 Old 02-26-2017, 12:01 PM   #1
johnathan_723's Avatar
Posts: 39   (View Stats)
johnathan_723 will become famous soon enough
Default Quick question for you guys
Previous owner installed this real shitty cold air intake. Witch is fine but I live in Canada and road debris gets all caught in it. So I was wondering if I can just take a hacksaw to it and make my own short ram intake out of it? Anyone see any problems with this idea? Sensor is just a bit close to where new air filter will be.
Sent from my SM-G930W8 using Tapatalk
johnathan_723 is offline   Reply With Quote
 Old 02-26-2017, 06:24 PM   #2
sheston's Avatar
Posts: 1,847   (View Stats)
Should be fine as long as you can get the air straightener in there somewhere. Without it people have had MAF cal problems
Varomnia (02-26-2017)
 Old 02-26-2017, 07:04 PM   #3
Well I cut it off
 Old 02-27-2017, 07:06 AM   #4
MSMS3's Avatar
Posts: 2,826   (View Stats)
Did it have an internal air straightener? If so, that needs to go in ahead of the MAF or it will not read air mass correctly and will not send accurate voltage to the ECU for your air to fuel ratio.
 Old 02-27-2017, 07:59 AM   #5
That sensor is behind the filter everything is the same except a shorter pipe
 Old 03-02-2017, 07:07 PM   #6
MSMS3's Avatar
I know where the MAF sensor is. I'm asking about a vane like plastic insert that goes in the pipe ahead of the MAF sensor to guide the airflow across the sensor.
It probably should have one.
Quick question on a quick potential sale... HeliBif MazdaSpeed 3/6 - Wheels & Tires 0 05-10-2012 02:48 PM
Quick question for COBB AP guys redmnsterut Mazdaspeed3/6 General Discussion 5 09-16-2011 09:26 AM
Page generated in 0.26497 seconds with 23 queries
