  • 1 Post By SpeedRebirth
 Old 08-01-2013, 12:36 PM   #1
spdtrux's Avatar
Posts: 481   (View Stats)
spdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the worldspdtrux is the leader of the world
Groaned at 9 Times in 6 Posts
Default restricor bolt on egay
Turbo Banjo Bolt Mazda Speed 3 6 w Restrictor to Prevent Exhaust Smoke | eBay
anyone used it?
try'd a search came up with nada.
I just got it free w/ egay bucks or i woulda went the JBR route.
99 JEEP WRANGLER SPORT
4 liter- 5 speed- RCD BILTEIN 4" lift -32X12.5" tires-Xtreme 15"x12" wheels-JET Stage 2 ECU- K&N Intake-TB Spacer -Banks Power Monster Header back exhaust-Hurst short throw shifter-Fender Flares w/ clear corners -brush guard -Fog kit-8500lbs winch -tail light guards-Sound bar
2007 Sunlight GT Crash Smash Boom
ZOOM ZOOM = HTP Full Metal 3" // CS SRI FMIC // Cobb AP // Autotechs // CS TP & CBE // Stock Block // Stock Turbo //
Ralco RZ Shifter // JBR 88 RMM + 80 PMM + Spherical Knob + SSP + WEIGHT + Bushings // Saiko Michi OCC // Cobb Springs // KYB FRONT & BACK // Tri-point rear links // Redline hood shocks // Gen2 VC //
RICE = Rally Armor // 20% Tint All Around // Weather Tech // JDM Goodie Visors // CF Eyelids // Red/Black CF Dash Kit // Bumper Covers // Extra Sub Mod //Stuby Antenna//Red&Blue Interior L.E.D. // 50w 10 L.E.D. Cree Reverse lights
spdtrux is offline   Reply With Quote
 Old 08-01-2013, 12:48 PM   #2
alphasaur's Avatar
Posts: 2,847   (View Stats)
Groans: 235
Don't see why it wouldn't work unless the size of the hole is off....
it's a bolt lol...
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/lol nator.
 Old 08-01-2013, 01:27 PM   #3
MSFer87's Avatar
Posts: 1,162   (View Stats)
Groans: 83
Yeah plus the company is pretty legit even for ebay standards you can build a pretty disgusting bolt on WRX with one of their turbos. Someone on here has one. You should be the first guinea pig and let us know how they work. As long as the thread pitch is right how can there be an issue.
 Old 08-01-2013, 01:35 PM   #4
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
since when does jbr make restrictor bolts?
 Old 08-01-2013, 01:37 PM   #5
If you read in the bnoon bolt thread, the bolt is not drilled to the same specs he recommended.
btstarcher (08-01-2013)
 Old 08-01-2013, 01:37 PM   #6
timjs's Avatar
Posts: 908   (View Stats)
timjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the world
I've had that bolt since ~60k and I have 96k now.
It fixed my smoke, and it was bad.
Edit:ninja'd by @Raider; but it doesn't matter because he has no first hand experience :p
'06 Mazdaspeed 6
timjs is offline   Reply With Quote
The Following User Says Thank You to timjs For This Useful Post:
Raider (08-01-2013)
 Old 08-01-2013, 01:38 PM   #7
BigO's Avatar
Posts: 614   (View Stats)
BigO is the leader of the worldBigO is the leader of the worldBigO is the leader of the worldBigO is the leader of the worldBigO is the leader of the worldBigO is the leader of the worldBigO is the leader of the worldBigO is the leader of the worldBigO is the leader of the worldBigO is the leader of the worldBigO is the leader of the world
I just ordered one today, I'll post up after I do my DP install. If it still matters by then. lol
Tapatapped with my fingers.
JBR Air Dam JBR Short Shifter JBR Solid Shifter Bushings JBR RMM TRZ TMM Damond PMM Damond P/S Cooler Damond Vented OCC JBR OCC JBR .250 Competition RSB 3SpeedsGarage PnP intake Manifold Cobb APV3 H&R Sport Springs Treadstone TR8 FMIC HTP 3.5 inch intake Snow Performance Progressive Controller and Safeinjection Module TWM Big Type-R Weighted Shift Knob Wiseco Forged Pistons XS Power Tubular Manifold UR DP UR TP Autotech HPFP Internals NGK 6510's Koni Yellows Stoptech SS Braided Lines and street pads GFB TMS Respons BOV Borla Cat-Back BNR S4V2 Eagle H-Beams ACT 6 puck clutch and flywheel
BigO is offline   Reply With Quote
 Old 08-01-2013, 01:51 PM   #8
spdtrux's Avatar
Under the @bnoon thread there was a comment that he did.
I didn't see one onhis site today when I ordered stuff.
Kinda looking for a ..yea I got one, works fine... peice of mindkinda thing.
