 Old 08-04-2013, 10:58 AM   #1
Cdez's Avatar
Posts: 120   (View Stats)
Cdez has a reputation beyond reputeCdez has a reputation beyond reputeCdez has a reputation beyond reputeCdez has a reputation beyond reputeCdez has a reputation beyond reputeCdez has a reputation beyond reputeCdez has a reputation beyond reputeCdez has a reputation beyond reputeCdez has a reputation beyond reputeCdez has a reputation beyond reputeCdez has a reputation beyond repute
Default Quick bpv question
I'm aware the stock bpv is plenty fine for my set up.. On that note for safe measure and +2rice power I got a bpv. Installed it.. Weird clicking noise when I tap the gas. Sounds like a little knock like a broken rmm or something. The sound is coming directly from the turboxs bpv. I monitored knock and see nothing but still took it off cause of the little tick it makes. I took it apart and the inside looks fine the gaskets and spring are all straight. Any ideas.. Do I need an updated tune for just the bpv?
Thanks
Cobb AP, 3 Gal E85 FreekTune, Cobb SF, Cobb TIH, Autotech FP internals, CorkSport Catback, UR Resonated TP, JBR 88Duro RMM, TWM Short Throw Shifter, TWM Solid Shifter Bushes, UR Tower Bar?, Moog Endlinks, SURE Swaybar bushes, itv 22's, Forge v1 BPV, Genpu transmission, Genpu motor with 20k miles, Rally Armour MF and stickers!
Cdez is offline   Reply With Quote
The Following User Says NO Thank You to Cdez For This Un-useful Post:
mazdafreak (08-04-2013)
 Old 08-04-2013, 12:22 PM   #2
rolanblack's Avatar
Posts: 2,110   (View Stats)
take it apart again and clean it out, regrease it.
The Following User Says Thank You to rolanblack For This Useful Post:
Cdez (08-04-2013)
 Old 08-04-2013, 02:48 PM   #3
Cdez's Avatar
Cleaned and regreased and sounds fine now.
 Old 08-04-2013, 03:35 PM   #4
Manny's Avatar
Posts: 1,185   (View Stats)
Groans: 320
you might need a re-tune, do you AP bro?
The Following User Says Thank You to Manny For This Useful Post:
Cdez (08-08-2013)
The Following User Says NO Thank You to Manny For This Un-useful Post:
secondchance (08-06-2013)
 Old 08-04-2013, 03:38 PM   #5
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
no retune needed if it's in full recirc
Blue Pu.
 Old 08-05-2013, 09:13 PM   #6
rolanblack's Avatar
Really....did he just say that?
jm211 (08-06-2013)
 Old 08-08-2013, 10:05 AM   #7
Cdez's Avatar
I ended up having to take it out. Not only was it making the click noise but on deceleration the car would make a weird whine noise and my CEL came on.
I do AP.. But @freaktune.
Put the stock bpv back on and no more CEL. I know the thing is not broken cause I took it completly apart and the peices all looked fine. I think its either the tune or because my LTFT's are jumping all over the place. But this still does not explain the noises.
 Old 08-08-2013, 07:05 PM   #8
rolanblack's Avatar
Maybe a vac leak? Any locals around you would consider swapping out stock bpv to see if its just that. Have them trst yours on their car
@atvfreek;
Cdez (08-10-2013)
Quick AP question Mazdaspeed666 MazdaSpeed 3/6 - ECU Computer Tuning 10 06-28-2012 06:45 PM
Quick question on a quick potential sale... HeliBif MazdaSpeed 3/6 - Wheels & Tires 0 05-10-2012 02:48 PM
Quick Oil Question k0m MazdaSpeed 6 - Engine, Transmission & Driveline 8 07-13-2010 02:34 PM
Quick question Engi-Freakin-Neer Mazdaspeed3/6 General Discussion 1 06-05-2010 09:17 PM
Quick Question Jake_MS3 MazdaSpeed 3 - How-To's 4 01-13-2010 07:38 PM
Page generated in 0.29135 seconds with 23 queries
