 Old 09-05-2017, 05:31 PM   #1
KamloopsDan's Avatar
Posts: 64   (View Stats)
KamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to all
Default Turbo bolt on kit question
Hey,
Can someone who has installed a BNR turbo please help me out here?
I want to replace my stock turbo with a BNR S4, and also get a 3.5" intake to match the turbo outlet.
*But* as I live in Canada I want to order everything in one go and have everything I need to hand for the day of the install.
So my question is, can someone please take a look at this list and let me know if I need anything else? when I say anything, I mean anything. Extra nuts and bolts, coolant lines, gaskets etc.
The car already has all the required prerequisites so I don't mean stuff like HPFP internals and step colder plugs, I mean stuff I need for the day of the install so I can drive it home.
This is what I intend to buy.
The Turbo bolt on kit
BNR Stage 4 Turbo Kit Mazdaspeed 3 2007-2013 | Mazdaspeed 6 2006-2007
Smaller battery tray (to make room for the larger intake)
Mazdaspeed 6 51R Small Battery Box [MS6-BTRY-BOX] - $95.00 : James Barone Racing, Aftermarket Performance
HTP 3.5" Full Intake
HTP Mazdaspeed 3.5" Full Intake System - Hi-Tuned Performance Products
Boost control solenoid
Electronic Boost Control Solenoid 3-Port - MazdaSpeed 6 - GrimmSpeed
3.5 bar MAP sensor
Bosch 3.5 Bar TMap Map Sensor with IAT
Accessport tune loaded ready to be flashed.
Thanks very much
Dan
KamloopsDan is offline   Reply With Quote
 Old 09-05-2017, 05:50 PM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
I found it easier to do the swap by removing the exh manifold. If you go that route, you need to have a gasket for that too.
Strange that I see new studs in the kit but not locking nuts...
If you remove the oil drain line from the block, you'll need that gasket.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 09-05-2017, 06:00 PM   #3
Regarding the exhaust manifold gasket, does this look like the correct part?
Mazda OEM Manifold Turbo Gasket MS3 MS6
For the exhaust manifold bolts and nuts, I was told to order 9 of each, does that seem correct?
Mazda OEM Exhaust Manifold Nut Mazdaspeed 3 Mazdaspeed 6 2006-2013
Mazda OEM Exhaust Manifold Stud Mazdaspeed 3 Mazdaspeed 6 2006-2013
Would you mind sending me a link for the oil drain line block gasket?
Thanks
 Old 09-05-2017, 06:13 PM   #4
Fstrnyou's Avatar
That's the manifold/turbo gasket and comes with the kit. I'm talking about the manifold/engine gasket.
Looks like 9 studs come in the kit. Just get the nuts.
You can find various gaskets and such at JimEllisMazdaParts.com
Other rides:
History:
 Old 09-05-2017, 06:21 PM   #5
OK got it. Thanks for your help.
Did you have any issues with coolant lines not being long enough? I thought I read somewhere that it was a good idea to get some extra just in case.
 Old 09-05-2017, 07:48 PM   #6
Fstrnyou's Avatar
I have the Corksport kit. But yeah, I did need to do some coolant line trickery.
Other rides:
History:
 Old 09-05-2017, 09:48 PM   #7
Jakeypoo's Avatar
Posts: 226   (View Stats)
Jakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond reputeJakeypoo has a reputation beyond repute
Please explain this trickery you speak of. I too have the Corksport and the coolant lines are not to my satisfaction. One is rubbing on the wastegate the other on the TIP. I am going to try and figure it out this weekend.
Did you splice into them and make them longer to go under or over? By the block or by the firewall?
2009 Mazdaspeed with 134,000 miles, Corksport Turbo, AT internals, CNT Turbo Back, AP, fully mounted, 3 bar, Freaktuned E25.
Jakeypoo is offline   Reply With Quote
 Old 09-06-2017, 05:55 AM   #8
GroceryGtr's Avatar
Posts: 472   (View Stats)
you're missing the harness for the map sensor. You don't technically need a battery tray for the 6, you can modify the stocker to work with the larger intake. It will make things easier though.
On the 6s I'd suggest you remove the cowling. This takes about 15 minutes and gives you a ton of extra room around the turbo to work with.
 Old 09-06-2017, 06:14 AM   #9
Djohns's Avatar
Posts: 3,944   (View Stats)
If you're going to be removing the exhaust manifold I would highly recommend new studs and nuts for that, as far as oil drain gasket, the BNR s4 kit comes with that so no need to worry. Also order 5 extra nuts for the downpipe studs. The studs that come in the kit are stricky meant for the turbo, nothing else so you will need to get manifold studs.
2010 black mica speed3
Soon:built motor
 Old 09-06-2017, 09:12 AM   #10
Thanks for the updates everyone, I have added the following parts to the list.
Bitwise Motorsports Bosch MAP Sensor Connector
Bitwise Motorsports Bosch MAP Sensor Connector Mazdaspeed 3 Mazdaspeed 6
9 nuts for the turbo to manifold and 5 nuts for turbo to downpipe connection
10mm (1.5 pitch) Nut Locking Head
10 nuts and studs that secure the exhaust manifold to the head
Anything else I forgot?
Cheers
 Old 09-09-2017, 03:52 PM   #11
So another few items that I have been advised to purchase are the two gaskets that come with the BNR kit. Apparently they are bad quality and I should get Mazda OEM replacements.
I am talking about the Upper Downpipe Gasket & the Manifold Turbo Gasket.
And as I am installing a large 3.5" intake, I should also buy a 5/8" Hose Extension Kit from HTP at the same time as ordering the intake.
5/8" Hose Extension Kit - Hi-Tuned Performance Products
Anything else?
 Old 09-09-2017, 04:34 PM   #12
Djohns's Avatar
Anything else?
I haven't had any problems with the included gaskets, and honestly you can make that extension hose for far cheaper than HTP wants.
Soon:built motor
Question about Bolt on TMM iammike Custom Performance Engineering (cp-e.com) 8 06-29-2015 01:09 PM
CP-E Downpipe bolt question mutiger93gt MazdaSpeed 3 - Engine, Transmission & Driveline 8 01-24-2012 05:05 AM
bolt size question Ozark Gen2 MS3 General Discussion 4 07-13-2011 05:53 PM
Missing Bolt Question MOVOVR MazdaSpeed 3/6 - Turbo Induction 3 03-29-2010 01:05 PM
Page generated in 0.33379 seconds with 24 queries
