 Old 02-05-2015, 12:11 PM   #1
meicalnissyen's Avatar
Posts: 1,158   (View Stats)
Default Shutter valve retaining screws
Does anyone know the dia and pitch??
I am electing to replace them after porting, and they are sacrified when removed
to get the head and material I want, I will proly have to order online, and I have not removed them yet, otherwise I'd just measure myself.
Thanks
 Old 02-12-2015, 10:50 AM   #2
09TrueRedGTX's Avatar
Posts: 127   (View Stats)
09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute09TrueRedGTX has a reputation beyond repute
I'm confused with what you're trying to do. You want replace the butterflies after porting the manifold? Why? The runner diameter will be larger, and the plates will not seat against the runner walls anymore, so what's the point?
You're best bet is to just put the rod back in, with the actuator and everything, but no flappers. This way the ecu thinks everything is kosher, and you won't get any CEL's.
09TrueRedGTX is offline   Reply With Quote
The Following User Says Thank You to 09TrueRedGTX For This Useful Post:
WetzMS3 (02-12-2015)
SURE SRI Install...Screws too big? CU_Slik Mazdaspeed3/6 General Discussion 14 10-07-2012 11:03 PM
Rotor screws stuck? Delphie MazdaSpeed 3/6 - Suspension & Brakes 14 12-18-2011 09:07 PM
CP-E Xcel Nano MAF screws... ms3bamf 2010 MS3 - Turbo Induction 13 06-17-2011 07:59 AM
Page generated in 0.23436 seconds with 21 queries
