  • 1 Post By secondchance
 Old 08-09-2012, 08:45 PM   #1
v8killer's Avatar
Posts: 203   (View Stats)
v8killer is the leader of the worldv8killer is the leader of the worldv8killer is the leader of the worldv8killer is the leader of the worldv8killer is the leader of the worldv8killer is the leader of the worldv8killer is the leader of the worldv8killer is the leader of the worldv8killer is the leader of the worldv8killer is the leader of the worldv8killer is the leader of the world
Groaned at 5 Times in 2 Posts
Default 'Relentless Performance' FMIC
Has anyone bought one of these? I know you get what you pay for... I'm mostly wondering about piping fitment. Although any experience with this or advice is appreciated. I'm only planning on using it for the stock turbo. I'd like to pick up a reasonably priced FMIC asap that isnt a complete custom job.
FMIC Turbo Intercooler Kit MazdaSpeed 3 DISI | eBay
363whp & 420trq (DynoJet)
384whp (Dyno Dynamics)
K04 + corn + nitrous + LEX = a happy v8killer
v8killer is offline   Reply With Quote
 Old 08-09-2012, 10:09 PM   #2
fooqr's Avatar
Posts: 559   (View Stats)
fooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the worldfooqr is the leader of the world
That will fit exactly the same as a cxracing FMIC.
08 MS3 GT (SSM). JBR WP intake, CS boost tubes, Forge v2 BPV, JBR TB/IM TIG, JBR TB coolant bypass, JBR EGR block-off, 3-bar MAP, PTP pill, bnoon bolt, SM OCC (MD kit) w/ Kat's heater, UR DP (ceramic cat), UR resonated TP/CBE, JBR SSP, SU shift bushings, JBR trilogy mounts (CRMO 88 RMM, 70 PMM/TMM), Koni yellows, JBR RSB, 2nd Fiamm, Stoptech SS lines, Hawk HPS, spin-on CX-9 oil filter, Fumoto valve, PP 5W-30, XT-M5-QS, tints, clear bra, Continental DWS, ITV22, DashHawk, AP, AT internals
There are no stupid questions, but there are stupid people and some of them ask questions.
- A. Funicello
fooqr is offline   Reply With Quote
 Old 08-10-2012, 11:29 AM   #3
v8killer's Avatar
I heard that the cx core isnt as good as the treadstone, etc but for running the k04 with bolt ons and a tune Im thinking its fine
 Old 08-10-2012, 01:56 PM   #4
fooqr's Avatar
Fine for what? What are you trying to achieve? (You're right, the cxracing IC core won't cause your car to blow up. But are you seeking performance gains, lower BATs, higher boost, less lag, what?)
You'll find this opinion in other threads, but if you're running stock turbo an FMIC is probably overkill and will only introduce turbo lag. Since the main advantage of the K04 is its quick spool, the combination of K04+FMIC kind of gets you the worst of both worlds.
Since bigger turbos spool later anyway, losing turbo lag with an FMIC is considered an acceptable compromise. It's not like you're going to get lots of low-RPM boost on a G35.
You're better off running an upgraded TMIC to reduce the airflow restriction of the stock IC. If, after doing this you find you still need lower BATs, spray meth or run E85.
- A. Funicello
The Following 2 Users Say Thank You to fooqr For This Useful Post:
greenespeed (08-10-2012), Neverlift (08-11-2012)
 Old 08-10-2012, 02:36 PM   #5
Off topic here but that test car they show in the ebay listing is a weird color of purple.
-Derrick
 Old 08-10-2012, 03:17 PM   #6
Koke382's Avatar
Posts: 4,361   (View Stats)
Im thinking of getting this too to be honest. I know alot of people running the CX racing and they always compare it to this kit, its price is more affordable and down the road i can just upgrade the core if i do decide to go BT.
