  • 1 Post By CWP_MS3
 Old 09-30-2013, 12:42 PM   #1
timjustindodd's Avatar
Posts: 45   (View Stats)
timjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the world
Default To those of you with a FMIC
So... I'm looking to either do a FMIC or an WTA IC. I already have a WTA IC so I'm considering just using that and it would fit right where my stock air box would have sat, below my HTP filter and stuff... it would be a near perfect fit with a straight shot going literally straight to the throttle body, with ONE problem...
THAT DAMN RADIATOR HOSE!!!!
So what do you guys do when you encounter that problem? Is there an after market hose we can switch to that is longer and drops more out of the way? Most of the kits for a FMIC that I've seen are still a relatively straight pipe going into the TB, so it makes me wonder how they do that...
What have you done for this solution?
2006 Mazdaspeed6 | SNR S3 | Stratified Tune | Corksport DP | Corksport TP | Cobb AP | SU TMIC | HTP 3" intake | HTP battery tray | 3 bar MAP | HPFP | Whiteline rear sway bar | SU Rear engine mount | SU rear diff mount | Forge BPV
timjustindodd is offline   Reply With Quote
 Old 09-30-2013, 12:44 PM   #2
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
you can rotate it for more access or bring the old hose to autozone and find one that matches the length but has a bigger dip.
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 09-30-2013, 12:54 PM   #3
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
is there a confirmed hose with a bigger dip in it my Water to air just sits on my coolant hose and pushes it down a bit but otherwise still flows fine
 Old 09-30-2013, 04:00 PM   #4
Big Ivan's Avatar
Posts: 57   (View Stats)
Big Ivan has a brilliant futureBig Ivan has a brilliant futureBig Ivan has a brilliant futureBig Ivan has a brilliant futureBig Ivan has a brilliant futureBig Ivan has a brilliant futureBig Ivan has a brilliant futureBig Ivan has a brilliant futureBig Ivan has a brilliant futureBig Ivan has a brilliant futureBig Ivan has a brilliant future
I had to do this when I was installing my custom piping for my FMIC, just took it out switch ends and there you go more space!!
2008.5 Mazdaspeed3
Stocking out
Big Ivan is offline   Reply With Quote
 Old 09-30-2013, 11:43 PM   #5
Axel907's Avatar
Posts: 231   (View Stats)
Axel907 is the leader of the worldAxel907 is the leader of the worldAxel907 is the leader of the worldAxel907 is the leader of the worldAxel907 is the leader of the worldAxel907 is the leader of the worldAxel907 is the leader of the worldAxel907 is the leader of the worldAxel907 is the leader of the worldAxel907 is the leader of the worldAxel907 is the leader of the world
Rotating it worked for me
2006 BCM MS6 GT Plasti-dipped Black
Current Mods:
BNR S3, HTP 3 inch TIP, Sure Shortcut, Sure RRM, Denzo One Step Colder, Autotech HPFP, KrankVents, Dashhawk, Water to Air Intercooler, HTP 3 Inch MAF Housing, MATT DAMON OCC, Block8Head Vent Pod, Prosport Electric Boost Guage, Napa remanufactured long block, Grimmspeed EBCS, 3 Bar Map with Matt Jackson Harness, JBR Intake Manifold TIG, ACT Clutch and Flywheel, JBR 70 duro PMM and TMM, Snow performance stage 2 meth setup to run off MAF signal, Kosmic motorsports full EGR delete, CPE injector seals, Oil filter conversion kit, AUX jack mod, Sure shift nob, HKS BOV W/recirc, M2 Downpipe And Ofcourse an AP... Tune in Progress
VVT and Timing Chain replaced under warranty at 69,000 miles
Spun rod bearing at 69,355 miles
Built Motor at 69,363 miles
Axel907 is offline   Reply With Quote
 Old 10-01-2013, 07:17 AM   #6
Same here, just rotated one side. Just be sure the hose isn't left with a bind or kink in it.
Any longer radiator/heat rated hosing that you can get to fit should work too.
 Old 11-05-2013, 07:08 PM   #7
Mortose's Avatar
Posts: 2,441   (View Stats)
Groans: 39
the butthurt is strong with this one.
99 miata: sold
The Following User Says Thank You to Mortose For This Useful Post:
CWP_MS3 (11-05-2013)
 Old 11-05-2013, 07:40 PM   #8
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Speed3syndicate (ID # 37867) was banned by CWP_MS3 (ID # 21969)
Reason given: I'm an MSF douche bag; get the fuck off my site!
Date the ban will be lifted: Never
heh
Mortose likes this.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
The Following 4 Users Say Thank You to CWP_MS3 For This Useful Post:
jdmage_mx5 (11-05-2013), magicka (11-05-2013), Mortose (11-05-2013), Playaj (11-05-2013)
 Old 11-08-2013, 08:51 AM   #9
Mistersix's Avatar
Posts: 2,585   (View Stats)
I rotated mine when i did a custom fmic piping. I found i didn't even need to remove it. I just move the clamps up the hose outta the way and twisted it while it was still attached. Just grab it where at the neck of where its attached and twist it with you hand. It took some muscle but it turned. Just do both ends and it will be completely clocked out of the way.
Do Yourself FMIC w/treadstone fmic I Love Brownies MazdaSpeed 3 - How-To's 140 02-13-2013 09:18 AM
Cobb FMIC vs Exhaust Depot FMIC mrjoshyman MazdaSpeed 3/6 - Turbo Induction 44 04-20-2009 10:30 AM
Page generated in 0.31685 seconds with 28 queries
