 Old 03-27-2014, 06:38 PM   #1
jacarper's Avatar
Posts: 23   (View Stats)
jacarper is on a distinguished road
Groaned at 5 Times in 1 Post
Default speed 3 boost problem?
Having a boost problem. I have searched and found multiple answers for similar problems but I cant tell if they are the same problems, anyways.. 2007 speed 3 CS SRI, TIP, Straight pipe after the stock down pipe. running a stage 1 AP tune.
Shitty video but were getting some kind of weird cut out around 5500rpms. HPFP internals are being installed this weekend and a CS DP next weekend.
Any idea on this cutout?
jacarper is offline   Reply With Quote
 Old 03-27-2014, 06:55 PM   #2
Erick13Speed3's Avatar
Posts: 353   (View Stats)
Erick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the world
Do you have an accessport? A log would help a lot. Regardless I'm pretty sure you're hitting a fuel cut seeing as you do not have your hpfp internals installed. Me, as well as many other people will urge you to take it easy until you get the internals installed
Erick13Speed3 is offline   Reply With Quote
 Old 03-28-2014, 04:56 AM   #3
jacarper's Avatar
Thanks for the advice.
Yes I have an AP and hpfp will be installed on saturday, after that if i'm still having issues i'll post a log.
2013 speed... No boost problem kennyg1966 Gen2 MS3 General Discussion 20 12-06-2013 09:57 AM
Had a boost problem :/ Evolution99 MazdaSpeed 3/6 - Turbo Induction 2 03-29-2013 05:43 PM
First problem for the speed....... jracer MazdaSpeed 6 - Engine, Transmission & Driveline 11 11-10-2011 05:18 PM
Need some ideas for low boost problem zdrpewter01 MazdaSpeed 3/6 - Turbo Induction 3 09-03-2011 03:33 PM
same problem... boost spike LiEast MazdaSpeed 3/6 - ECU Computer Tuning 4 10-11-2009 10:31 AM
Page generated in 0.23836 seconds with 22 queries
