  • 1 Post By dizzin9
  • 1 Post By nickdbz
 Old 03-08-2010, 05:42 PM   #1
dizzin9's Avatar
Posts: 1,807   (View Stats)
Groans: 77
Question Stock PCV Valve Removal
just want to diagnose things and i want to start by replacing the pcv valve. this is my daily so i have to drive the car to work and just waiting for a few more items before i start putting my new turbo. do i just pull it out or do i have to go the hard way by taking the IM off?
talonlee likes this.
 Old 03-08-2010, 07:45 PM   #2
dizzin9's Avatar
Groans: 77
oh well... FML.
 Old 03-08-2010, 07:49 PM   #3
JmkC's Avatar
Posts: 871   (View Stats)
JmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the world
Groans: 109
there is a plastic clip holding it in place.. you can try from undernear the car, but removing the intake manifold depending if you have done it before could be easier
JmkC is offline   Reply With Quote
The Following User Says NO Thank You to JmkC For This Un-useful Post:
 Old 03-08-2010, 07:56 PM   #4
dizzin9's Avatar
Groans: 77
u done this b4? how do u get access to that clip?
 Old 03-08-2010, 08:08 PM   #5
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
im pritty sure you haved to remove the im to do this. there is a plastic cover over part of the pcv valve.
 Old 03-08-2010, 08:41 PM   #6
nickdbz's Avatar
Posts: 30   (View Stats)
nickdbz has a spectacular aura aboutnickdbz has a spectacular aura about
Groaned at 8 Times in 2 Posts
Why do you want to remove it? Why not just disregard it and add another heavy duty PCV in line on a CC setup? Thats what I did. Maybe I'm missing your point.
DJR likes this.
nickdbz is offline   Reply With Quote
 Old 03-08-2010, 08:43 PM   #7
dizzin9's Avatar
Groans: 77
maybe because it's faulty????? i'm missing YOUR point if u ask me.
 Old 03-08-2010, 09:00 PM   #8
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,931   (View Stats)
Groans: 70
There's a block breather box on the block that the PCV valve sits in. You need to remove that box, in-order to get at the clip and remove the PCV valve.
IDK if you could get at the 10 or so 10mm bolts, that hold the breather box to the block, w/o removing the mani.
How do you know you're stock valve is faulty?
Current Fail:
The Following User Says Thank You to MATT DAMOND For This Useful Post:
rfinkle2 (12-20-2012)
 Old 03-08-2010, 09:04 PM   #9
dizzin9's Avatar
Groans: 77
it might be faulty. i'm trying to know if it is.
 Old 03-08-2010, 11:45 PM   #10
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
If you look at my crankcase breather thread you might be able to get an idea of what you would need to do to get to it. I highly doubt you can get that clip off without removing the breather.
2006 Mazdaspeed 6
ZoomZoom_ms6 (03-03-2011)
 Old 03-08-2010, 11:58 PM   #11
phantom3's Avatar
Posts: 1,223   (View Stats)
Groans: 190
Now you tell us... What happened to "Just pull on it! It'll pop right out!"
My mission is to go fast.
Currently Designing:
The golden girdle of the gods
The CF "fuck your face" IM
phantom3 is offline   Reply With Quote
 Old 03-09-2010, 12:58 AM   #12
JmkC's Avatar
Groans: 109
lol you werent suppose to pull on the pcv itself, we just needed the hose off it.
id say easy way is remove intake manifold.
The Following 2 Users Say Thank You to JmkC For This Useful Post:
phantom3 (03-09-2010), ZoomZoom_ms6 (03-03-2011)
 Old 03-09-2010, 08:19 AM   #13
bnoon's Avatar
Posts: 1,770   (View Stats)
You can test the pcv without removing it by temporarily removing the stock hose from the intake manifold and connecting a longer piece of 5/8 hose. You can suck on the hose (LOL) or blow air in from the valve cover side to make sure air comes out that pcv valve through the longer hose and you can pressurize the longer hose with an air compressor to make sure the pcv holds pressure.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
The Following 2 Users Say Thank You to bnoon For This Useful Post:
Meder (12-20-2011), ZoomZoom_ms6 (03-03-2011)
 Old 03-09-2010, 08:27 AM   #14
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
do you think the engine has a preference? maybe alternate a little?
The Following 3 Users Say Thank You to karl-hungus For This Useful Post:
Cosmic3MPS (03-09-2010), duappleganger (08-01-2014), TriO (04-15-2012)
 Old 03-09-2010, 08:31 AM   #15
Cosmic3MPS's Avatar
Posts: 355   (View Stats)
Cosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the world
Groans: 31
Groaned at 22 Times in 10 Posts
Just make sure to keep your teeth out of it!
How to deflower virgins:
At the crucial point the guy bites her on the ear. Distracts from the pain. Ever try that?
Mitch: Hell no, I sock 'em in the jaw and yell, "Pop goes the weasel."
Cosmic3MPS is offline   Reply With Quote
The Following User Says Thank You to Cosmic3MPS For This Useful Post:
karl-hungus (03-09-2010)
 Old 03-09-2010, 08:32 AM   #16
tbot's Avatar
Posts: 2,821   (View Stats)
Groans: 40
Dude, I just helped a buddy with this since he broke his PCV valve. Removing the intake mani isn't as hard as it sounds and makes the whole process of working on the PCV valve a HELL-OF-A lot easier. I would recommend doing that honestly. Plus then you get to see all the shit built up on your valves
 Old 03-09-2010, 09:21 AM   #17
patrick failman
Groans: 74
a little teeth is okay, but you don't want to be a biter.
The Following User Says Thank You to karl-hungus For This Useful Post:
weird tire wear pattern. stock tires. stock rim. stock suspention. stock tire pressure what's up with this? labikesrcool MazdaSpeed 3/6 - Wheels & Tires 21 11-30-2015 03:32 PM
MS6 ECU removal kore2000 MazdaSpeed 3/6 - ECU Computer Tuning 14 01-27-2010 03:19 PM
Removal of pill phantom3 MazdaSpeed 3/6 - Turbo Induction 3 10-22-2009 12:02 AM
got myself a dilema with stock pcv valve, it cracked... bova MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 09-08-2008 10:18 PM
Page generated in 0.37375 seconds with 30 queries
