 Old 02-20-2009, 02:21 PM   #1
Trader's Avatar
Posts: 90   (View Stats)
Trader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to beholdTrader is a splendid one to behold
Groaned at 5 Times in 1 Post
Default Should my LTFT be this high?
My long term fuel trims are the following:
idle = 4 to 6
Part throttle = 7.0
Engine breaking = 7.8
Medium throttle & WOT = 10.2
These LTFT are after about 100 miles of driving.
My only mods right now are the MSCAI2 with straighteners.
I have checked all the typical areas for leaks. I tightened up all the intercooler piping and intake piping couplers.
The car does not seem any faster with the intake.
Trader is offline   Reply With Quote
 Old 02-20-2009, 08:12 PM   #2
shadesofgray19's Avatar
Posts: 794   (View Stats)
Those LTFT's are just fine. Ideally you want them to be zero, but aftermarket intakes tend to lean the car out a bit. This is why you are seeing fuel being added. I wouldn't worry about those numbers.
 Old 02-21-2009, 09:02 PM   #3
ZoomMS3's Avatar
Posts: 94   (View Stats)
ZoomMS3 has a spectacular aura aboutZoomMS3 has a spectacular aura about
I would be.. You LTFT should be NO higher than 5% at WOT and really shouldnt be any bit higher than 3. Good thing is that a protune will do great things to your setup and you shouldnt cause too much harm with how it is currently running.
On motor #3
Turbo #2
Now have a SSM 08 STi!!
ZoomMS3 is offline   Reply With Quote
 Old 02-20-2009, 08:49 PM   #4
frito's Avatar
Posts: 28   (View Stats)
frito will become famous soon enoughfrito will become famous soon enough
Did you drive very easy for a prolonged time?
frito is offline   Reply With Quote
 Old 02-21-2009, 09:46 AM   #5
Trader's Avatar
Yes for about 100 miles
 Old 02-21-2009, 10:00 AM   #6
MS6_Auburn_Fan's Avatar
Posts: 481   (View Stats)
Are these LTFTs positive or negative?
One other thing to check is how far the intake pipe goes into the filter. If it goes to far then it can effect everything from fuel to boost.
MS6_Auburn_Fan is offline   Reply With Quote
 Old 02-23-2009, 12:03 PM   #7
Trader's Avatar
These are positive
 Old 02-22-2009, 01:04 PM   #8
jayspeed3's Avatar
Posts: 356   (View Stats)
jayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond repute
Groans: 60
From what I have read anything between +-(6%~8%) is reasonable. Zero, or close to it, is ideal.
jayspeed3 is offline   Reply With Quote
 Old 02-23-2009, 09:48 AM   #9
bnoon's Avatar
Posts: 1,770   (View Stats)
Agreed. If they go higher than 15 (I believe that's it) you get a MIL/CEL if it's sustained for a period of time.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
 Old 02-25-2009, 04:59 AM   #10
FCmaniac's Avatar
Posts: 330   (View Stats)
FCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond reputeFCmaniac has a reputation beyond repute
I wish my LTFT's were that low
FCmaniac is offline   Reply With Quote
 Old 02-25-2009, 07:23 AM   #11
Trader's Avatar
What intake do you have? How high are yours at WOT
 Old 02-25-2009, 10:05 AM   #12
FCmaniac's Avatar
I have a Cobb SRI and Cobb inlet. It's only been a couple hundred miles since my last ECU reset so maybe they will come down a bit.
+9.0% at idle
+14.0% at WOT
 Old 02-25-2009, 10:20 AM   #13
bnoon's Avatar
+9.0% at idle
+14.0% at WOT
Wow that's high. You checked for leaks?
2002 BMW M3 - Sold!
 Old 02-25-2009, 10:21 AM   #14
Deadman's Avatar
Posts: 868   (View Stats)
mine is 17% at idle, and WOT -1% lol. i wonder if i have a leak..
Deadman is offline   Reply With Quote
 Old 02-25-2009, 10:49 AM   #15
FCmaniac's Avatar
yes I've checked for leaks. I can't find any. Everything is tight and installed correctly. I had even higher readings when I had just the Cobb SRI... I'm not the only one either.
 Old 02-26-2009, 04:42 PM   #16
FCmaniac's Avatar
Well my LTFT's came down today finally... 5.5% at idle and 7.8% at WOT. All I did was beat the crap out of the car. I've been driving like an old man for the most part for the past couple hundred since the ECU reset for inlet install. Today I decided to do a few WOT runs. What also is interesting is that I got some mild KR in the upper RPM's the first couple times and then it went away and kept feeling better. I think the ECU just gets used to how you drive and maybe doesn't react to changes as quickly as we think.