Ill to a write up when it comes in.
The Following User Says Thank You to spdtrux For This Useful Post:
speed3 britz (08-01-2013)
 Old 08-01-2013, 02:49 PM   #9
spdtrux's Avatar
Yea.. when my tih is on it smokes withind 1minn at idle in the first 5 miles. After that it won't smoke at idle till 3or so mins. So I fuger its time to try oit the RB.
Right now my set up is cp-e sri unkown tih, corksport cbe and fmic kmd. Ptp pcv reducer.idle set @ 950rpm
Dp and tp are next months mods
 Old 08-01-2013, 04:09 PM   #10
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
If you guys want i can post up a complete how to on the bolt install if the pictures in the bnoon thread isnt enough. Ive already got the pictures uploaded on a site because i make a swedish how to
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 08-01-2013, 04:53 PM   #11
LilGator's Avatar
Posts: 136   (View Stats)
LilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond repute
Groaned at 6 Times in 3 Posts
All these bolts do is restrict oil flow to the turbo which I certainly can't see helping your turbo's lifespan. It's just a smoke band-aid, no?
2007 Speed6 GT - LPM
RMM 88 | JBR SSP, SSB & Heavy Knob | NGK Iridiums | Cobb AP
SURE Full3 3" Aeros | M2 Downpipe | Autotech Internals | Forge BPV
MagnaFlow CBE | SURE Dreadnaught / Juggernaught | Whiteline RSB | H&R Sports
E85 Stratified
LilGator is offline   Reply With Quote
The Following User Says Thank You to LilGator For This Useful Post:
xI Leveler Ix (08-02-2013)
 Old 08-01-2013, 05:37 PM   #12
Groans: 33
At idle there is too much oil pressure inside the turbo so the seals cant handle that and oil starts to seep past and ends up in the exhaust = smoke. One of the fixes is to decrease the amount of oil going in = less pressure. Band aid, maby. But its a lot better than getting oil onto your cats. They may clog up and increase the pressure on the exhaust side... worst case scenario is engine damage
memin likes this.
Mazdaspeed6 -06
290 AWHP / K04
 Old 08-01-2013, 06:15 PM   #13
timjs's Avatar
The turbo CHRA should never have pressure in it.
Someone correct me if I'm wrong.
'06 Mazdaspeed 6
 Old 08-01-2013, 06:23 PM   #14
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
The bolt is like $13 and it appears to be a regular banjo bolt. The hole is significantly smaller than the passage on a BNOON bolt. If I remember, I will try and take a picture of them side by side on friday.
Pickles Tune in progress
 Old 08-01-2013, 06:34 PM   #15
LilGator's Avatar
And if you don't have cats?
E85 Stratified
 Old 08-01-2013, 07:13 PM   #16
spdtrux's Avatar
If the hole is too small that it may starve the turbo then i can just drill it out to the correct size of the bnoon bolt.
Probly do that(bore to bnoon size) when i get it, before install. Just to be safe.
Last edited by spdtrux; 08-01-2013 at 07:13 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-01-2013, 08:31 PM   #17
spdtrux's Avatar
Half the pics in the bnoon thread don't load for me....so any addition pics would be a help
 Old 08-01-2013, 08:51 PM   #18
himurax13's Avatar
Groans: 255
Then you will still lose oil, you just won't smoke as much.
Sent via blown passenger side speakers.
 Old 08-01-2013, 09:11 PM   #19
willix231's Avatar
Posts: 1,315   (View Stats)
willix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond reputewillix231 has a reputation beyond repute
Himurax. Has see my bolt.I bought one of these.the restrictor is exactly the same as bnoon bolt.onot difference is this bolt has the restrictor on the side. Side by side with the bnoon this bolt looks like something made in a factory. The holes don't even look like home drilled type.it's a true banjo bolt.if anyone needs pics let me know and I'll use my dslr
Sent from my LG-E970 using Tapatalk 2
Corksport Sri+Tip, Cobb FMIC, Turbosmart BPV, NGK 1 step colder Plugs,Cobb accessport v2,Cobb RMM,cobb shift weight, Megan racing test pipe, Racing beat catback exhaust, Labonte wmi controller with cooling mist pump,stratified 91 octane & e85 ots tunes,Mazdaspeed oem coilovers,CS camber plates,whiteline ALK, whiteline bumpsteer kit, whiteline poly bushings, JBR rear sway bar, SPC rear camber arms,Gtspec mid chassis Aluminum brace, Gt spec rear cross member Brace with V brace addition,Wilwood 4 pot BBk+hawk DTC 60 with DBA 4000 rotors(F),Stoptech high carbon rotor(R), stoptech street performance pads(R), Stoptech stainless steel braided brake line(FxR), Enkei Rpf1 17*8.8 +30, Aluminum hubcentric rings, Work Rs open ended lug nuts, Hankook Rs3 245/40/17
willix231 is offline   Reply With Quote
 Old 08-02-2013, 03:40 PM   #20
LilGator's Avatar
I smoke plenty without cats. When I had cats, I didn't smoke at all...