2007 Mazdaspeed 3 GT
18x8.75 XXR 527 225/40/18r
New fucken miata build:
1993 Red Na6
Some suspension modz yo
Coilovers// Other shit
 Old 08-11-2012, 12:54 PM   #7
secondchance's Avatar
Posts: 421   (View Stats)
secondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the worldsecondchance is the leader of the world
Groaned at 114 Times in 37 Posts
that core is tiny, outside of esthetics is a waste of money imo. Get a treadstone IC and the protege garage piping kit. Will yield better performance and cooling.
v8killer likes this.
2009 Subaru WRX 265 Sedan || Cobb AP || Cobb SF intake w/ air box || Process West TMIC || Tein Springs || Grimspeed 3 port || Forge BPV || Invidia Catback || UR Downpipe || Kartboy short throw w/ cobb knob and bushings || Cobb Heatshield || DW65c fuel pump || NGK 1 steps
In Garage for Spring || HSD Coilovers || Eibach f+r sway bars || Whiteline positraction bushing kit || Kartboy Endlinks || Whitelink endlink reinforcements || GTSpec front + rear sway bars || Stoptech front and rear rotors,pads,lines
Sold
2007 MS3 295 whp 350 Torque
2010 Evo X 440AWHP 11.7 @ 113
2009 Ralliart w/ xswap 320AWHP (first in canadia to break 300whp in gen2 RA) 12.4@ 108
2004 srt-4 s2
2006 ms6
2005 srt-4 s3 w/toys 12.16 @ 117
secondchance is offline   Reply With Quote
The Following User Says Thank You to secondchance For This Useful Post:
Dmurray06 (08-11-2012)
 Old 08-11-2012, 04:18 PM   #8
v8killer's Avatar
Ok. I will prob go with the protege piping kit and a treadstone intercooler...i'll just have to pick up a bpv unless the stock one is good enough for 18 psi-ish. And buy good enough I meant wont get heat soaked, isnt too big, low pressure drop, and good flow. I dont mind a little more lag for a cooler air charge. def worth a the trade off to me. Thanks guys.
 Old 08-11-2012, 04:23 PM   #9
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Get an upgraded top mount if you're staying k04.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 08-12-2012, 09:18 PM   #10
v8killer's Avatar
Well I am for atleast 6-9 months. Got a ride in a guys gt3076 pwr'd speed3 this weekend in phx and Its only a matter of time before I end up doing the same. Damn that thing pulled hard. Thats why I think I'll just do the front mount now... or is that a bad idea... decisions, decisions... I suppose I could get a used bigger top mount and then when I go bigger turbo down the road just sell of the top mount. hmm
 Old 08-13-2012, 07:16 PM   #11
Tokay444's Avatar
Groans: 793
In that case just get the $6500+ efr full kit and hope its as fast as the gt30.
Demodded.
The Seals
 Old 08-13-2012, 10:00 PM   #12
v8killer's Avatar
yeah i'll get right on that... no, i'll stick with the stocker for a bit. Im planning on building a .50 Beowulf after I get some parts thrown on and a tune so im not looking at dumping all my cash into it... yet
 Old 08-15-2012, 03:51 PM   #13
v8killer's Avatar
So after hearing what people had to say on here and talking to others I went with the CP-E tmic. Down the road when I go with a bigger turbo I will go with a FMIC. But for now I hear stay with a top mount.
Relentless FMIC kit...? NinjaT1985 2010 MS3 - Turbo Induction 9 04-11-2012 09:34 AM
Chicago 2011: Hirsch Performance Saab 9-3 adds some Swedish style, performance Haltech Automotive News 0 02-10-2011 08:40 AM
Saab officially teams up with Hirsch Performance for high-performance parts Haltech Automotive News 0 01-12-2011 04:50 PM
Video: Dodge Neon burnout ends in relentless fail Haltech Automotive News 0 02-14-2010 02:40 PM
Cobb FMIC vs Exhaust Depot FMIC mrjoshyman MazdaSpeed 3/6 - Turbo Induction 44 04-20-2009 10:30 AM
Page generated in 0.32067 seconds with 25 queries
