 Old 01-01-2011, 12:44 AM   #1
awdfun's Avatar
Posts: 41   (View Stats)
awdfun is a splendid one to beholdawdfun is a splendid one to beholdawdfun is a splendid one to beholdawdfun is a splendid one to beholdawdfun is a splendid one to beholdawdfun is a splendid one to behold
Default test pipe question
got around to installing my test pipe today. finally got the crazy spring bolts to break loose and pulled the cat off. after i took it out, i quickly realized that the stock cat had been completely removed from the pipe by the previous owner. it was basically a test pipe. he had gutted it and put the heat shield back on. i've passed state inspection twice since i've had the car. i got the wrong size nuts to put back on the spring bolts that connect the downpipe to the test pipe. i had to declare epic fail and put the stock cat back on until i had more time to track down hardware. does anyone that's installed a test pipe know what size hardware to get to put back on those spring bolts?
also do you think i should even put the test pipe on or just roll will the gutted cat? the tp is 2.5" so i know it's a little bigger than the stock pipe. should the tp flow better since it's straight and doesn't open up and bottleneck like the stock pipe? do you think it will sound any different?
thanks
awdfun is offline   Reply With Quote
 Old 01-01-2011, 07:25 AM   #2
ScarMS3's Avatar
Posts: 2,088   (View Stats)
Groans: 97
Sounds like you're good to go, sell the test pipe on here or try to return it
 Old 01-01-2011, 08:11 AM   #3
asall667's Avatar
Posts: 1,017   (View Stats)
asall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the worldasall667 is the leader of the world
Groans: 56
Groaned at 37 Times in 18 Posts
How much did u buy the tp for? I don't know what size hardware u need sorry but roll with the gutted cat ur good to go
asall667 is offline   Reply With Quote
 Old 01-01-2011, 09:29 AM   #4
awdfun's Avatar
tp was like $70 shipped. think i'll sell it and get the defrost vent pod and finally install my boost gauge. thanks for the feedback...
 Old 01-01-2011, 10:49 AM   #5
BReif61's Avatar
Posts: 403   (View Stats)
BReif61 is the leader of the worldBReif61 is the leader of the worldBReif61 is the leader of the worldBReif61 is the leader of the worldBReif61 is the leader of the worldBReif61 is the leader of the worldBReif61 is the leader of the worldBReif61 is the leader of the worldBReif61 is the leader of the worldBReif61 is the leader of the worldBReif61 is the leader of the world
If the cat's gutted, I'd keep that on there. It will draw less attention, both at the dealer and any inspection/emission tests you need done.
-Brad
BReif61 is offline   Reply With Quote
 Old 01-02-2011, 03:07 AM   #6
pearl_ms3's Avatar
Posts: 545   (View Stats)
pearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the world
Groaned at 27 Times in 12 Posts
what testpipe is it u might sell?
CP-E INTAKE W/ AMSOIL FILTER, CP-E INLET, TURBOSMART BOV, DENSO ITV22, AWR RMM, STREET-UNIT TMM & PMM, STEEDSPEED MANI CERAMIC COATED, T3 GT3076, TIAL EWG, CUSTOM V-BAND DOWNPIPE, UR CATTED TESTPIPE, TURBO XS CATBACK EXHAUST, COBB FMIC, CP-E FUEL PUMP, DASHHAWK+CP-E MOUNT, JBARONE SSP, COBB ACCESSPORT STAGE 2 SF 91 FMIC. SELF TUNED WITH 400HP/375TQ @ 21 PSI ON 100 OCTANE.
pearl_ms3 is offline   Reply With Quote
 Old 01-02-2011, 07:00 AM   #7
dscsk8er55's Avatar
Posts: 50   (View Stats)
dscsk8er55 is a jewel in the roughdscsk8er55 is a jewel in the roughdscsk8er55 is a jewel in the roughdscsk8er55 is a jewel in the rough
That is funny and crappy all in the same time. At least you will be able to make that money back.
dscsk8er55 is offline   Reply With Quote
 Old 01-02-2011, 06:17 PM   #8
ms3_kidd's Avatar
Posts: 356   (View Stats)
ms3_kidd is the leader of the worldms3_kidd is the leader of the worldms3_kidd is the leader of the worldms3_kidd is the leader of the worldms3_kidd is the leader of the worldms3_kidd is the leader of the worldms3_kidd is the leader of the worldms3_kidd is the leader of the worldms3_kidd is the leader of the worldms3_kidd is the leader of the worldms3_kidd is the leader of the world
how convenient that the cat has already been gutted for you
2009 Mazdaspeed3 Grand Touring
Cobb SF Intake — Street Unit Silicone Boost Tubes — Street Unit Shifter Spacers — AWR Rear Engine Mount
HKS SSQV Blow Off Valve — 2nd Cat Delete — JBarone SSP — Yellow Fog Light Overlay — 20% Window Tint
Hella Supertones — H&R Lowering Springs — Koni Sports "Yellows" — GV Replica Front Lip — HKS Cat Back
ms3_kidd is offline   Reply With Quote
 Old 01-02-2011, 07:05 PM   #9
awdfun's Avatar
yeah, it was kinda funny when i looked throught the cat and realized i could see the ground!!! gonna sell it and get a boost gauge...
it's a 2.5" sls tp
 Old 01-05-2011, 11:05 PM   #10
andrew416's Avatar
Posts: 52   (View Stats)
andrew416 will become famous soon enoughandrew416 will become famous soon enough
Groaned at 9 Times in 5 Posts
My friend has a gutted cat and it sounds good!
andrew416 is offline   Reply With Quote
Ultimate racing test pipe and down pipe install w pics 2010 MS3 2010 MS3 - Engine, Transmission & Driveline 28 03-17-2010 10:38 AM
Brand name test pipe vs. custom muffle shop test pipe Huligan MazdaSpeed 3 - Engine, Transmission & Driveline 10 10-05-2009 07:52 AM
SU test pipe vs. turboxs test pipe ZoomByU MazdaSpeed 3 - Engine, Transmission & Driveline 22 08-06-2009 03:09 AM
Which Race Pipe/Test Pipe is the best for a Mazdaspeed 6? ItalianSA MazdaSpeed 6 - Engine, Transmission & Driveline 6 04-20-2009 12:14 PM
Page generated in 0.28813 seconds with 27 queries