E85 Stratified
 Old 08-02-2013, 04:01 PM   #21
himurax13's Avatar
Groans: 255
Then your smoke probably mighnt not be coming from leaky turbo exhaust seals. Do you have any blowby pre turbo?
 Old 08-07-2013, 03:17 PM   #22
seshomaru7's Avatar
Posts: 182   (View Stats)
seshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to all
So any more feedback on this bolt?
Need a way to mount your Devil's Own methanol kit? Find my F/S thread for a custom made mount kit with all hardware included!
seshomaru7 is offline   Reply With Quote
 Old 08-07-2013, 03:40 PM   #23
bluemonstr's Avatar
Posts: 45   (View Stats)
bluemonstr has much to be proud ofbluemonstr has much to be proud ofbluemonstr has much to be proud ofbluemonstr has much to be proud ofbluemonstr has much to be proud ofbluemonstr has much to be proud ofbluemonstr has much to be proud ofbluemonstr has much to be proud ofbluemonstr has much to be proud of
I have this bolt and I too did a LOT of research before buying this exact same bolt about 4 months ago. Since then I DID have to replace my turbo anyways but I am still using this bolt today.
As far as the bolt size goes, Bnoon mentions in his thread about the size: "I found out after much begging and pleading that .060" is recommended minimum size per 2 rebuild shops that specialize in rebuilt KKK turbos." The ebay bolt when converted is .059" - close enough for me.
Someone in the thread mentioned what is the worst that can happen from the smoking turbo, aside from losing a quart of oil every couple hundred miles (luckily I was checking like a hawk and kept on top of that while I tried to figure a solution, well the car DEMANDED my attention with this.... My seals really BLEW.
I came out to my car with a nice little oil puddle under my turbo...my seals had blown so completely I didn't have a choice but to replace the turbo. Towed the car to the dealer and had it replaced. Sucked. But the bolt is still in use now - who knows maybe it will help prevent any future issues. I have no complaints with the ebay bolt mentioned in this thread. Working great as far as I can tell and I will be rebuilding my old k04 soon.
bluemonstr is offline   Reply With Quote
 Old 08-07-2013, 03:47 PM   #24
himurax13's Avatar
Groans: 255
Bnoon and fleabay bolt
Stock and fleabay bolt
 Old 08-07-2013, 04:02 PM   #25
LilGator's Avatar
@Lex, what are your thoughts on this bolt and smoking turbos over the long run?
E85 Stratified
 Old 08-07-2013, 04:14 PM   #26
seshomaru7's Avatar
There is a new bolt out by Damond Motorsports if anyone is interested.
 Old 08-07-2013, 04:38 PM   #27
spdtrux's Avatar
thanks for more info
Bolt came in yesterday
... 1.5mm = 0.0590" so no work should be needed.
Got the OK to buy me a DP&TP. So i won't be installing the bolt till they come in.
MS3 isn't my DD so i can wait.
 Old 08-07-2013, 06:33 PM   #28
Groans: 33
So i made a how to for the install, take a look: How-To: Install oil restrictor bolt (complete guide)
Mazdaspeed6 -06
290 AWHP / K04
The Following 3 Users Say Thank You to SpeedRebirth For This Useful Post:
alphasaur (08-07-2013), Raider (08-07-2013), Tedspeed6 (11-27-2013)
 Old 08-27-2013, 01:48 AM   #29
spdtrux's Avatar
update: Has been installed and no smoke and all seems good so far
 Old 10-09-2013, 01:39 PM   #30
bnoon's Avatar
Posts: 1,770   (View Stats)
10 thousandths of an inch too small as recommended by several rebuilders of these turbos FYI. If you buy an Ebay bolt, ream it out to something closer to .0600 (MINIMUM) to .0625 area. My bolts were drilled slightly larger than the minimum size and hand reamed to remove any burrs.
Good job on the writeup @speedrebirth!!!
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
BOLT ONS!! Q & A JP@edgeautosport.com EdgeAutosport.com 327 12-28-2016 05:00 AM
Will a UR dp/rp bolt up to a CS cbe? Speedin Gen2 MS3 General Discussion 7 05-28-2012 04:33 PM
stripped bolt haskms3 MazdaSpeed 3 - Engine, Transmission & Driveline 6 12-20-2010 04:23 PM
Bolt help iracer7 MazdaSpeed 3 - Engine, Transmission & Driveline 18 07-25-2009 11:26 AM
Page generated in 0.47977 seconds with 33 queries