 Old 02-28-2009, 04:47 PM   #17
08.5TRS3's Avatar
Posts: 130   (View Stats)
08.5TRS3 is just really nice08.5TRS3 is just really nice08.5TRS3 is just really nice08.5TRS3 is just really nice
yea my ltft are around 15 but ive been drivin like an old lady for a few months maybe ill beat the shit outta it for a few days and see what happens lol
CP-E cai, CP-E catless dp, CP-E fuel pump, CP-E flash, Standback V2, CP-E fmic, ATP inlet, SU mm
Tuned by PTuning
CP-E and Cobb .. why cant we get along :friday: LoL
08.5TRS3 is offline   Reply With Quote
 Old 02-28-2009, 09:50 PM   #18
08.5TRS3's Avatar
i jus checked mine out and my shits all over the place lol at idle its 19.5, if i barely touch the gas like 100 200 rpms tops its 14.3 and if i do jus a hair over that like maybe 1/8 throttle its 8.6 lol why the hell is it all over the place like that within that little bit of a change of rpm
Tuned by PTuning
 Old 03-02-2009, 05:45 PM   #19
ALL-IN.
AndyMS3's Avatar
Posts: 671   (View Stats)
AndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the world
Groans: 30
Sounds like you guys gots leaks.
I would inspect all hose connections thoroughly.
AndyMS3 is offline   Reply With Quote
 Old 03-04-2009, 07:35 AM   #20
DaleNixon's Avatar
Posts: 2,079   (View Stats)
Groans: 91
The OP has fuel trims I dream about!
I might have a leak, but I've checked every hose I can find.
DaleNixon is offline   Reply With Quote
 Old 03-04-2009, 08:09 AM   #21
ThEsHoCkEr's Avatar
Posts: 457   (View Stats)
ThEsHoCkEr has a reputation beyond reputeThEsHoCkEr has a reputation beyond reputeThEsHoCkEr has a reputation beyond reputeThEsHoCkEr has a reputation beyond reputeThEsHoCkEr has a reputation beyond reputeThEsHoCkEr has a reputation beyond reputeThEsHoCkEr has a reputation beyond reputeThEsHoCkEr has a reputation beyond reputeThEsHoCkEr has a reputation beyond reputeThEsHoCkEr has a reputation beyond reputeThEsHoCkEr has a reputation beyond repute
Groans: 68
I'm getting some high LTFT also. Here is my thread
http://www.mazdaspeedforum.org/forum/foru...og-inside.html
Not sure what's causing it though.
Edit: I also have been driving like a granny the past 200 miles to let my ECU relearn this new map. I don't know if that's a factor or not though.
2010 Dodge Ram Hemi
1967 Camaro RS/SS
2008 Caliber SRT-4 (SOLD)
2008.5 MS3 GT (R.I.P.)
ThEsHoCkEr is offline   Reply With Quote
 Old 03-05-2009, 07:01 PM   #22
08.5TRS3's Avatar
i checked for leaks didnt come across anything boost leak tested it and retighten everything ... if i gotta leak it cant be much of one because my car is still runnin like a champ .. i donno this cars anal
Tuned by PTuning
 Old 03-05-2009, 07:06 PM   #23
DaleNixon's Avatar
Groans: 91
I did some WOT runs the other day for a thread on this forum and my trims have suddenly gotten a lot better. It might have to do with the warmer weather we've been getting. Or maybe I just needed to blow the carbon out of this mother fucker
 Old 03-05-2009, 08:45 PM   #24
frito's Avatar
That is good to hear.
 Old 03-09-2009, 08:05 AM   #25
DaleNixon's Avatar
Groans: 91
Update. My trims are staring to move to relatively sane levels! It's great. I recently installed an ETS 3.25" TMIC, Denso ITV22 step colder plugs, and added two shims to the blue spring on my Forge valve.
I did some WOT logs (starting in 4th gear at 3000rpm) to show someone in another thread, and I noticed my LTFT's starting looking a lot better!
At this point I'm idling no higher than +3.9, Cruise is around +3.1, Moderate gas puts it around +5.8, and hard throttle/WOT puts it around +11 to +13.
These trims aren't perfect, but they're a hell of a lot better than what I had. I'm not sure if my recent mods helped or just the warmer weather I've been driving in, but I'm one happy camper right now! My knock retard warning on the DH has been missing in action as well! (knocks on wood)
LTFT: What can it tell you? badams118 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 03-17-2009 10:06 AM
LTFT going back to 0 at WOT aaronc7
Cobb Access Port/Maps
93 02-16-2009 09:12 PM
Standback, LTFT & CEL badams118 MazdaSpeed 3/6 - ECU Computer Tuning 13 01-05-2009 10:58 AM
Is my LTFT okay? RMCAT MazdaSpeed 3/6 - ECU Computer Tuning 3 09-10-2008 08:40 AM
Page generated in 0.44363 seconds with 32 queries
