 Old 04-26-2014, 07:01 PM   #1
Motokag444's Avatar
Posts: 10   (View Stats)
Motokag444 will become famous soon enough
Default The Speed is surging...
Strange issue... When Im cruising at a constant speed (5th-6th gear) on the highway at low RPM with no acceleration my car is surging intermittently. I still can get full boost and when I let the car idle it is fine. Also when surging my boost gauge is also very sporadic. I have a SURE TIH, Cobb intake, and FORGE recirculation valve. I checked all hoses and clamps leading up to turbo inlet and all are tight. This started to happen about a month after TIH and intake install (might not be related). Is it possible i need to just get an Accessport and tune. It is pretty intermittent and I have no CEL or fault codes in car. I am a bmw mechanic and have never ran into something like this??? Any thoughts, ideas, or experiences would be helpful. Thanks
Motokag444 is offline   Reply With Quote
The Following User Says NO Thank You to Motokag444 For This Un-useful Post:
Vansquish (05-16-2014)
 Old 04-26-2014, 07:27 PM   #2
littleloogy's Avatar
Posts: 4,005   (View Stats)
So when you are in 5th and you boost it does not surge?
 Old 04-26-2014, 07:43 PM   #3
Motokag444's Avatar
No not at all, when I intentionally boost the car is fine. It doesnt skip a beat when I intentionally boost in any gear. It is only when cruising that it acts up.
 Old 04-26-2014, 07:53 PM   #4
sidekick's Avatar
Posts: 3,093   (View Stats)
How many miles? The EGR valve could be stuck open with carbon build-up. EGR would only be active during cruising, so just something to think about.
littleloogy (04-26-2014)
 Old 04-26-2014, 07:59 PM   #5
Motokag444's Avatar
Damn thats a good thought, 88k on the car. I will have to look into that. Would that really have an impact on my boost (boost guage though?) It is pretty frustrating and I have been searching like crazy to get some ideas. Its definitely not a missfire sort of feeling... just more of a surging/lunging that the car does. Im gonna have to pull spark plugs, check EGR and do some simple shit first to see whats going on.
The Following User Says Thank You to Motokag444 For This Useful Post:
 Old 04-26-2014, 08:04 PM   #6
You are boosting while cruising at a constant speed? I am confused by this part of your statement.
It was a trick question to try to get you to admit that you boost in higher gears which is a NoNo! The MZR does not like low RPM torque. It is good practice to Never boost in 5th or 6th gear unless you are shifting to 5th from 4th while going WOT.
 Old 04-26-2014, 08:34 PM   #7
Motokag444's Avatar
That's why I put "boost gauge" in parenthesis. I guess technically it would be vacuum it's affecting. I honestly didn't know that they don't like boost in higher gears though. Thanks for the heads up.
 Old 04-26-2014, 08:45 PM   #8
Moved to the proper section...
 Old 04-26-2014, 08:49 PM   #9
Big Dog's Avatar
Posts: 730   (View Stats)
Groans: 89
Groaned at 9 Times in 9 Posts
Sounds like someone's car has been neglected and is due for maintenance.
1. Check where your tih and turbo meet. That coupler or hose likes to get lose and after install of a aftermarket tih it has to be retightened.
2. Thoroughly clean the EGR, Throttle body, Intake Manifold, Valves,. Be sure to use a new intake manifold gasket.
3. Replace the PCV valve with a new OEM Mazda one.
4. New NGK factory Plugs - Go stock heat range with your mods and gap between .028-.032
5. Clean MAF Sensor
6. Buy a DashHawk or AP so you can monitor things afterwards.
7. Report back after the above is done.
The Following 4 Users Say Thank You to Big Dog For This Useful Post:
ItsNox (04-27-2014), Kyle Undefined (04-27-2014), Motokag444 (04-27-2014), sidekick (04-27-2014)
 Old 04-27-2014, 08:31 AM   #10
Motokag444's Avatar
Sounds like a plan, I will try and get everything for next weekend, u recommend the walnut shell blasting that a lot of guys are doing for valve cleaning?
 Old 04-27-2014, 08:40 AM   #11
Sideswipe Magnet
Kyle Undefined's Avatar
Posts: 3,378   (View Stats)
Groans: 332
Yes, it works really well.
Emerald Green 2002 Miata
Mods:
Waiting list:
Full vinyl wrap
Events:
LynzeCs bottom bitch.
 Old 05-16-2014, 12:23 AM   #12
LordKingston's Avatar
Posts: 48   (View Stats)
LordKingston is on a distinguished road
Any news?
LordKingston is offline   Reply With Quote
 Old 05-17-2014, 09:12 AM   #13
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
are you having turbo surge or another king of surge because it cannot surge out of boost ????
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 05-17-2014, 09:24 AM   #14
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Bet you a dorra it's the BCS
car is surging 07CX-7KID CX-7 > Issues & Troubleshooting 18 08-30-2011 02:53 PM
Surging @3,000 RPM Hit Redline Mazdaspeed3/6 General Discussion 10 12-11-2010 12:57 PM
HELP!!!! BOV surging volodya84 MazdaSpeed 3/6 - Turbo Induction 3 07-30-2010 09:48 AM
Surging Shanems3 MazdaSpeed 3 - Engine, Transmission & Driveline 14 04-25-2010 02:37 PM
Surging?? phantom3 MazdaSpeed 3/6 - ECU Computer Tuning 8 11-16-2008 09:26 AM
Page generated in 0.33617 seconds with 28 queries
