 Old 05-24-2009, 09:57 PM   #1
ms3boost's Avatar
Posts: 400   (View Stats)
ms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to behold
Default steedspeed manifold ebay
wonder what version they are?
Mazdaspeed 6 and 3 turbo manifold.:eBay Motors (item 280349330480 end time May-30-09 1010 PDT)
2008 TR MS3 Sport[/B]:Cobb Sri,AP/Corksport Dp/Vibrant Dp Back/Pg HF CDFP/SU Boost Tubes/TRZ Poly MM/TWM STS, Shifter bushings/DashHawk/Turbosmart DualPort BOV/15,35% Tints/AutoExe Shift Knob/ Redline Shifter,E-brake Boot
Future Mods[/B]auter Rods/CP pistons/PTP SST K04/PG Tubular Manifold EWG/Turbo XS Dp/Cobb TIP/HKS Plugs/Perrin OCC/Devils Own WM Injection/BC Racing Coilovers/Hotchkis H&R Sway Bars/Rotora F&R slotted Rotors/EBC Red stuff Pads/Goodridge Stainless Brake Lines/ACT Street clutch and flywheel/Cobb FMIC/Tial 38mm v-band and screamer pipe/SU Side Mounts/8000k HIDs/PTP BS delete,WT/rx8 wheels/samco silicone hoses/235-40-18 Falken Azenis RT-615/P&L Motorsports ATP or ATR tune we will see though although 350whp is the goal!
ms3boost is offline   Reply With Quote
 Old 05-24-2009, 10:41 PM   #2
steedspeed's Avatar
Posts: 582   (View Stats)
steedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the worldsteedspeed is the leader of the world
The version that you should only buy if your stock manifold is broke!
steedspeed is offline   Reply With Quote
 Old 05-25-2009, 10:10 AM   #3
BentClamps's Avatar
Posts: 51   (View Stats)
BentClamps will become famous soon enoughBentClamps will become famous soon enough
Did you CNC part numbers into them or other identifiable ways? Asking in case people are looking to buy used in the future.
BentClamps is offline   Reply With Quote
 Old 05-25-2009, 10:14 AM   #4
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
The final design will be different. You'll be able to tell as far as i am aware...
 Old 05-25-2009, 02:31 PM   #5
steedspeed's Avatar
The new design is substantially different to these ones so no problem identifying them. I started cutting the new prototype this morning.
Gauging interest: SteedSpeed Turbo Manifold subparpunk03 MazdaSpeed 3/6 - Turbo Induction 737 07-14-2010 09:41 PM
Looking for a manifold phantomspeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 0 03-25-2009 07:54 PM
High strength studs for turbo (manifold to head and manifold to turbo) bnoon MazdaSpeed 3/6 - Turbo Induction 4 03-11-2009 10:26 PM
Externally Wastegated Turbo Manifold vs Tubular Turbo Manifold nobmood Mazdaspeed3/6 General Discussion 18 03-01-2009 08:14 PM
Page generated in 0.26081 seconds with 23 queries
