instructions...I've tried searching w no answers...where do you mount the support bracket too? And why is it hitting the shifter weight we had to turn the shifter weight so that he could get into 1st-6th? We also installed this onto the stock turbo inlet pipe also if that helps
Invisible_2.3 is offline   Reply With Quote
 Old 08-22-2013, 11:26 PM   #2
theurgy's Avatar
Posts: 2,580   (View Stats)
You mount it to a spot on the outside frame rail.
 Old 08-22-2013, 11:38 PM   #3
That's what i thought what do I have to remove to get it to fit there?
 Old 08-23-2013, 12:25 AM   #4
theurgy's Avatar
You have to take out the complete resonator, the shield piece as well.
 Old 08-23-2013, 06:01 AM   #5
And if the shifter weight is hitting it, that was common on early ones. I had the 2nd one made, so I know how to fix it. Remove the forward shifter weight bolt loosen the rear. Then rotate it clockwise until it wont hit, tighten rear. Now, you can also make it easier to shift by cutting off the extra chunk of weight that hits. I have one like that and it is smooth. The other, is to just cough up $25 for one from most vendors.
Did the intake come with the vibramount for between the intake and the frame? If not, no need to spend $35 with CPE,
$2! GRAINGER APPROVED VENDOR Vibration Isolator, 50 Lb Max, M6 x 1 - Cylindrical Vibration Isolators - 2NPA2|2NPA2 - Grainger Industrial Supply
Just go grab a nylon locknut and done.
HawkeyeGeoff likes this.
theurgy (08-23-2013)
 Old 08-23-2013, 11:30 AM   #6
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
Silver 2007 Speed3 GT
Raider (08-23-2013)
 Old 08-23-2013, 11:32 AM   #7
Looks just like me!
 Old 08-23-2013, 11:37 AM   #8
Looks just like me!
lol Scruffy=Raider?!
"No wash bucket, this is wrong. Go before I change my mind!"
 Old 08-24-2013, 09:29 AM   #9
jm211's Avatar
Posts: 943   (View Stats)
Cant the weight just be removed? I havent had mine on for 6 months.
 Old 08-24-2013, 09:33 AM   #10
theurgy's Avatar
It just doesn't feel right without it. And yeah, do what Raider said, reverse the weight so it curves out wards and then save up and buy a new weight from Cobb, TWM or the other guys we won't name.
Some even just cut the stock weight.
Problems after turbo install keke MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 05-03-2012 09:49 PM
problems with ots map after dp install Zbrit00x 2010 MS3 - ECU Computer Tuning 17 11-03-2011 01:14 PM
cp-e Xcel Nano and Forge BPV combo install skubidoobie Mazdaspeed Forums User Reviews 27 09-16-2009 08:43 PM
CP-e Xcel Nano Install Problems - got tips? Hank3 MazdaSpeed 3 - Engine, Transmission & Driveline 17 06-25-2009 10:14 AM
Cp-e Xcel Nano install and review w/ pics n vids copperkid Custom Performance Engineering (cp-e.com) 19 11-07-2008 02:53 PM
Page generated in 0.30206 seconds with 24 queries
